It is currently Wed May 14, 2025 11:31 pm
Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject:
PostPosted: Fri Jun 01, 2007 8:18 pm
OK, thanks! :thumbs_up_1:
-Abram
ModelWarships Gallery Page
Joslin Models Facebook Page
 Post subject:
PostPosted: Sat Jun 02, 2007 12:01 am
She's beautiful Jef :thumbs_up_1:
Dino
 Post subject:
PostPosted: Sat Jun 02, 2007 3:07 am
Excellent! :thumbs_up_1:
 Post subject:
PostPosted: Sat Jun 02, 2007 3:42 am
Really looks superb! :thumbs_up_1:
 Post subject:
PostPosted: Sat Jun 02, 2007 12:03 pm
She looks AWESOME Jefgte :thumbs_up_1:
 Post subject:
PostPosted: Sun Jun 10, 2007 12:23 pm
:wave_1:
Sorry to be late for the week update...
Well, here is the last update for Study 8 - Coastal battleship "Short Hull"
This PB must be finish for saturday june 16th.
Jef :wave_1:
Current 1/700 WL
HMS Repulse
 Post subject:
PostPosted: Mon Jun 11, 2007 6:21 pm
:heh: :heh: :heh:
The paint on the turrets was use as air identification in 1940
Yes but, I don't like this red brown paint on the turrets
I change to classic 1939 paint...
Jef :wave_1:
Current 1/700 WL
HMS Repulse
 Post subject:
PostPosted: Mon Jun 11, 2007 6:24 pm
Looking good :jump_1: :jump_1: :woo_hoo: :woo_hoo: :wave_1: :thumbs_up_1: :lol_spit_1: :lol_spit_1:
Simple but effective.
 Post subject:
PostPosted: Tue Jun 12, 2007 5:18 pm
:thumbs_up_1: :thumbs_up_1:
 Post subject:
PostPosted: Sat Jun 16, 2007 12:35 pm
Study 8 "Short Hull" is finish
:lol_spit_1: :lol_spit_1: :lol_spit_1:
Here is the SpringSharp
Study 8, germany Coastal Battleship laid down 1929
Displacement:
11 281 t light; 11 890 t standard; 12 010 t normal; 12 105 t full load
Dimensions: Length overall / water x beam x draught
452.76 ft / 446.19 ft x 76.12 ft (Bulges 77.43 ft) x 22.37 ft (normal load)
138.00 m / 136.00 m x 23.20 m (Bulges 23.60 m) x 6.82 m
Armament:
9 - 11.02" / 280 mm guns (3x3 guns), 669.80lbs / 303.82kg shells, 1929 Model
Breech loading guns in turrets (on barbettes)
on centreline ends, majority aft, 1 raised mount aft - superfiring
8 - 3.46" / 88.0 mm guns (4x2 guns), 20.79lbs / 9.43kg shells, 1929 Model
Quick firing guns in deck mounts
on side, evenly spread
8 - 1.46" / 37.0 mm guns (4x2 guns), 1.55lbs / 0.70kg shells, 1929 Model
Anti-aircraft guns in deck mounts
on side, evenly spread, 2 raised mounts
8 - 0.79" / 20.0 mm guns in single mounts, 0.24lbs / 0.11kg shells, 1929 Model
Weight of broadside 6 209 lbs / 2 816 kg
Shells per gun, main battery: 106
8 - 21.0" / 533 mm above water torpedoes
Armour:
- Belts: Width (max) Length (avg) Height (avg)
Main: 11.0" / 280 mm 255.91 ft / 78.00 m 8.60 ft / 2.62 m
Ends: 1.57" / 40 mm 147.64 ft / 45.00 m 8.01 ft / 2.44 m
42.65 ft / 13.00 m Unarmoured ends
Main Belt covers 88 % of normal length
- Torpedo Bulkhead and Bulges:
1.57" / 40 mm 255.91 ft / 78.00 m 22.24 ft / 6.78 m
- Gun armour: Face (max) Other gunhouse (avg) Barbette/hoist (max)
Main: 11.0" / 280 mm 5.91" / 150 mm 11.0" / 280 mm
2nd: 0.79" / 20 mm - -
- Armour deck: 4.72" / 120 mm, Conning tower: 11.02" / 280 mm
Machinery:
Diesel Internal combustion motors,
Geared drive, 2 shafts, 19 000 shp / 14 174 Kw = 20.34 kts
Range 500nm at 14.00 kts
Bunker at max displacement = 215 tons
