It is currently Tue May 13, 2025 11:44 am
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Mon Sep 12, 2016 10:21 am
I bought a couple of Revell's Snowberry and, of course, was not satisfied with them so I started converting one of them to an early Canadian short-forecastle version. I'm building mine after HMCS Kamsack - short forecastle, early bridge style, and two masts.
This is how she looked in 1942 and how I plan on building her.
Some of the general short forcastle plans I'm working from:
And some cutting work - guess I'm committed now!
I cut back the bulwarks and added detail on the insides. Also opened the scuppers and added a few more. I also cut the original forecastle deck to recycle as much kit parts as possible. It also had some good detail difficult to scratch.
I was temporarily out of scribed styrene for the decking so I started work on the gun and shield:
I used some 1/350 railing bits for the railing on the side and top, and some brass wire for the canvass frame on the rear. Rounded off the front shield and the rear bottom, and sanded off the gunsight aperture covers and made new ones with plastic sheet, and added a flange around the gun aperture. Also added some interior, including training and elevating handwheels which are not visible!
Comments, criticisms, replies welcome. :wave_1:
PostPosted: Mon Sep 12, 2016 10:25 am
A couple of days have passed and I made a new forecastle deck:
Some gaps here and there as nothing is glued together yet.
:wave_1:
PostPosted: Mon Sep 12, 2016 2:42 pm
Online
Excellent subject choice! Try to get a copy of Lynch's "Canada's Flowers" for drawings of the 2-masted short forecastle superstructure decks. I did the same conversion from ISW's 1/350 kit: viewtopic.php?f=59&t=93807&#p466458
PostPosted: Mon Sep 12, 2016 3:15 pm
I have Lynch's book as well as the one by Lambert. That's where I'm getting all my info from. Would have preferred to build an early (as built) Sackville, but I can't find any relevant pics or info. No two corvettes, even from the same series and ship yard, were identical, and it's these small differences that are problematic. I saw that your Sackville is pretty well identical to what I've done so far so maybe I can still make a Sackville out of it. I notice in your pics you have no armament in the bandstand. Did Sackville not have a gun there at that point? Maybe the two twin Lewis guns? :wave_1:
PostPosted: Mon Sep 12, 2016 4:08 pm
Online
Chambly (the one I built) did not have a weapon at that time - there was a severe shortage of weaponry in that early period, and I couldn't find evidence for anything fitted there.
You might also check out the Anatomy of the Ship Agassiz book.
PostPosted: Tue Sep 13, 2016 10:18 am
Some more work done on the superstructure - the wheelhouse and compass house:
More pics as things get done. :wave_1:
PostPosted: Wed Sep 14, 2016 10:27 am
Great start! Can't wait to see more.
John
PostPosted: Wed Sep 14, 2016 8:00 pm
Excellent project! Started a similarly ambitious build of the 1/72 Matchbox/Revel kit some years ago, but alas it sits on the shelf of doom gathering dust.
Keep the posts coming.
Keith
PostPosted: Thu Sep 15, 2016 12:38 pm
Hey guys. Did a little more work. Roughed in the aft superstructure and the casing, and worked on some detail parts. I built the searchlight platform, but I'm not sure yet if I will use it on this particular ship, but if I change the ship I'm building I'll have that part. I was originally going with HMCS Kamsack because I liked her appearance, especially with the very early two masts. Then I considered that HMCS Sackville is more iconic, seeing she is the only remaining corvette, and undergoing restoration. Sackville had the raised searchlight platform, but was not built with two masts. Sometimes I become obsessed with details and get bogged down. So it's probably back to Kamsack, or Wetaskiwin ("Wet Ass Queen") just because I like the name :big_grin:
White plastic is the scratch built parts. I'm saving as much of the original kit parts as possible.
More pics later. :wave_1:
PostPosted: Fri Sep 16, 2016 2:02 am
Great job so far. Amazing what you can do with a little bit of wire when it comes to detailing. Great execution of that detailing as well. Very sharp turns and fitting with that wire on the cannon, even on close-up pics! :thumbs_up_1: :thumbs_up_1:
The merchant shipyard
PostPosted: Sat Sep 17, 2016 5:59 pm
After a few days work I came up with this:
This is the steam-powered winch for mine sweeping gear. Took almost three days to scratch build out of some bits from the spares box, and a lot of Evergreen, brass wire, and stretched sprue. I didn't count, but I estimate it has 80 - 100 separate parts and bits to it.
And here's what it's for:
From sprue
to paravane
Made of scrap sprue (very handy to keep), some Evergreen, and lead foil.
More photos when things get done! :wave_1:
PostPosted: Sat Sep 17, 2016 6:05 pm
Online
Super impressive!
PostPosted: Fri Sep 23, 2016 6:04 pm
Bit of an update for all those interested. It's starting to look more like Wetaskiwin and less like Snowberry. After some more research I found that Wetaskiwin didn't have planking on the forecastle deck, so away with the original part I was saving and on with a new deck:
Put boat decks on and did some detailing on the boats. Unfortunately, Revell molded the boats' hulls like they were fiberglass instead of clinker construction - no overlapping plank detail.
Did some work on the bandstand and made a new thinner splintershield, and added support struts as well as assembling the pom-pom and adding bits and spare PE:
I also replaced the cone shaped flash hider on the gun as the molded one was slightly mis-shapen and was solid. I used a trick from aircraft modellers who scratch their own pitot tubes - they take plastic tubing and stretch it, like stretching sprue. The result is long tapering tubes. I used the wide end of the stretched section and glued it in place. No need to drill out the muzzle as the hole is still there.
Scratched the mine sweeping gear davits. Mostly Evergreen styrene and bits of PE:
Most importantly, I flattened the stern hull, as corvettes fitted with the mine sweeping gear had this feature. This was the tricky part as I had already assembled the hull and I didn't want to cut it up and replace the stern. I carefully heated the stern with my hot knife and when the plastic became a little soft, I pressed the stern down on my table to get that flattened look. Then repositioned the depth charge openings and filled the original ones:
So this is how Wetaskiwin looks now with mainmast:
More pics as stuff gets done. :wave_1:
PostPosted: Sat Sep 24, 2016 1:08 am
Been watching this thread and gotta say, this is looking like a top-notch conversion job. Keep up the excellent work!
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
PostPosted: Sat Sep 24, 2016 1:55 am
Fantastic. Excellent attention to detail
PostPosted: Sat Sep 24, 2016 4:17 am
Very nice! The scratch-built stuffs are so good! Ah when will I be able to make it as good as yours! :(
Aop
On the way:
And our artworks!
PostPosted: Sat Sep 24, 2016 7:02 pm
That is great work,Biggles. :thumbs_up_1:
Scott
K494 HMCS Arnprior
Royal Canadian Navy
PostPosted: Sat Sep 24, 2016 7:18 pm
Awww guys. You're making me blush! :big_grin:
PostPosted: Sun Sep 25, 2016 5:47 pm
Some close-up shots of the pom-pom and Mk.ll depth charge thrower. I thinned the shield of the gun as it looked like armor plate! Added some bits and sacrificed the gun sights of a perfectly good set of 1/350 twin Bofors kit. And there's that new muzzle flash hider made from stretched Evergreen tubing:
And the depth charge throwers: they weren't bad, but the mount and base were simplified into a single blob. I made it look more like the steel girders and angles, and wood block it's supposed to be:
Mor pics as things get done. :wave_1:
Users browsing this forum: No registered users and 33 guests
