It is currently Fri Jun 27, 2025 11:33 pm
Post new topic Reply to topic  [ 252 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 13  Next
PostPosted: Mon Jan 13, 2014 7:06 am
One B%#^y complicated box!
AT
1/72 Arleigh Burke flight iia
http://www.shipmodels.info/mws_forum/viewtopic.php?f=13&t=154767
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 HMAS Perth 1942
Last edited by Perth_shipyard on Mon Jan 13, 2014 12:00 pm, edited 1 time in total.
PostPosted: Mon Jan 13, 2014 11:35 am
Further progress of the forward superstructure. Both of the angled panels forward I cut too short as can be seen, so had to splice in a piece to suit. A pain but should clean up fine.
Ill now need to trim down the forward bulkhead under the bridge windows to finish the basic structure of the bridge, but enough for now.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
Last edited by Perth_shipyard on Mon Jan 13, 2014 11:56 am, edited 1 time in total.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
PostPosted: Mon Jan 13, 2014 1:59 pm
Uh-oh mate, looks like you've exceeded your allotted bandwidth!
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
PostPosted: Mon Jan 13, 2014 2:37 pm
Hi AT,
It might be just me, but I cant see your pics any more?
Andrew
PostPosted: Tue Jan 14, 2014 11:32 pm
Hi Andrew, yeah photobucket wanted me to upgrade something to with the buffer space? Anyway I've upgraded now so hopefully the pics will be viewable again soon.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
PostPosted: Wed Jan 15, 2014 1:55 am
Lets see if photo bucket is behaving now.
More slow progress on the bridge. The windows as well as the angles have slowed things right down, but enjoying every minute still.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
PostPosted: Wed Jan 15, 2014 3:40 am
Looking good :thumbs_up_1: :thumbs_up_1:
Andrew
:wave_1: :wave_1:
PostPosted: Thu Jan 16, 2014 11:53 am
Thanks Andrew :)
After going through two more new scalpel blades the bridge windows are cut out! Something I was really dreading but had to give it a go and I think they've come out ok. A little cleaning and fine filling needed but otherwise....
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
PostPosted: Thu Jan 16, 2014 11:45 pm
The basic forward superstructure is now complete. Now to fill and sand joints.
This has been nearly a week of work just to get the basic box built, but I'm happy with how it's turned out so far. I've also copied Russ French's builders model with having the angled bridge window covers. The Spanish ones don't have them and the hobart herself has yet to have any fitted but most australian warships have these and I just like the extra bit of detail.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
PostPosted: Fri Jan 17, 2014 9:29 pm
That a bit harsh :huh: It a bit more than just a basic box. Good work so far mate. keep it up :thumbs_up_1: :thumbs_up_1:
Andrew
:wave_1: :wave_1:
PostPosted: Sat Jan 18, 2014 12:24 am
Hey Andrew, I meant the basic superstructure as there's no detail etc :) but yeah it's definitely far from a simple box that's for sure. I thought the FFG bridge was a pain, damn easy in comparison! Haha
Have to work tonight but if I'm awake early enough tomorrow I'm hoping to get her first proper run tomorrow with the FBP guys! :D and see if I've wired the motors the right way?!? Haha
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
PostPosted: Sat Jan 18, 2014 12:29 am
That's great AT, have a good day tomorrow :thumbs_up_1: :thumbs_up_1:
Andrew
:wave_1: :wave_1:
PostPosted: Tue Jan 21, 2014 11:56 am
Ok so a small update. Well she runs! The crest motors definitely have some power with the Brissy. I only ran her for 5 mins as I had no steering! After close to an hour trying to figure out what was wrong with her at the lake with Peter and Robert - it definitely showed the steering servo was at fault - it was time to head home plus the heat and both lakes were like pea soup and even Robs PTG was picking up weed. After I got home pulled out the servo and opened it up. One of the wires solders had come off! It was brand new in the box! Anywho. Fixed and tested, I have steering! Woohoo!
I've also decided to replace both of my electronize esc with two blue marine 50amp ESC's, these both have the BEC built in so it'll eliminate the need for an RX power source. As both of the ESC's will be providing power to the RX do I have to remove one of the power wires from one of the ESC RX connections? Don't want to blow up my RX
Also as I have the futaba 6j I've opened that up and inserted a bar over the second stick so both sticks will act as throttle without one springing back, I found it awkward having one with the spring.
Back open, the left stick has the bar, right without and spring attached.
Right stick with bar in place. This was included in the box just not fitted.
Now I can easily position each throttle independently.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
PostPosted: Thu Jan 30, 2014 3:15 am
Just noticed this, they havn't even finished the real thing yet. great work so far, I wouldn't mind an RC ship at some point, have to admit most of what you said about the electronic bits went over my head, will have to learn all about that I think.
Looking forward to seeing this take shape
Cheers Callum
PostPosted: Thu Feb 06, 2014 9:41 am
Not much of an update but Brissy has had her first successful sea trials! No problems what so ever and ran like a dream. Proved to be a very stable platform on the water and there was quite a few gusts which barely effected her performance. There's some talk about adjusting the pitch of her props but she kept up easily with Robs USS Rossevelt Arliegh Burke so might leave it for now.
At the lake - some small detail added to her hull.
More than nine vessels last Sunday, a decent fleet !
Brisbane abreast of Rossevelt with Darwin (FFG) leading
Reversing off her mooring
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
PostPosted: Thu Feb 06, 2014 9:43 am
Cheers Callum
Thanks mate, yeah I know what you mean I've done a lot of learning this past month! It's much easier once you've done it. It all falls into place :)
Exciting news for today as the 1:1 version HMAS Brisbane had her official keel laying ceremony in Adelaide today :)
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
PostPosted: Sat Mar 01, 2014 4:25 am
Well gave in and bought a ubec so have replaced the blue ESC's with my electronize ones and she's running like a dream. Now the running problems are all taken care of I can focus on building again. I have to say I haven't done much at all to her for a few weeks now, waiting for the fittings from Russ and a few bitts and pieces from the states to arrive. Here's a few pics of where she's at now. A little bit of detail added to her starboard hull, eyelets etc and a couple of the cage ladders forward I've made up but yet to be fixed. Have also started to add some detail to the bridge wings.
Brass PE eyelets forward and aft under the helo deck.
One of the many cage ladders on her superstructure. Great items from plastruct. They come with one cage and two lengths of ladders so will have some nice spares.
The forward bridge windows need to come forward so they are flush with the forward bulkhead, I want to remake the side windows etc of the bridge so not too painful to make correct.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
Last edited by Perth_shipyard on Sun Mar 02, 2014 12:04 pm, edited 1 time in total.
PostPosted: Sun Mar 02, 2014 11:29 am
Your builds are awesome .
PostPosted: Sun Mar 23, 2014 1:09 am
Thanks Kevin, hopefully have some more updates on Brisbane over the next week. Now she's running perfectly I can focus on just building her now and fitting her out. I'll start forward and move aft per deck level.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
