Hi everyone,
Before I get to the subject of today’s posting, I’d like to make a quick note of the earthquake in Japan and its aftermath. I commented at length elsewhere on this site, so I will be brief here. My thoughts, prayers, and sympathy are with the victims of the earthquake and tsunami, and I pray for their recovery.
In my previous posting, I referred to the ‘spray shields’ on either side of the bow. I’d solicited feedback from readers about the correct terminology and my brother stepped up to provide the correct terminology. The official nomenclature is ‘bulwark.’ Yeah, I know; bulwark is a pretty nautical-sounding term and I should’ve realized that’s what they were called!
Thanks for the help!
Today, I’d like to tell you about my strategy for painting the camouflage on the ship. At the start of my postings on this model project, I posted a photo of the LSM-59 at Iwo Jima. At commissioning, most LSMs displayed the Measure 31 design 10 or design 17 camouflage scheme. Due to the harsh environment of the sea, it didn’t take long until ships needed repainting. As can be seen in the photo of the 59 at Iwo, when repainting became necessary, it was typical that the new paint went over the old, using the same pattern and colors the ships wore when leaving the shipyard.
Initially, LSMs displayed 3 to 4-foot tall hull numbers painted in white on the bow and stern. As experience was gained from amphibious operations, the Navy ordered ships to repaint their hull numbers larger (approximately 6 feet tall) to aid in identification.
One more thing to consider. In the photo below, you can see the weathered paint scheme on the bow of the 59.
File comment: Photo of bow of LSM-59 at Iwo Jima 1945, courtesy of John Cason
Also note that the ship’s original small hull numbers are still visible even though they’ve been painted over. Although there aren’t photos that show the rest of the ship with such clarity, I think it is a safe assumption that the rest of the hull numbers were painted over in a similar manner.
So, at this point, we are talking about a ship that has had locally-applied camouflage painted to mimic the original scheme, with larger hull numbers and evidence remaining of the earlier hull numbers, and the ship is heavily weathered. So, how to replicate this on a model?
Well, here’s the strategy I decided upon. First, I’d give the ship an overall base coat of ocean green. Then, I would paint on the small white hull numbers. Then, I’d paint the camouflage scheme and next, I’d use a suitable shade of paint to paint over the existing hull numbers so as to leave a telltale sign of their presence. Once this is completed, I’ll spray the hull with Future and weather the hull. Sounds pretty easy, huh?
The photo below shows the first steps of translating my strategy into reality. The model is painted overall ocean green and the small white hull numbers are applied. At the time I painted the hull, I got ahead of myself and forgot about what I believe is referred to as ‘scaling colors.’ That is, addition of gray or white to the paint to give the model a more authentic appearance. Straight out of the bottle, paint will usually appear too dark on a model. Since painting the hull overall ocean green is just the first step in the camouflage process, it is not a major concern.
File comment: LSM-59 with small hull numbers and overall ocean green
The next step is to begin laying out the camouflage scheme and applying masking. The Measure 31 scheme consisted of Ocean Green, Navy Green, and Flat Black. This is the point at which it is important to remember to ‘scale’ the paints. To mask the areas of Ocean Green off, I rely on a latex masking liquid called Magic Masker, which used to be made by Walthers. It appears they have recently discontinued producing it, but I have some old stock still around to use up. To augment the Magic Masker, I use plain old everyday painter’s blue masking tape. Yeah, not very exotic, I know, but since I am not concerned about having sharp edges to the paint, it is more than adequate. I’ll show you how that is progressing in my next posting.
One last thing before I wrap this post up. Earlier, I posted a couple of shots of the stern anchor winch. The winch wasn’t finished at the time because it lacked the wildcat drum on the side and some handwheels. I solved the handwheel problem by ordering some PE handwheels from the Floating Drydock. I scratch built the wildcat drum using the very common method of layering styrene. The minimum diameter of the drum was ¼ inch, which allowed me to use styrene tubing as the basis for the drum. Standard everyday hole punches make a ¼ inch hole, which I used to punch holes in .010 inch styrene. I chose .010 inch styrene because I wanted to take advantage of the additional strength gained from multiple layers. I then cut ‘donuts’ out of the .010 styrene. I didn’t worry too much about them being pretty because they would be filed down anyway.
Here’s a shot of the beginnings of making the drum.
File comment: Beginnings of the wildcat drum 01
I glued all the ‘donuts’ onto the ¼ inch styrene tubing using Testor’s liquid cement and let the assembly set overnight.
File comment: Rough version of the wildcat drum
Lacking a lathe, I put the assembly into a standard electric drill and with a file and sandpaper, shaped the drum to the desired profile. Pretty high-tech, eh?
Here’s a photo of the winch in its final configuration with the handwheels and the wildcat drum.
File comment: The winch almost finished
After a bit of cleaning up, I’ll spray it with future and weather it. Photos to come.
In my next post, I’ll show you the progress on the camouflage. See you then! John
