It is currently Mon Sep 08, 2025 10:42 am
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri May 24, 2013 9:39 am
Hi, Bernd!
I know , you use the very reliable data abvout the Bismark.
Also I walked around www today- yes, the antimagnetic system can consist of few separate coils - no need in springs around the whole hull.. .
The result: I have to:
- do some additional works with my model;
- say: thank you!
With best regards -
Anatoly
PostPosted: Fri May 24, 2013 11:09 am
Yes, there are Pictures of bs that Show seperate leads in the MES. Also known from tp.
Keep us updated! :thumbs_up_1:
Thanks & Sources: Nilsson (research) and J.Arntz (research, drawings). 3D-Service Jenzsch, 3D Druckerei, HASSLER Profile, ZERO PAINTS, IWATA airbrush, EXCEL blades, Byrnes Model Machines and more
PostPosted: Sat May 25, 2013 1:32 pm
Hallo, friends!
I've made some changes with my Bismarck hull:
- the MES cable was removed to Spt.10,5
-the sterh frames were smoothed a little bit.
With best regards-
Anatoly
PostPosted: Sat May 25, 2013 3:02 pm
:thumbs_up_1:
PostPosted: Sun May 26, 2013 8:29 am
Indeed the stern looks better! My question concerns the base pedestals, these fit into pockets molded or fitted into the bottom of the hull? I haven't decided as to what sort of base to mount my Missouri, though may go with keel blocks and a removable clear case because of dust. Yours looks quite nice and does get around possible issues with a warping base. Here in Alaska the extreme dryness indoors can cause issues with wood.
Regards: Tom
PostPosted: Sun May 26, 2013 9:21 am
Hi, Tom!
There are few ancient photos about my Bismsrck base.
The material of the base is oak.
The only minus of the construction- two big holes in the hull bottom- but they are never seen!
With best regards -
Anatoly
PostPosted: Tue May 28, 2013 12:01 pm
Horisho!
Tom
PostPosted: Thu May 30, 2013 1:38 pm
Hallo, everybody!
Today- a little excursion around the section III.
With best regards-
Anatoly
PostPosted: Thu May 30, 2013 8:33 pm
Nice ! :woo_hoo: :cool_1:
PostPosted: Fri Jun 07, 2013 11:00 am
Hi, friends!
Thanks for the kind replies -I am pleasured, if my work is interesting and helpful !
Today- the sections IV and V are for taste.
Best wishes -
Anatoly.
PostPosted: Fri Jun 14, 2013 10:21 am
Hallo, everybody!
Now- sections VI and VII for your attention.
With best wishes-
Anatoly
PostPosted: Sun Jun 23, 2013 11:16 am
Hello everybody!
Below - a short review of the Section VIII.
With best wishes!
Anatoly
PostPosted: Sun Jun 30, 2013 11:12 am
Hello, everybody!
There are a few pictures -Section IX.
With best wishes-
Anatoly
PostPosted: Mon Jul 01, 2013 2:59 pm
That's an awesome result Anatoliy! Beats any Trumpeter hull no matter how much remodelling it has. Love the rivets etc. on the plating, you have even the tiniest grating! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :woo_hoo:
The merchant shipyard
PostPosted: Mon Jul 01, 2013 7:09 pm
One word... "Spectacular"
A true masterpiece in the making. I eagerly await more.
One thing you never want to hear from the Ammo tech - "Oops"
PostPosted: Tue Jul 02, 2013 9:34 am
Hi, friends!
Thanks for your compliments! They are a good support in my work! :thanks:
With best regards-
Anatoly
PostPosted: Sat Jul 06, 2013 11:52 am
Anatoly,
Where did you find your hull documentation - I've been looking all over the place for hull plating diagrams....
Great job so far!
Take care,
John
PostPosted: Sat Jul 06, 2013 1:16 pm
Hi, John !
To be frankly, I have no exact documents about the hull. I tried to order the plans from Harhaus and even from Blohm&Voss - but without a success. So , I use technical descriptions (for example-
"The Bismarck- the history, the legend and the model"- from Hachette (Russian issue)), the Gally's drawings, the Harhaus 1/100 Bismarck model drawings, lots of books about the ship, and - kindly help from the shipmodellers! For example, lots of information I get from topic "Bismarck 1/100: Reconstruction of the hull" - it is here, in Online Scratchbuild- the autor is 109 (Bernd)- his help was (and is!) really huge.
And, of course, I work with photos..
So, there are lots of improvisations and technical "guesses " in my work- and my work is open for criticism!
With best regards-
Anatoly
PostPosted: Sat Jul 06, 2013 3:19 pm
Hi Anatoly I have been following your build , the attention to detail is truly impressive :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Sun Jul 07, 2013 2:18 am
Hi, Dave!
Thanks for your interest!
In day or two see the next section!
With best wishes -
Anatoly