Complement:
573 - 745
Cost:
£4.514 million / $18.055 million
Distribution of weights at normal displacement:
Armament: 776 tons, 6.5 %
Armour: 4 908 tons, 40.9 %
- Belts: 1 170 tons, 9.7 %
- Torpedo bulkhead: 332 tons, 2.8 %
- Armament: 1 222 tons, 10.2 %
- Armour Deck: 2 060 tons, 17.2 %
- Conning Tower: 125 tons, 1.0 %
Machinery: 584 tons, 4.9 %
Hull, fittings & equipment: 4 998 tons, 41.6 %
Fuel, ammunition & stores: 729 tons, 6.1 %
Miscellaneous weights: 15 tons, 0.1 %
Overall survivability and seakeeping ability:
Survivability (Non-critical penetrating hits needed to sink ship):
17 391 lbs / 7 889 Kg = 26.0 x 11.0 " / 280 mm shells or 3.9 torpedoes
Stability (Unstable if below 1.00): 1.03
Metacentric height 3.5 ft / 1.1 m
Roll period: 17.3 seconds
Steadiness - As gun platform (Average = 50 %): 70 %
- Recoil effect (Restricted arc if above 1.00): 0.69
Seaboat quality (Average = 1.00): 1.32
Hull form characteristics:
Hull has rise forward of midbreak
Block coefficient: 0.544
Length to Beam Ratio: 5.76 : 1
'Natural speed' for length: 21.12 kts
Power going to wave formation at top speed: 48 %
Trim (Max stability = 0, Max steadiness = 100): 53
Bow angle (Positive = bow angles forward): 5.00 degrees
Stern overhang: 4.33 ft / 1.32 m
Freeboard (% = measuring location as a percentage of overall length):
- Stem: 25.59 ft / 7.80 m
- Forecastle (20 %): 20.83 ft / 6.35 m
- Mid (50 %): 19.00 ft / 5.79 m (10.99 ft / 3.35 m aft of break)
- Quarterdeck (19 %): 10.99 ft / 3.35 m
- Stern: 10.99 ft / 3.35 m
- Average freeboard: 16.02 ft / 4.88 m
Ship space, strength and comments:
Space - Hull below water (magazines/engines, low = better): 88.2 %
- Above water (accommodation/working, high = better): 101.0 %
Waterplane Area: 23 569 Square feet or 2 190 Square metres
Displacement factor (Displacement / loading): 98 %
Structure weight / hull surface area: 152 lbs/sq ft or 742 Kg/sq metre
Hull strength (Relative):
- Cross-sectional: 0.92
- Longitudinal: 1.92
- Overall: 1.00
Hull space for machinery, storage, compartmentation is adequate
Room for accommodation and workspaces is adequate
Ship has slow, easy roll, a good, steady gun platform
Good seaboat, rides out heavy weather easily
:woo_hoo: the photos
Jef :wave_1:
Current 1/700 WL
HMS Repulse
 Post subject:
PostPosted: Sat Jun 16, 2007 12:48 pm
Looking very good jef, :woo_hoo: :wave_1: :wave_1: :thumbs_up_1:
 Post subject:
PostPosted: Sat Jun 16, 2007 1:05 pm
:thumbs_up_1:
Do you maybe have photo of all your Panzerschiff studies? On one photo of course...
 Post subject:
PostPosted: Sat Jun 16, 2007 6:54 pm
Schnellboot wrote:
" Do you maybe have photo of all your Panzerschiff studies? On one photo of course... "
I have not global photos of my Panzerschiff Studies.
I 'll take later & post certainly in Panzerschiff Fans topic.
Jef :wave_1:
Current 1/700 WL
HMS Repulse
 Post subject:
PostPosted: Sun Jun 17, 2007 6:52 pm
Very nice! :thumbs_up_1: :thumbs_up_1:
 Post subject:
PostPosted: Sat Jun 23, 2007 12:47 pm
:wave_1:
Last update for Study2 "Pocket Derfflinger" with the Baltic camouflage
Jef :lol_spit_1:
Current 1/700 WL
HMS Repulse
 Post subject:
PostPosted: Sat Jun 23, 2007 1:28 pm
They all look very nice Jef!!
