1/192 USS Missouri BB-63, 1945
Post by ModelMonkey »
June 2003 the model looked like this:
I decided to create masters and cast my own 5-inch mounts. My resin mounts were later improved by incorporating the gun captain's blast hood and replacing the resin barrels with brass barrels. I also mastered and cast Mk-37 Directors in resin. [Edit: all of the resin parts you see here have since been replaced with much more accurate and much better detailed 3D-printed parts of my own design.]
Much of the brass, but not all, comes from Gold Medal Models.
1/192 USS Missouri BB-63 (1945) - scratch
Scratchbuilding USS Missouri BB-63, 1945, in 1/192nd scale.
Here are some in-progress photos of my scratch-built USS Missouri, 1945
Scale: 1/192 (1/16-inch = 1 foot)
Length: 55-1/2 inches (140.97 cm)
Plans: US Navy Booklet of General Plans from Floating Drydock
Photoetch: Gold Medal Models
Note: this model is NOT be being built from the vintage Sterling kit.
This model was my first entirely scratch-built model built from plans obtained from
the Floating Drydock.
Humble beginnings. I began building the superstructure in February, 2002
while deployed to Kandahar, Afghanistan using plans from Floating Drydock
(I retired from the Army in 2006). After returning home and being reassigned
to West Point in June, 2002, I began framing the hull and casting turrets.
Model Monkey at work, Christmas 2002.  The turrets, Mk-37 Directors, oxygen and acetylene bottles and bulkhead-mounted draped fire hoses are resin parts cast from my own styrene masters.
Roughing out of major structures.  You can see that the hull is skinned <br />with balsa sheet glued to a frame made from 1/8&quot; thick plywood.  The <br />masking tape temporarily held the skin in place while the carpenters glue <br />hardened.  The hull was later covered with fiberglass for strength, sanded <br />smooth then primed with automotive gray primer.
with balsa sheet glued to a frame made from 1/8" thick plywood. The
The superstructure is Evergreen styrene sheet and strip.  The main deck is <br />made from 1/8&quot; plywood covered with Evergreen V-grooved styrene sheet <br />to replicate the wood planking.
made from 1/8" plywood covered with Evergreen V-grooved styrene sheet
Size comparison of an in-progress Tamiya 1/350 Missouri and the in-progress 1/192nd scale Missouri.
Toms Modelworks photo-etch water tight doors are gems.
Foot rung installation. Installing foot rungs on the fire control towers is very tedious! Each rung is brass, bent to shape, then installed into two tiny holes hand-drilled with a pin vice.
Next steps:
New coat of Deck Blue 20-B
Reinstall photo-etch brass rails and ladders
Cast improved oxygen and acetylene bottles and install them
Build and install the 40mm Quadruple Bofors mounts
Mark the Bofors and their respective tubs with numbers (1,2,3...)
Install propellers and prop shafts
Build and install 20mm Oerlikons.
Finish detailing the masts
Aft funnel nearly complete.
The rungs are basically u-shaped brass bits that are included in the exceptional John R Haynes photo-etch Bofors tub. They just need one bend to get into the right 3-D shape.  I used the rung pattern as shown in Floating Drydock's USS Missouri Plans Book.  It seems the pattern changed after the TDY jammer was installed in 1945.  The new path curves around the TDY Jammer platform.
Auxiliary conning station.  Footrungs compared to a standard-sized staple.
GMM photo-etch brass set being installed. The stanchions on the Main Deck and on portions of the first superstructure deck are individually cut brass H-column sections made by K&S. Tedious to cut and install but they have the right three-dimensional look. She's nearly ready for paint.
Turrets, gun mounts and painting essentially complete but before most details were installed.
The resin 16-inch barrels shown were later replaced by CNC lathe-turned brass barrels made by the late Steve Nuttall - he was a great modeler and friend and I miss him.
Installation of 36" Searchlights, Target Designators and other details.
Curtis SC-1 Seahawk.
36&quot; searchlights complete with bulb.
36" searchlights complete with bulb.
The target designators are the white objects near the armored conning tower.
Greg W
Post by Greg W »
looks great Steve. :thumbs_up_1: Greg W
Dino Carancini
Post by Dino Carancini »
Awesome Steve a huge beauty!
Dino
Post by Dave Wooley »
Steve what a stunning piece of work . The results speak for themselves . :thumbs_up_1: :thumbs_up_1: :wave_1:
J. Soca
Post by J. Soca »
WOW, it looks FANTASTIC.
Steve Sobieralski
Post by Steve Sobieralski »
Beautiful work Steve. I have an 1/192 Iowa Class Scale Shipyards hull and a Don Pruel Baltimore hull that I hope to build someday. Are you marketing your fittings at all?
Dave Wooley-Finally got your book the other day from Amazon and am really enjoying it.
Steve Sobieralski
Tampa Bay Ship Model Society
Laurent
Post by Laurent »
Looks fantastic , indeed :thumbs_up_1:
Regards ,
Laurent
Thanks again, gentlemen!
Yes, Steve, all turrets and fittings are available. Good luck with your builds!
Like you, I also intend to make a 1/192 Baltimore, USS Saint Paul actually, but after USS Saratoga CV-3.
Here's where the inspiration came to build Missouri:
Here are some photos I took of the official
USS Missouri builders model as it appeared
at the Smithsonian Museum of American History
in Washington DC in 1987.
The model now rests at the Navy Museum, Washington Navy Yard
in Washington DC.
Scale: 1/48
Length: 19 feet (228 inches -or- 5.79 meters)
The model was built by Gibbs and Cox Company in New York and
delivered to the Navy on 22 January 1951. See here for more
information about the model: http://www.dt.navy.mil/cnsm/show_01.html
The detail is superb. Her paint scheme is rather unusual in that she is
Haze Gray overall with very dark gray decks and interior splinter shields.
Jefgte
Post by Jefgte »
:woo_hoo: :woo_hoo: :woo_hoo:
Superb !!!
Fantastic work
Jef :wave_1:
Current 1/700 WL
HMS Repulse
Post by Guest »
Steve Larsen wrote: Here's where the inspiration came to build Missouri:
I first saw the model in the Smithsonian in 1967 at the age of 17. Previously, at the age of 10, I had seen the 1/48 builder's model of the USS California at the San Francisco Maritime Museum. I blame my exposure to these two models for my incurable case of BSD (big scale disease).
Steve Sobieralski
Post by Guest »
Nice work.
J. Soca
Post by J. Soca »
Cool!!!!!! :thumbs_up_1:
U.S.M.C.
Post by U.S.M.C. »
My favorite battleship!! Great job!
nick
Post by nick »
Amazing!!
:thumbs_up_1:
Nick
Nichol Caballero
Mike Reading
Re: 1/192 USS Missouri BB-63, 1945
Post by Mike Reading »
Just found your web site, so dare say that by now your model is near complete, if not finished.
It looks excellent.
During the last 10 years or so I have been building, entirely from scratch, a 1:600 scale, waterline model of Missouri depicting her in her first commission.
It's a really challenging ship to model - thank goodness there are a decent set of plans of her and a goodly number of photos.
Good luck
Michael Reading
from East Sussex
England
