It is currently Wed Apr 24, 2024 3:46 am
 Post subject: A Egyptian ship
PostPosted: Tue Oct 03, 2017 4:53 am
Hey everybody.i built a Egyptian boat last year and well... I need a bit of help.i don't know what to do.i can't really change it into a rc boat at all.i don't have any electrics to power it.and even worse.its beginning to disintegrate.since I don't know how to put photos up on this website il explain the damaged bits of it.first,the sail and mast.its not on it.it broke off 3 months ago.then the sides(or hull whatever you call it).the tops of it are nearly going to snap.the remaining hull is alright but those two are wrecked and destroyed or going to break.the kneel is alright and the cloth(attached to the kneels structure)is alright as well.post me how to post pics of it and il show you it.and also help me try and fix her rope(the mast and sail are long gone)
 Post subject: Re: A Egyptian ship
PostPosted: Wed Oct 04, 2017 1:26 am
Pictures must be 1200x1200 pixels or less, and the file size must be 150 kbytes or less.
You can use the Windows MSPAINT program to resize images.
To add the pictures to a post just use the "Filename" and "Browse" areas below the message window while you are composing your post.
Browse to the folder containing the image and select it. Then click "Add the file."
PostPosted: Thu Oct 05, 2017 2:08 pm
Don't have a mspaint sorry
PostPosted: Fri Oct 06, 2017 8:13 am
You can do the same in GIMP.
PostPosted: Sat Oct 07, 2017 1:21 am
If you have Windows you have MSPAINT.
C:\Windows\System32\mspaint.exe
Users browsing this forum: No registered users and 37 guests
