It is currently Tue Apr 16, 2024 4:16 am
 Post subject: K class destroyer build
PostPosted: Fri Dec 27, 2019 7:47 am
:woo_hoo: Good morning. I have been building H.M.S Kashmir for a number of years, there is much work done, the hull is still in basic form, b/b construction but fully carved and shaped. All the superstructure assembly's are well advanced, all from plasticard tube and strip, most as yet unpainted, I would estimate probably at 70 % complete for whole project.
The plans used are from David Mc Gregor plans, London, at 1/96 scale. I have doubled these up tp1/48 which gives plenty of scope for detail, there are also drawings from John Lambert, Bedford.
My intention had been to use the wood hull as a former and use tinplate to follow the plating plan, so the hull has no decking at this time.
As I am now 77, and eyesight not as good, the detail work would be difficult, hence the hope of passing the project on.
I am based at Rushmere, near Lowestoft, Colin...
PostPosted: Mon Oct 26, 2020 7:48 am
How are you coming with the K class destroyer ? I like the subject . I am also working on a K-class . My wife's name is Kimberly so I am working on HMS Kimberley in 1/96 scale .
Richard
