It is currently Thu Aug 14, 2025 1:27 pm
Post new topic Reply to topic  [ 288 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 15  Next
 Post subject:
PostPosted: Mon Mar 26, 2007 4:37 pm
Now , at last , I hope Our Admiral will admit I'm cheaper than he is .
I must have taught you to well. :lol_3: :lol_3: :lol_spit_1: :lol_spit_1: :lol_spit_1: Nice build by the way.
Simple but effective.
 Post subject:
PostPosted: Tue Mar 27, 2007 3:09 am
Your rudder-work is marvellous! I like the "fragile" construction and admire your shaft, mine is very simple compared to that and not removable.
Uli "Torpedo" Setzermann
http://www.marine-forum.de - Das Kaiserliche Marineforum
Currently Building: SM TrpBt B-110, SM TrpBt S-37
Upcoming: SMS Derfflinger
 Post subject:
PostPosted: Tue Mar 27, 2007 3:28 am
Very good work Laurent
Jef :wave_1:
Current 1/700 WL
HMS Repulse
 Post subject:
PostPosted: Tue Mar 27, 2007 4:11 am
Hi Laurent Good rudder construction . I note that you are using a brass tiller? Question what type of linkage { material} do you intend to use from the tiller arm then to the servo? I ask this because it is known that using metal to matal can be a source of interference for the R/C. Just a thought?
 Post subject:
PostPosted: Tue Mar 27, 2007 6:42 am
Hi Guys ,
thanks for the comments ... :thumbs_up_1:
@ Dave ,
the rudder will be connected to the rudder arm with a twisted stainless steel rod , steel in contact with brass doesn't create interferences , I think ...
on the other side , at the servo , the connection should be the same , I'll just have to pay attention to the distance between the two connections , that both arms are well swung at 90° , once it is set , it is tight and won't move ...
brass to brass or steel to steel is not good , nothing to do with interferences , but "mechanically" speaking ...
I always did it that way & never have encountered any problems , anyway ... :eyebrows:
Cheerzzzz !
Laurent
 Post subject:
PostPosted: Tue Mar 27, 2007 6:48 am
Looks good!
 Post subject:
PostPosted: Fri Mar 30, 2007 8:00 am
Searching for pictures of german ships I "only" found some interesting photographs of your "Arabis" type:
http://www.iwmcollections.org.uk/qryPhotoImg.asp
(as I can't link: type subject: arabis
perios: first ww and submit)
Here's an example:
Maybe that'll help...
 Post subject:
PostPosted: Fri Mar 30, 2007 3:36 pm
Hallo Uli ,
WOW ! Thanks for that link , the only other link I had found till now was :
http://www.battleships-cruisers.co.uk/naval_sloops_.htm
look what I've found for you , I have no idea if there are useful pictures for you ... :wave_1:
http://www.battleships-cruisers.co.uk/t ... boats1.htm
more general :
http://www.battleships-cruisers.co.uk/german.htm
Schönen dank , auf jeden Fall ! :thumbs_up_1:
Laurent
 Post subject:
PostPosted: Sat Mar 31, 2007 9:38 am
Merci pour le link. These pictures are mostly Reichsmarine and not so important to me. But thanks anyway. Hope the others did help you!
 Post subject:
PostPosted: Sun Apr 08, 2007 12:38 pm
Hi Guys ,
building at a veeeeeryyyyy slow speed those days , a lot of different improvments to do in the house and on the cars :big_grin:
that's no valable excuse , I'm just telling :censored_2: crap , I know ... :eyebrows:
some super detailling , as I saw Uli's model , I couldn't sleep for nights , I decided to do like him :thumbs_up_1: :
the signalling flags locker , situated abaft the pilot house , with a little chart table on it , all this has been made with cardboard , on some pictures , you may seen that the glazing has been glued :
detailling the CO's cabin sliding door , the white unfinished part near & beneath it will be a skylight for the CPO's & PO's mess below , in the door are the two holes for the handle :
I added some railing around the CO's cabin :
That's it for today , I'm going to paint the funnels ( outer skin in grey , inner skin in matt black ) & the under part of the boat's deck tonight ...
Regards ,
Laurent
 Post subject:
PostPosted: Sun Apr 08, 2007 2:28 pm
Who would want to be a Senior Rate on that ship? At least on modern ships the Skipper has to make an effort to ruin your day, here all he has to do is open his door and pee down the skylight. Nuts to that for a game of sailors!
 Post subject:
PostPosted: Sun Apr 08, 2007 3:48 pm
:woo_hoo: The signal flags locker ist amazing and I like the door too!
Keep on Laurent! I haven't done anything since yesterday, hope to get to finish the other rails on the bridge together with the stairs tomorrow. Let's see if I get the time to do it.
 Post subject:
PostPosted: Mon Apr 09, 2007 1:41 am
Excellent! :thumbs_up_1:
 Post subject:
PostPosted: Mon Apr 09, 2007 1:56 am
very effcetive--extra detail brings models to life!
JIM B :thumbs_up_1:
 Post subject:
PostPosted: Tue Apr 17, 2007 4:28 pm
Hi Guys ,
those last days , I worked on the pilot house equipment
first the telemotor ...
as a reference , while surfing on the net , I only could find a decent picture of a telemotor on board Titanic's wreck :
to model that stuff , I used a piece of Evergreen tubing ( 2 mm in outside diameter ) , all the rest , like the casting reinforcements , is in cardboard
I added a 0,3 mm piece of brass rod to represent the piping
I didn't find a steering wheel in the appropriate size , so I did my own .
I tried to do it in brass --> just forget it :big_grin:
self photo-etching is beyond my knowledge --> forget it either
Trying to build that :censored_2: wheel in wood almost caused me several heart attacks --> just forget it again :heh:
I tried to do them in cardboard , and I succeeded ( well , sort of ... ) :woo_hoo:
the compass stand is a white metal part , bought through the net , a while ago , by "Hasse" in Germany...
the pictures :
you noticed the greasy fat under my thumb's nail ( and some scars ) , its not because I'm allergic to soap & water but I fought a battle with my Van's barn doors :mad_1: --> I won :surfer:
See you later !
Laurent
 Post subject:
PostPosted: Wed Apr 18, 2007 3:54 am
Excellent work that looks indeed very good.
I have a compassstand from zinnecker (lead), would you recommend the Hasse part?
 Post subject:
PostPosted: Wed Apr 18, 2007 5:36 am
Hi Uli ,
I should say : order one compass by "Hasse" ( it costs 1 € ) , you'll see the difference ...
I never ordered by Zinnecker , though , so I'm not able to tell you who's better ...
regards ,
Laurent
 Post subject:
PostPosted: Wed Apr 18, 2007 6:31 am
PetrOs Modellbau
PetrOs Modellbau
Hmm, is hasse down now? I cant access it..
Further kits in preparation.
 Post subject:
PostPosted: Wed Apr 18, 2007 8:54 am
Hi Petros ,
they have a stand at "Intermodellbau" , it might be the reason why they don't answer your questions ...
Also , they don't have an online catalogue , you'll have to buy their catalogue ...
Regards ,
Laurent
 Post subject:
PostPosted: Wed Apr 18, 2007 11:24 am
That looks terrific, I can't wait to see the pilot house done.
cron
