USS Whitehurst was a Buckley class TE Destroyer Escort, one hull number lower than the famous England and built side by side in San Fransisco at the same time. Due to war time "supply chain" issues, the DE's featured a variety of power plants. The TE's used steam plants and turbines to drive generators and electric motors, avoiding the bottleneck of reduction gearing. For anti sub work the responsiveness of such a power plant greatly enhanced maneuverability.
Accumulating information, received the Al Ross AOS book on England, from England, have the movie "Enemy Below", filmed aboard her in 1957, ordered the TFD plans disk etc. I discovered the AOS hull lines are seriously in error for the stern, after I made a 3D model and it was apparent the stern was far too narrow, Awaiting further information, but constructed a hull using the waterlines for the aft section.
The transom should be about 65% of the hull beam, not 55% as seen here.
A series of Chitubox images of my 1:500 test hull.
The program I am using is capable of many things, ship hulls is not one of them so considerable legerdemain is required to get a hull that may need minor filling and sanding.
Scale? I dunnoh, maybe 1:144, 1:120? Era? I dunnoh? I drilled on this ship in the mid 60's when she was a Reserve training ship based at Pier 91 in Seattle , but WWII might be interesting. She did sink a submarine off leyte, shot down a number of aircraft, and like England, took a kamikaze off Okinawa. her damage, though less than England was handled at Pearl Harbour where her torpedo tubes were removed and large cable reels were added, allowing use as a floating power plant.
The Submarine Bugara which I have been aboard for sound tests and Whitehurst collided in Hawaiian waters when Bugara was surfacing and both met their end nearby off the Washington coast, Whitehurst sunk as a target and Bugara foundering under tow.
Don't expect quick progress here!
