It is currently Tue May 13, 2025 10:12 pm
Post new topic Reply to topic  [ 263 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13, 14  Next
PostPosted: Sat Dec 06, 2008 9:29 am
Amazing-crazy-admirable!
It will be some day when the mines, the crane and the ship are all married up!
:thumbs_up_1: :thumbs_up_1: JIM B
PostPosted: Wed Dec 10, 2008 11:37 am
You never cease to amaze me! :thumbs_up_1:
PostPosted: Fri Dec 12, 2008 5:50 am
Hi Ludwig
I recently discovered a portuguese resin manufacturer (RMG resinas) that produce german mines in 1/35, as well as other accessories in that same scale. I know that they have a website, but couldn´t find the address. I´ll look it up for you, if interested.
:cool_2: .
PostPosted: Fri Dec 12, 2008 6:43 am
hello all ,
thanks for the kind replies ,
@ Jose Chaica , yes that would be fine.
Ludwig
PostPosted: Fri Dec 12, 2008 8:00 am
Jose Chaica wrote:
Hi Ludwig
:cool_2: .
Their site is http://rmgresinmodels.com/
Wonderful work Ludwig
Enjoy
João
There's no brighter star than my daughter
PostPosted: Tue Jan 27, 2009 7:49 am
hello all, :wave_1:
have been working on my 'Ankerstuhl' .
a solid block of styrene
the 4 little wheels , diameter 6 mm
the wheels temporarely put in place.
the upper plate , lower and top view.
the plate on top of the anker
anker and mine together , the small disk on the right is were the chain comes , the larger one is detail for under the mine.
reel and supports , this reel is for the so called 'Voreilanker'
the reel complete and placed temporarely on the anker
and with top plate in place
the last 3 photo's are of the whole mine , Ankerstuhl and mine , the figure is a British Navy Sailor in scale 1/35 this is placed for dimentions. In the 1st and last photo , the mine is not placed in this manner , I still have to add some detail on the top plate.I also left out the horns and hook , these were not as I wanted it , I'll have to redo them
enjoy,
Ludwig
PostPosted: Fri Jan 30, 2009 4:15 am
Hi Ludwig
One question : Why a solid block of styrene to build the main component ?
:cool_2: .
PostPosted: Sat Jan 31, 2009 5:16 am
hello Jose,
A solid block is used because when I make a mould , I put it in my vacuum chamber to suck out all the air ,so now traces of air bubbles . When a hollow part is made the vacuum pump will implode it.regards,
Ludwig
PostPosted: Sat Jan 31, 2009 10:18 am
Ludwig wrote:
...A solid block is used because when I make a mould , I put it in my vacuum chamber to suck out all the air ,so now traces of air bubbles . When a hollow part is made the vacuum pump will implode it.regards...
Same problem here, but when I built my 5´mounts, I decided to fill it with plaster of Paris, instead of a solid construction... :thumbs_up_1:
:cool_2: .
PostPosted: Sun Feb 01, 2009 1:07 pm
Ludwig wrote:
hello Jose,
Ludwig
Hello Ludwig
Great job as always :thumbs_up_1:
You can avoid that mould making problem by just simply make (if possible) some small holes on a not visible surface of the part. That would allow the air inside to come out and not damaging the master.
Happy modelling
João
PostPosted: Mon Feb 09, 2009 6:26 am
hello all,
@ softsea , I have bought myself a vacuum-chamber , I hope the air bubbles problem will be solved.
I am sorry not to place an up-date earlier , but I had to redo the anker because it was 3 mm to long.
this is how it looks now , 4 grabhandless in place , also 2 lifting hooks on each side , the disk on top is an air valve.
these are all the parts I have made untill now , some more have to be made.
this photo shows all the parts (which I have made allready) in place , sorry for the blurry photo.
with the mine in place.
with navy soldier , this is for dimensions.
the mine on my boat.
this is not the only mine I am making.
this is an EMF mine , same dimensions as EMC , NO horns.
on the anker , which is the same as for EMC mine.
enjoy ,
Ludwig
PostPosted: Mon Feb 09, 2009 1:07 pm
Ludwig this is outstanding work . and you are a mast of your craft :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Mon Feb 09, 2009 1:15 pm
Site Admin
Site Admin
I agree, fantastic work. Thanks for sharing your work with us. :thumbs_up_1:
Timothy Dike
Owner & Administrator
ModelWarships.com
PostPosted: Mon Feb 09, 2009 1:26 pm
EXCELLENT! :thumbs_up_1: :thumbs_up_1:
looking forward to seeing regular progress again on her!
JIM B
PostPosted: Thu Feb 12, 2009 7:11 pm
This is my first time to this website :newbie: and I have to say "Ludwig You are the best I have ever seen!" :good_job: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: I have been building 1/35th scale German armor for a long time and started looking into building a diorama involving a port or harbor scene. I had Googled Torpedoboat, Harbor, Dock, U-Boat and a few other things, but your post came up on most of my searches. I have gotten plans for a type VII-c U-Boat that I want to build, and would give almost anything to get my hands on a set of plans for that very nice Flottentorpedoboot Typ 39 that you have there. If you could inform me on how I would accomplish such a feat I would be most appreciative. :worship_1: :worship_1: Again you are preforming a remarkable job. Keep up the good work!
Mark S. Vipond
U.S.A.
Models and Models. Both can be seen in magazines, both look good on a pedestal, I really like working on both with my hands, and when doing so, only one will slap me. Happy building!
PostPosted: Sun Feb 15, 2009 6:40 am
hello Mark,
I bought my plans at www.christian-schmidt.com , they are in scale 1/100 ,4 plans, you could also buy a copy at www.ship-model-today.de these plans are in scale 1/75 , 2 plans . I must say they are detailed , but I would like to see some more photo's , which are not that plenty.
regards,
Ludwig
PostPosted: Tue Feb 24, 2009 11:04 am
hello all,
some more photo's of my mine , the mine is almost complete now.
some etched screws glued on.
the lower horns have a ring at the end.
some more details added to the anker.
the mine on the anker , secured with 2 heavy rings on the back.
on the front side the mine is secured with a bar.
I have also worked on my aft superstructure, photo's will follow later.
enjoy,
Ludwig
PostPosted: Tue Feb 24, 2009 2:07 pm
Hi Ludwig Your attention to detail is inspirational . Question how many mines need to be made ?
PostPosted: Tue Feb 24, 2009 2:53 pm
breathtaking stuff- astonishing sharpness and detailing...
but I echo Dave Wooley--how many mines do you need...? :heh:
Regards
Jim Baumann
PostPosted: Tue Feb 24, 2009 4:05 pm
hello jim , Dave,
a full load of mines is about 50 pieces .
Ludwig
Users browsing this forum: No registered users and 34 guests