-Abram
 Post subject:
PostPosted: Sat Jun 23, 2007 2:21 pm
I really like the Pocket D. ^^ It reminds me of the fake Moltke in Navyfield =P
 Post subject:
PostPosted: Sat Jun 23, 2007 2:41 pm
Great job, love the camo :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
 Post subject:
PostPosted: Sat Jun 30, 2007 5:46 pm
Study 2 is finish
:lol_spit_1:
Study 2, Germany Panzerschiff-raider laid down 1931
Displacement:
11 563 t light; 12 245 t standard; 14 417 t normal; 16 154 t full load
590.50 ft / 582.02 ft x 72.18 ft (Bulges 72.74 ft) x 23.46 ft (normal load)
179.99 m / 177.40 m x 22.00 m (Bulges 22.17 m) x 7.15 m
Armament:
8 - 11.02" / 280 mm guns (4x2 guns), 669.80lbs / 303.82kg shells, 1931 Model
on centreline ends, evenly spread, 2 raised mounts - superfiring
12 - 4.13" / 105 mm guns (6x2 guns), 35.32lbs / 16.02kg shells, 1931 Model
8 - 1.46" / 37.0 mm guns (4x2 guns), 1.55lbs / 0.70kg shells, 1931 Model
on side, evenly spread, all raised mounts
8 - 0.79" / 20.0 mm guns in single mounts, 0.24lbs / 0.11kg shells, 1931 Model
Weight of broadside 5 797 lbs / 2 629 kg
Shells per gun, main battery: 120
Armour:
Main: 3.35" / 85 mm 406.82 ft / 124.00 m 9.19 ft / 2.80 m
Ends: 1.57" / 40 mm 150.92 ft / 46.00 m 7.87 ft / 2.40 m
24.28 ft / 7.40 m Unarmoured ends
Main Belt covers 108 % of normal length
1.57" / 40 mm 406.82 ft / 124.00 m 23.36 ft / 7.12 m
Main: 6.69" / 170 mm 2.76" / 70 mm 4.92" / 125 mm
- Armour deck: 2.24" / 57 mm, Conning tower: 5.51" / 140 mm
Machinery:
Geared drive, 2 shafts, 57 600 shp / 42 969 Kw = 27.22 kts
Range 14 000nm at 15.00 kts
Bunker at max displacement = 3 909 tons
Complement:
657 - 855
Cost:
£5.474 million / $21.897 million
Armament: 725 tons, 5.0 %
Armour: 3 137 tons, 21.8 %
- Belts: 593 tons, 4.1 %
- Torpedo bulkhead: 554 tons, 3.8 %
- Armament: 749 tons, 5.2 %
- Armour Deck: 1 171 tons, 8.1 %
- Conning Tower: 70 tons, 0.5 %
Machinery: 1 722 tons, 11.9 %
Hull, fittings & equipment: 5 959 tons, 41.3 %
Fuel, ammunition & stores: 2 854 tons, 19.8 %
Miscellaneous weights: 20 tons, 0.1 %
19 381 lbs / 8 791 Kg = 28.9 x 11.0 " / 280 mm shells or 3.4 torpedoes
Stability (Unstable if below 1.00): 1.08
Metacentric height 3.6 ft / 1.1 m
Roll period: 16.1 seconds
- Recoil effect (Restricted arc if above 1.00): 0.83
Seaboat quality (Average = 1.00): 1.16
Block coefficient: 0.508
Length to Beam Ratio: 8.00 : 1
'Natural speed' for length: 24.13 kts
Power going to wave formation at top speed: 52 %
Trim (Max stability = 0, Max steadiness = 100): 60
Bow angle (Positive = bow angles forward): 10.00 degrees
Stern overhang: 3.74 ft / 1.14 m
- Stem: 26.90 ft / 8.20 m
- Forecastle (19 %): 23.62 ft / 7.20 m
- Mid (50 %): 21.46 ft / 6.54 m (13.45 ft / 4.10 m aft of break)
- Quarterdeck (18 %): 13.45 ft / 4.10 m
- Stern: 13.45 ft / 4.10 m
- Average freeboard: 18.45 ft / 5.62 m
Space - Hull below water (magazines/engines, low = better): 107.3 %
- Above water (accommodation/working, high = better): 127.3 %
Waterplane Area: 28 195 Square feet or 2 619 Square metres
Displacement factor (Displacement / loading): 116 %
Structure weight / hull surface area: 141 lbs/sq ft or 690 Kg/sq metre
- Cross-sectional: 0.96
- Longitudinal: 1.42
- Overall: 1.00
Room for accommodation and workspaces is excellent
The photos
Jef :wave_1:
Current 1/700 WL
HMS Repulse
 Post subject:
PostPosted: Sat Jun 30, 2007 5:53 pm
Looking better than ever, how you will get the R/C in to them is beyond me. :lol_3: :lol_3: :wave_1: :wave_1: :lol_spit_1: :lol_spit_1: :eyebrows: :eyebrows:
Users browsing this forum: Bing [Bot] and 32 guests
