It is currently Tue Apr 16, 2024 9:19 am
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Tue Jun 11, 2019 10:55 am
Another handsome ship !
I've tried to build the hull using styrene frames, but the central one was to thin (0,75 mm) and the hull was warped !
I returned to my usual method : solid wood
PostPosted: Tue Oct 22, 2019 10:56 am
I finished the hull and turrets. I was not very busy
PostPosted: Tue Oct 22, 2019 11:04 am
wow, nice building here :thumbs_up_1: :thumbs_up_1:
PostPosted: Sat Nov 16, 2019 10:40 am
The tower is finished : wood turned on a lathe and photoetch
File comment: Dry fit of all the parts I already made
PostPosted: Tue Nov 19, 2019 6:29 pm
A very nice Cruiser, the Italian ships were designed before such ships were overgrown with small and medium AA. The possess the clean lines of say, HMS Hood.
A fun scale to work in. I many years ago I built a USN DE (Whitehurst) in thins scale, with only a ruler, a knife and a pair of pliers, from styrene sheet. My 1:192 Alaska came out very nice, waterline like yours, of styrene sheet, by having a base sheet screwed to the build base.
Keep up the nice work! Tom
PostPosted: Wed Jan 15, 2020 12:12 pm
I made the catapult with photoetch.
The gratings are photoetch too, painted with Humbrol radome tan.
The funnel caps where vacuum formed
File comment: The different directors
PostPosted: Sun Jan 19, 2020 11:52 am
Definately good looking. I'm also a fan of such "crude" ships, without all the clutter of AA and radars etc. Love the techniques you're using, did you make that PE yourself?
Vacuum form worked splendidly as well. You don't see it used so much, apart perhaps for lifeboats, but it worked for these funnel caps for sure! :heh:
The merchant shipyard
PostPosted: Sun Jan 19, 2020 12:49 pm
Thank you Neptune !
yes I made my own photoetch .
I'll make the boats with vacuum forming, with this method you can make thin curved funnel caps. And you just need a hair dryer !
PostPosted: Wed Apr 01, 2020 11:50 am
I've finished the 100mm guns (20 parts each) using custom photo etch, styrene and albion alloys tubes.
Finally, to raise my morale, I put on the ship all the parts aleady made.
PostPosted: Mon Nov 02, 2020 8:29 am
I'm terribly slow, but it's taking shape
PostPosted: Sun Jan 10, 2021 11:56 am
Finished at last
PostPosted: Tue Jan 12, 2021 2:29 am
I don't know that I have seen too many ships in 1:500, but in some ways possibly a good scale. You can still work in decent detail such as you have. I made my Whitehurst railings from wire stanchions and human hair and they look very good!
It's not a race to complete, slow is good!
PostPosted: Tue Jan 12, 2021 12:26 pm
Very finely built model of a handsome ship! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Tue Jan 12, 2021 5:29 pm
Excellent work, there!
It's funny, really; the Italians sure knew how to build sexy ships...it's such a shame the weapons they had to put on them were almost all crap.
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
PostPosted: Tue Jan 12, 2021 9:05 pm
I don't know that the Italian Naval Rifles were crap. The 15" rifles of Roma et al. had very good velocity and range. What the regs marina lacked was OIL to leave port and drip, drill, drill. Much like the vaunted IJN of early WWII, hard to keep any edge at all swinging at anchor as the war wore on.
Cruisers were always mixed bag protection wise. HMAS Sydney was sunk with all hands by the raider Kormoran off the West Coast of Australia. Except for the Atlanta's The only major difference between US heavy and Lights was counting the number of turrets and the frequency and size of the arriving splashes.
Lacking the huge small AA complement, a very clean and pleasing design was possible in the gist of interwar ships such as Hood.
Keep up the good work, a really lovely model of sleek ship!
PostPosted: Wed Jan 13, 2021 2:34 pm
Agreed - I think the issues with the cruisers' gunnery were more related to the mountings - specifically, use of a single cradle for multiple guns. The Kirovs were similarly notorious in this regard.
The later Condottieri groups, the heavy cruisers and the Littorio class were all extremely handsome vessels with very appealing lines. This model does them justice :-)
PostPosted: Wed Jan 13, 2021 6:06 pm
Thank you all! I now wonder what's next, either a steam cargo or the most handsome Italian cruiser : Bolzano
File comment: Jacques Schiaffino pictured in front of my house
File comment: Bolzano
PostPosted: Mon Jan 18, 2021 3:44 am
USN had similar issues with early interwar Heavy Cruisers and some Battleships with the multi mountings in a common sleeve causing salvo dispersion. Even with separate mountings a millisecond delay between firings unproved accuracy a lot.
PostPosted: Mon Jan 18, 2021 9:59 am
Same problem occured with the french 330mm and 380mm
