It is currently Thu Apr 25, 2024 4:46 am
Post new topic Reply to topic  [ 285 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15  Next
PostPosted: Wed Apr 03, 2013 9:52 pm
i dug out a small dremel lathe and played with lathing a 11 inch/280mm gun for fun and practice.
Shoot till You see the Whites of their tails.
PostPosted: Wed Apr 03, 2013 9:54 pm
i made it a little to big to the diminsions and the pine is a little to course, i need walnut or somthing harder. but it was a first good test.
PostPosted: Thu Apr 04, 2013 3:58 pm
Haratio
Cherry works good .English boxwood is great but expencive .
PostPosted: Mon Apr 08, 2013 6:54 pm
wouldnt it be easier to cast the guns with lead ? ? I have toyed around with plaster of paris and got some decent results , maybe casting the guns with resin is another option theres a lot of options
be inspirational today , you might never get that chance tomorrow
PostPosted: Thu Apr 11, 2013 3:43 am
Lead would make the model a bit top heavy and isn't that healthy at the end, I think. Since resin is much easier to handle, I would give it a try.
Best wishes
Lars
PostPosted: Thu Apr 11, 2013 11:07 am
I plan to resin cast them, I was just seeing what kind of barrol I could lathe out on My Dremal hobby lathe (LOL) this barrol stretched the limit with the length. however I dont think it was to bad for just messing around. I have seen some wood toy kits for sale at the hobby stores and have thought about making wood turrets, and gun sets that wouldn't have to be in super acurate scale and detail, but more like a toy for 6 to 10 year olds. My older brother uses foam insulation sheets and hot knives for projects. I have thought that maybe I could make a simple hull shape, and ballest it, and put the wood guns and structures on top and it could float in a swiming pool. I'm just experimenting with the side ideas till I can fly on teh RC projects again. I have been determining all the WW2 German turret deminsions and drafting them. My older brother is Auto CAD formating them so when I can afford to buy the 3D printer we can produce them, however I think I can make some from othe materials, and resin cast them also, its just more time consuming. Thank You for the imput and interest though, You guys keep me going, because life tries to pull Me away all the time.
PostPosted: Thu Apr 18, 2013 8:37 am
well my friend brought me some white metal a while ago and i mixed it 50 , 50 with lead . I must admit they are pretty strong because we used crackers to make them shoot . Haratio do you maybe have a extra set of 1:144 or 1:100 or 1:72 set of plans there that you would sell ? ? My worst enemy my side is to get plans of models i want to build . I just used the plaster of paris to make a resin mould with and it works great
PostPosted: Mon Apr 22, 2013 12:50 pm
sorry for the late reply D. Which ship would You like? I have the M class in 1/72 scale right now. It would cost about 30 to 50 dollars to mail it to your adress, I won't sell You the plans, as the plans for the M class I obtained from Germany from the originals, so I will give You the plans, I would just appriciate the covering of the Mailing and printing cost. I am acctually Drafting plans for the O class Battle Cruiser, The P class Panzer ship, and the Reconisance Large Destroyer - (Spahkruiser) so I would sell those at a latter Date as they are not finished and still under the pen as though to speak. I also have some line drawing copies of Prinze Eugan, and A Mine Sweeper design that I had obtained from the same source in Germany that I could send after scaling. If You would like the M class in 1/144, or 1/100, let me know. I am looking at posibly making a set in 1/87 scale to match a HO train diorama that a man here is working on. I still have Your adress in SA if it is the same, I just need to do more checking with the Postal Service here to get a beter price check, and have them weigh a Paper Tube container so I will have a better idea of the price. Will let You know, and tell me what You think. Your freind from the Ocean Front in Wyoming. Haratio.
PostPosted: Wed Apr 24, 2013 12:27 am
Hello Haratio, :wave_1:
Long time no hear - Seems like you are creating a whole drafting and casting industry. Very good indeed. Just cannot wait to see more updates on the M- Class cruiser.
Take care.
