It is currently Sun May 11, 2025 11:06 pm
PostPosted: Wed Dec 13, 2017 9:40 am
Hello folks,
my dad and I are building the ORP Orkan together. Since we both are beginners in this area, we hope to get some tips, tricks and information if needed. The current state is seen in the attached photo below:
Constructive criticism is always well-received.
Greetings
Allan (son) and Adam (dad)
:big_grin:
Work in progress:
1:72 - Class Hunt II (ORP Kujawiak)
1:72 - Class M (ORP Orkan)
1:72 - Class T-13
1:72 - Class T-22
1:72 - Class Z-32
1:72 - HMS Grey Goose
1:72 - PC-553
PostPosted: Sun Dec 17, 2017 8:16 am
Since we can't laminate in winter, we are working on details now.
Greetings
Work in progress:
1:72 - Class T-13
1:72 - Class T-22
1:72 - Class Z-32
1:72 - PC-553
PostPosted: Sun Dec 17, 2017 11:43 pm
Looks fantastic with nice clean lines - I look forward to your progress. How did you make the hull, if I may ask, cheers Will
PostPosted: Tue Dec 19, 2017 3:36 am
Hello Will,
thanks for the compliment.
The hull was made using two methods:
The main part (middle) was made using rib cage created with a laser-cutter.
The bow and astern are made with a milling machine. Smaller hulls (ex. Grey Goose and PC-553) are completely CNC milled.
We will add another thread for the smaller ones later as well.
Greetings
Work in progress:
1:72 - Class T-13
1:72 - Class T-22
1:72 - Class Z-32
1:72 - PC-553
PostPosted: Mon Mar 12, 2018 5:55 am
Hello everyone,
after a short winter break we are working on some details.
Work in progress:
1:72 - Class T-13
1:72 - Class T-22
1:72 - Class Z-32
1:72 - PC-553
PostPosted: Thu Mar 15, 2018 8:37 am
I had to look up the Orkan.
https://en.wikipedia.org/wiki/ORP_Orkan_(G90)
https://uboat.net/allies/merchants/ship/3100.html
Looks like you're going to need secondary armaments. 3D Boats on Shapeways should be able to hook you up -
1 × quadruple QF 2-pdr (40 mm) Mk VIII AA guns
https://www.shapeways.com/product/KCJL4 ... d=59816807
2 × single Oerlikon 20 mm (0.8 in) AA guns
https://www.shapeways.com/product/P4W5A ... d=57169489
or
https://www.shapeways.com/product/7WY7J ... d=60206230
2 × quadruple, 2 × twin 0.5 in (12.7 mm) Vickers Mark III anti-aircraft machineguns
https://www.shapeways.com/product/UBQ9H ... d=42202884 <- quads here, not sure if he does .5 Vickers twins but if you show him this thread/tell him what you're up to I'm thinking he'd cobble up something for you.
Current build logs -
1/72 110' Subchasers as Rum Runners
1/96 Japanese 'Steel Truck'
1/96 12cm pre-Dreadnaught deck gun
1/124 CS Privateer 'Beauregard'
1/124 CS Blockade Runners Pevensey & Ella Warley
1/192 scale whaler PEQUOD
PostPosted: Fri Mar 16, 2018 4:29 am
Again, crisp clean lines, very nice - I will have to start measuring up to your standards, cheers, Will
