It is currently Tue May 13, 2025 11:35 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
PostPosted: Thu Dec 03, 2015 11:41 am
The original, a 348 ft general cargo vessel from Moldova called "Hassan D"
Current:
viewtopic.php?f=13&t=164061
Last edited by HOscalemodeler on Sun Dec 06, 2015 6:06 pm, edited 2 times in total.
PostPosted: Thu Dec 03, 2015 5:43 pm
Early Hull construction
Painted and Decking
Current:
Last edited by HOscalemodeler on Fri Dec 04, 2015 7:05 pm, edited 2 times in total.
PostPosted: Thu Dec 03, 2015 6:42 pm
I'm very new here, still learning how to post pics, to view them so far just copy the link inside the brackets and paste it in the url box
Current:
PostPosted: Thu Dec 03, 2015 11:35 pm
Online
You need to upload them onto an internet server first. Right now, the links you provided are the addresses for the photos on your computer, which we can't access.
Please follow one of the two methods outlined here for photo-posting instructions: viewtopic.php?f=12&t=1261
PostPosted: Fri Dec 04, 2015 5:16 pm
this is my first big ship model and my first that is not a kit, so perfection is far away
Superstructure started
Crane platforms
More to come
Current:
Last edited by HOscalemodeler on Fri Dec 04, 2015 7:09 pm, edited 1 time in total.
PostPosted: Fri Dec 04, 2015 5:35 pm
More superstructure progress
Details
Bollards
Obviously these updates are not posted has I build it, I am very far along with this build so I'll bring you up to speed
This is pretty much how to ship looks as of the time of this post:
Current:
Last edited by HOscalemodeler on Fri Dec 04, 2015 7:15 pm, edited 1 time in total.
PostPosted: Fri Dec 04, 2015 6:52 pm
Anchor windlasses all put together and another view in better light
Another update soon
Current:
PostPosted: Sun Dec 06, 2015 8:30 am
Okay, my first real-time update
The way a lifeboat begins
After shaping, sanding and first paint layer, still much to do with them
Bulkheads completed
A few minor details have been added like exhaust stacks
Current:
PostPosted: Sun Dec 06, 2015 1:09 pm
That's an ambitiously-sized model! :thumbs_up_1: But why have you painted and decorated parts that still need work, like levelling, filling, smoothing, etc. ? Is it for an HO scale RR? :wave_1:
PostPosted: Sun Dec 06, 2015 3:36 pm
biggles, as I said, this is my first model that is not a kit, so I still am learning techniques and methods :big_grin:
what did you notice needs filling and smoothing? maybe I can fix it!
I plan to make it a seafaring ship, but it will probably have a place on my HO railroad
Current:
PostPosted: Sun Dec 06, 2015 3:56 pm
[/quote]
Well, the hull seems to have an uneven-ness, or depression, in areas, especially on port side. The sections and walls of the bridge and superstructure could use some trimming to even up sides, and filling of joints, etc. But that's just me! :wave_1:
PostPosted: Sun Dec 06, 2015 4:13 pm
biggles,
the hull, I did notice that it is uneven in several places, I think a paper mache construction was not the wisest decision
Next time, I will choose fiberglass as I plan larger models in the future...
as for the bridge and superstructure, this was my first time working with styrene (I am a true newb!)
so imperfections are frequent
what could I use as a filler? milliput?
Ive been working on it a lot today, many details are being added
Current:
PostPosted: Sun Dec 06, 2015 6:02 pm
Update, I started on railings which I initially thought I would 3d print, but I found this material called hardware cloth which I found I could make many things out of like railings, ladders, and other stuff
Hardware cloth
Installed some details on the cranes before painting
Painted details (tape holds the ladder on while drying)
Railings dry fitted before painting set on the superstructure
Lifeboats with 4 coats ready for details
Current:
PostPosted: Sun Dec 06, 2015 8:30 pm
When I was a kid in the 50's I remember an article about building the Savanna in Popular Science, suing water glass and News paper. Could you tell me a bit about how you built the hull? over a form?
Cheers. Tom
PostPosted: Mon Dec 07, 2015 11:43 am
Didn't know you made the hull of papier-mache - good job! Filling and patching could be awkward to impossible at this stage. Maybe on your next project? :wave_1:
PostPosted: Mon Dec 07, 2015 4:59 pm
Fliger, I just read an article about the Savanna in Soundings, sort of a sad story
Anyway, the hull is 12 coats of paper mache (I make it with water, flour, and salt) over a stacked cardboard frame. Sanded in between every two coats, then 10 coats of colonial red rustoleum
Soon I will put one layer of fiberglass resin over it as a waterproof sealant
biggles, yes the hull is paper mache (I wouldn't recommend it!)
I think I'll switch to fiberglass over a foam frame for the next model, (thinking a much, much bigger one)
Another update soon
Current:
PostPosted: Tue Dec 08, 2015 6:41 pm
A small update, I made the lifeboat cranes and finished the lifeboats themselves
Lifeboat
Cranes drying
Cables to hold down antennas
Current:
PostPosted: Wed Dec 09, 2015 7:59 pm
Another small update
I attached the lifeboats to the cranes and mounted them on the ship, next time the railings will be painted and glued on
Current:
PostPosted: Sat Dec 12, 2015 1:44 pm
Another little update, I painted the railings for the cranes and superstructure and attached them
A glimpse of the Hassan D's first cargo
Current:
PostPosted: Sun Dec 13, 2015 8:10 pm
I took the ship outside today for some better pics, added the depth markings using dry transfer decals and made a few exhaust details
Comparison
Front
Superstructure looks better in light
Current:
Users browsing this forum: No registered users and 29 guests
