It is currently Mon Feb 19, 2018 8:40 am
Post new topic Reply to topic  [ 1366 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 69  Next
 Post subject: Re: Bismarck 1/100
PostPosted: Fri Jan 15, 2010 2:37 pm
File comment: finished and unfinished platform
File comment: KGV in cleaning dock work
File comment: adding braces
:smallsmile:
PostPosted: Fri Jan 15, 2010 2:51 pm
Norbert "magnificent workmanship"
You attention to the fine detail on the range finder and radar mattress is inspiring. I do like the work around the funnel casing particularly around the ventilator panels this is superb. Both Russ and yourself are working on similar areas of the ship, armoured tower /bridge platforms and are both taking scratch building in styrene to very fine level . It's a true delight to see and appriciate . Like Russ I am also interested to see the type of tools you use . We can compare notes on this one.
Dave Wooley :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Fri Jan 15, 2010 2:59 pm
Superb workmanship as always!
I was wondering on picture 06930 about the funnel diagram underneath the plastic. Did you develop this yourself? I am struggling to interpret the plans I have and this drawing seems to be highly detailed for the builder.
Thank you.
PostPosted: Fri Jan 15, 2010 3:05 pm
Hi Dave, thank you so very much the comments and kind words.
the range finder still not complete. i need to insert some metal bars(very fine and delicate) but as i say stillnot have a good soldering station(i need purchase some one urgent) so this range antenae is epoxy glued minus the tripod mast i soldering(soft) and work with file to "lapidate" the soldering joint. i need to do soldering work as you do. too is very inspirating for me. Russ is doing a very good model and work as you are doing in your magnificent Kiev.
my tools are basic i think but i am take one picture to show it. i use pliers, cutters, wetdry sandpaper(many grits), dremel,etc... i am take one picture and show my specially tool i have is a circular saw motorized - wonderfull machine to cut tubes(plastic or metal) in angles too.
i would like again to thank you about the encouragment you give for all modellers(includes me) cause to do a ship model
is not easy in many aspects - psicologic too and encouragment is the best "tool" for us and U2.
Many regards my friend
sincerely
Norberto :wave_1: :thumbs_up_1:
PostPosted: Mon Jan 18, 2010 12:37 pm
Hi sgtmac
yes this part is a engineering of my shipyard to built it.
i make some calculations and drawings who don't have in your plan.
if you having some problem t solve it please let me know about :thumbs_up_1:
PostPosted: Fri Jan 22, 2010 11:24 am
hello norberto,great work on the funnel and range finders,i see a ladder on the inside of the funnel.that is going above and beyond :big_grin: .your styrene work is superb,all cuts clean and glued together straight :thumbs_up_1: .you and dave and bill are setting the ladder higher and higher,i am trying to keep up :smallsmile:
PostPosted: Fri Jan 22, 2010 11:56 am
Hi Russ good hear from you.....
yes i don't know if having ladder inside or no.
i think yes for inspection but where i don't know so i add on e effect using the ladder..
thank you so much i am inspired with your jobs too and Dave, Bill, and many others good modellers here... :thumbs_up_1: :thumbs_up_1: :wave_1:
PostPosted: Wed Jan 27, 2010 10:12 am
File comment: the tools i am using part one
File comment: my magic box
File comment: another part of tools - this saw is very usefull
Hallo all i am posting the pics Dave Wooley and Russ Clark (as promised) about some tools i am using.
i don't have specials tools as a lathe or milling machine( i liked this but...) so i am have some specials
tools to do my boat
i am showing in the pics :cool_2:
PostPosted: Wed Jan 27, 2010 10:14 am
File comment: a close up
File comment: this saw cut in angles too
File comment: the proportional disc - very usefull to calculate measures - this is hard to find here actually
:big_grin:
PostPosted: Wed Jan 27, 2010 10:19 am
File comment: marking the holes to the circular finishes od funnel
File comment: the base of hood
some works in the funnel's hood - acomodation of the hood base
PostPosted: Wed Jan 27, 2010 10:22 am
:wave_1:
until next
File comment: if you don;t have a cutter or have some problems with the tools sometimes you can use this to make a perfect circular disc - and use low speed - befor mark with a compass...... and i use a wetdry paper
File comment: discs to dome components - still in construction
PostPosted: Wed Jan 27, 2010 10:29 am
File comment: making holes before
:wave_1:
PostPosted: Wed Jan 27, 2010 10:39 am
hi there norbert,i see we are using the same mostly the same tools,you are just using them better than me :thumbs_up_1: .the saw you have in the last pic what do you cut with it ,styrene,wood or metal.also who makes it, and where did you get it.the reason i am asking is i am looking for a better way to cut styrene sqaure stock and small diameter tubing. my chopper always cuts on a bit of an angle,very annoying.and by the way i like your way of using a drill and sandpaper to make circles :thumbs_up_1:
PostPosted: Wed Jan 27, 2010 10:46 am
Hi Russ good from you....
yes i am using the saw to cut metal and sometimes some tubes in styrene.
nut the tubes in the funnel i cut with a single cutter - and don't use the saw in this case.
yes the saw cut styrene tubes - metal - wood etc.. and is to cut just tubes
the square parts of styrene i use or the yellow cutter(slim) or the stainless steel(near the yellow cutter)= more harder and more older strongfull and the blades are large too.
and i use the ruler of drawing table or the 45º square or metal ruler too.
thansk for ask
yes the tools we have sometimes make more we think about... :cool_2:
PostPosted: Wed Jan 27, 2010 1:52 pm
Hi Norbert Yes many of the tools you have are similar to those that I have. I do like the proportional Disc , I have not seen this before ,I will have to get one of those . Your build on the funnel casing is looking excellent, have you made a start on the hull yet? One of the most over worked tools I have after the various sizes of pin vice is a mini tube cutter .
PostPosted: Wed Jan 27, 2010 2:23 pm
Hi Wooley good from you too.
yes most of tools are basic tools we haved used yes.
well the proportional disc is wonderfull. but i use when needed.
and is a difficult piece to find here cause the graphics firm still not used more that. are very older tools of the past but still working so much and very efficacy. i have a mini cutter too - is more faster and efficacy too but to cut angles the saw i have is wonderfull..
well i pretend order lime from your country this month(i pretend) and start finally the hull...
my great problem is still not make a "attelier" for me wich means a room to work and a shelter for the hull...
you know the money is short :roll_eyes:
but yours don't loose to wait and i thank you so much the support and encouragement :thumbs_up_1: :thumbs_up_1:
PostPosted: Wed Jan 27, 2010 2:59 pm
That is one extraordinary funnel work so far :thumbs_up_1: :thumbs_up_1: keep up the good stuff coming Norberto!!!
Jose :wave_1:
PostPosted: Wed Jan 27, 2010 3:02 pm
Thank you too Jose..
soon news.... :wave_1:
PostPosted: Wed Jan 27, 2010 6:47 pm
You are very welcome my friend. I will show some photos of the tools that I find very useful . As Russ works in the same medium as both of us we can compare notes ?
PostPosted: Thu Jan 28, 2010 10:00 am
i will waiting Dave
thank you so much :thumbs_up_1:
Users browsing this forum: Major Rich and 10 guests
Search for:
