It is currently Tue Jun 03, 2025 7:58 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: 1/192 HMS Glatton
PostPosted: Mon Apr 26, 2010 9:43 am
I started building this model 3 years ago (I'm terribly slow), I hope I'll finish it before this year's end !
It's based on the National Maritime Museum plans.
 Post subject: Re: 1/192 HMS Glatton
PostPosted: Mon Apr 26, 2010 10:10 am
Hi Setori Welcome to the board and the site . Good to see you posting pictures of your Glatton , an interesting subject.
PostPosted: Tue Apr 27, 2010 5:00 pm
:welcome: to modelwarships.com!
I always like a Monitor.....
:thumbs_up_1: :thumbs_up_1:
Jim Baumann
PostPosted: Thu May 06, 2010 11:15 am
Thank Jim an Dave :smallsmile:
here's the new production
File comment: This is the structure which will support the boats. It's photoetched
File comment: My main mast mast is nearly complete with the derrick.
PostPosted: Thu May 06, 2010 11:18 am
that's a good building Setori.
i love this type of attention in detail :thumbs_up_1:
PostPosted: Thu May 06, 2010 11:27 am
Thank you, but when I see what you're doing on your Bismarck, it will take a hundred years before I can get close to the the perfect work you're showing us.
It's the 1st time I build a 1/192 model (apart from a small cargo boat 40meters long)
I usually work on 1/500
PostPosted: Thu May 06, 2010 12:17 pm
Setori do you have a quality absorved from your 1/500 models.
but now is fantastic for you work in a large scale.
i can see many details and painting job with a good quality reproduction
welcome here
sincerely
Norberto :wave_1:
PostPosted: Fri May 21, 2010 8:30 am
I've done some work
The main mast is now glued to the deck
The metallic frames supporting the boats are also in place, and I've glued some stiffeners on the funnel (I made them with unithread 8/0)
The Carley floats are not glued yet
PostPosted: Fri May 21, 2010 9:18 am
This is a superb Glatton .
PostPosted: Thu Jun 24, 2010 5:44 am
Very nice work! :thumbs_up_1: And hey - no Bismarck!! :cool_1: :cool_2:
Please keep us updated! :wave_1:
Thanks & Sources: Nilsson (research), M.Otten (modelling, research), J.Kaiser (research), B.Jenzsch (3D Services) and J.Arntz (research, drawings). HASSLER Profile, ZERO PAINTS, IWATA airbrush, EXCEL blades, Byrnes Model Machines and more
PostPosted: Thu Jun 24, 2010 10:12 am
My camera is broken and I sent it back to the dealer. I think it's gonna take time :heh:
PostPosted: Fri Aug 27, 2010 10:09 am
Summer's almost gone
I can resume work on my model.
during the last two months it was very hard to find time to work on it (beach fiestas) without a trembling hand.
I've fixed the railings on the port side of the boat deck : stanchions : entomologic needles 000 and nylon fishing thread.
The 3" HA gun is not definitely glued, neither the motor boat which is not finished
The compass platform is almost ready (the chart table needs to be glued on place)
There's too a lot of minor paintwork to do
PostPosted: Wed Jan 26, 2011 11:30 am
I've done some work !!!
I've fixed the foremast. I tried to make the signal halyards with Uni caenis wire, but I was dissatisfied with the result (too much sagging).
I've then tried the stretched sprue method of Jim Baumann and it worked perfectly (and quickly) Thank you Jim :thumbs_up_1:
For tightening the sprue I used a rolled cigarette as I have always have one in the mouth !
Edit JB-- rotated photo
File comment: Anchors, chains and stoppers are finished (a little painwork left to do) but the catseyes have been blown away in the process
PostPosted: Wed Jan 26, 2011 1:15 pm
Excellent!
I am happy that it worked well for you in a larger scale also!!
I actually developed the smoke method using Gitanes and Gauloise cigarettes--then I moved on to Camel Filter... :big_grin:
then... 11 years ago...
I gave up smoking--hence I now use incense sticks fro tightening rigging.
Model room smells like an Eastern Temple!
JIM B :wave_1:
PostPosted: Mon Apr 04, 2011 11:17 am
I've done some work
File comment: I tested the making of radio aerials.
I photo etched some rings and glued Uni caenis on them. It worked at the 2nd attempt.
A big problem will be fixing them on the yards
File comment: I've finished the forward part of the upper deck.
Still need somme painting.
The Jackstaff will be glued at the last moment
PostPosted: Mon Apr 04, 2011 11:27 am
Hi Setori good to see you back again
with this fine construction
the works i :wave_1: :thumbs_up_1: :cool_2: n your shipyard bringing us a fine model
Regards
PostPosted: Fri May 06, 2011 9:07 am
I made the rope ladders which lead to the the top of the masts.
I had to build a jig and glued the wires with shellac
File comment: the jig
File comment: the ladder on the foremast
File comment: on the mainmast
File comment: There's a lot of vents (approximately 18 on each side)
PostPosted: Fri May 06, 2011 9:46 am
Hello Setori :wave_1:
great build, i wish i could do my own p/etching.
An easy way to attach the radio rigging is to use Lycra at both ends.
Roy
PostPosted: Fri May 06, 2011 9:55 am
Photo etching is Very Easy.
You only need
a computer an Corel draw for instance
an etching lab which cost 170 euros.
try it (if you have the money) the result is worth the investment
PostPosted: Fri May 06, 2011 10:17 am
Hi :wave_1:
Where would i look for p/etch labs, sounds interesting :big_grin:
Roy