NEVER RETREAT - NEVER SURRENDER
JUST DO IT YOUR WAY AND NEVER LOOK BACK
PostPosted: Wed Apr 24, 2013 1:43 am
I would suggest the resin casting method for the gun barrels with the addition of using a brass tube for the inner bore of the barrel (that's how APS models does their 1/72 gun barrels...). Your wooden barrel would make an excellent master for making the mold up. :thumbs_up_1: :thumbs_up_1:
Cheers Bruce
building:
1/72 RC USS LONG BEACH CGN9
1/72 RC USS CALIFORNIA CGN36
1/72 RC USS SAIPAN LHA2
1/72 RC USS SHARK SSN591
1/72 RC USS SEAWOLF SSN21
1/72 RC USS ALBANY CG10
PostPosted: Wed Apr 24, 2013 2:31 am
TY Hvy. That is what I was thinking. The brass in the center makes them look more like a real ship gun. I just need a beter lathe, which is in the works. Hello to You also Paul. I have been following along on Your project with great interest. I have been working on an aircraft project, and my Cars in the Yard, and It has kept snowing here up into april, the last to storms we have had have been worse than all winter. I have started working on Styrene CL34 150mm turrets for the Munich. Here are a few pics.
File comment: turret face armor plate. and lower sides.
File comment: Early bismark drawings with correction notes.
File comment: styrene turret floor in 72scale, by resincast K class triple in 100 scale.
File comment: floor on center support on deck print.
PostPosted: Wed Apr 24, 2013 3:32 am
hello haratio my friend , i hope you are well ? ? I would gladly cover your costs for the plans printing and mailing of the kreuzer M , if you can make them 1:100 i would really appreciate it if thats possible , just hit me up with a qoute on dvmetalhead@gmail.com , just include how payment should be done please , i am also looking for a admiral hipper plan thats correct , your friend from the lions kingdom , south africa .
PostPosted: Wed Apr 24, 2013 3:51 am
i can see your model shipyard is busy and the turrets look really good , i can see a masterpiece starting to take shape , well in time i would like to build all the german navy ships or thats what i am aiming for but my main thing is to build ships that were never built but have plans , maybe its just theyre uniqueness that attracts me lol but I must admit you really have an amazing craftmanship hand and a sharp eye , greetings from south africa and may you have smooth oceans my friend
PostPosted: Tue Jun 18, 2013 5:11 am
I built a new workbench on the other side of My living room to further work on the Project.
PostPosted: Tue Jun 18, 2013 5:12 am
next pic
PostPosted: Mon Oct 07, 2013 3:22 pm
I have been working on my workshop and saving money for a Lath, and a 3D resin printer, along with learning the programing to draft CAD to use it. I ordered the first of 4 Laser resin machines and I have about 2 weeks to go and I can go to Denver to pick up a metal lathe. I have about 200 pages wrote about the ship designs for plan Z and am talking to publishing companies to see if I can get it published, but I need to finish writing and make the illustrations for it. take a quick look at the 1/350 Spahkreuzer post I added a couple photo's.
PostPosted: Wed Oct 23, 2013 3:14 pm
Here is a pic of a sample piece made on one of the prototype printers I have ordered.
PostPosted: Wed Jan 01, 2014 9:57 pm
File comment: 105 cm AA gun dual.
File comment: Turret Anton, or the fore most guns on the bow with no range finder.
File comment: angle bow in wire frame.
here is some of the 3D work I have been doing to further the project.
Last edited by Haratio Fales on Wed Jan 01, 2014 10:09 pm, edited 1 time in total.
PostPosted: Wed Jan 01, 2014 10:06 pm
File comment: Turret Bruno, Caesar, or Dora. fore angle in object mode.
File comment: aft 3 turrets in object orthoscopic mode.
File comment: side hull bow in wire frame.
File comment: the fore hull side in object mode.
File comment: A rendered pic without coloring.
a few more.
PostPosted: Tue Jan 21, 2014 3:22 am
new stuff.
Users browsing this forum: No registered users and 58 guests
