Hi everyone!
Thanks for checking in and leaving your comments. In particular, most recently, Richard and the Admiral have left notes. They're always appreciated!
Today's posting is a bit long-winded because it is about the base I've been working on for the model. I began work on the base at the start of the year; you'll see that in the photos below because I hadn't begun camouflaging the LSM-59 when I took these photos.
From the beginning, I knew that the base was going to be big. The model is about 51 inches or about 1.3 meters long all by itself. Since the display would show the 59 landing vehicles at Iwo Jima, that was going to add another 6 inches to the length of the base for the bow ramp alone. Then, after adding about 4 more inches at the bow and the stern so the model won’t look too crowded, all of a sudden, I was looking at a base that was 64 inches long! In the same regard, the width of the base was going to be rather large, too. The model is about 8 ½ inches wide. I wanted to have about 4 inches of space on either side of the hull once again so as to not crowd the model. This meant that in the end, the base was going to be about 16 inches by 64 inches. Good thing I have lots of room!
I rarely build bases for my models and I’ve never built a seascape base before, so I was a bit hesitant about proceeding. Fortunately, examples of seascape bases abound at ModelWarships.com, along with lots of ‘how-to’ guidance, which gave me an idea of how to proceed. The first step was to get some lumber and then pick up some acrylic paints and gel medium at the local Michael’s crafts store.
The base began as a particle board shelf, which I cut down to the desired size. Then, I attached thin wood strips along the sides.
Here's a look:
File comment: This is a photo of the newly-assembled base with the model sitting in the approximate position where it will be mounted.
Once the base was assembled, I painted it with Payne’s Gray acrylic, which is a dark black-blue and allowed it to dry.
Here’s a photo.
File comment: The base is shown here sitting on my highly organized work bench after it had been painted. You can see the approximate location of the ship, which has been left unpainted.
The next step was to tackle the ‘beach.’ Iwo Jima is a volcanic island and one of the unforgettable characteristics of the island is its black sand. I pondered how to replicate this for quite a while and read about how other modelers had simulated beach scenes. Some modelers have used actual sand but I decided against that because the grains would be out of scale. I wanted something that would be relatively smooth but a little coarse. I decided to mix up a batch of Celluclay with model railroad fine black ballast and fine brown cinders. Celluclay is a papier mache’ model railroad product that dries hard as a rock. To give the mix the right color, I added acrylic black paint until I felt I had the right shade.
Here’s a photo of the mush I created.
File comment: This is going to become the 'beach'
I applied the mush by hand to the beach end of the base while wearing gloves. Once I’d gotten all of mush onto the base, I applied masking tape around the model’s hull and attached the hull to the base with screws. At this point, I carefully sculpted the ‘beach’ around the bow of the ship.
Here’s a photo of the hull sitting on the base with the waterline masked.
File comment: Model is sitting on the base in its approximate final location with the waterline masked.
Here’s a couple photos of the ‘beach’ taking shape.
File comment: The beach going in
File comment: Another shot of the beach
While waiting for the beach mush to dry, (which took a couple days!) I began working on the water. For this, I took a page from other modelers on ModelWarships and used acrylic gel medium. On a base this large, application takes a very long time!
As I’ve mentioned in an earlier post, LSMs would drop their stern anchor when approaching a beachhead and after unloading, use the anchor to pull the ship off the beach. One of the reasons that I made the base so large was so I could display the model with the anchor deployed. For the anchor cable, I used thread that I’d coated with white glue. The white glue smoothes out all the fuzz and helps to keep the line straight. One end of the ‘anchor cable’ was fastened to the base prior to applying gel medium and the rest of the cable was temporarily attached to the stern of the model.
While unloading on a ‘hot’ beachhead, LSMs would maintain an ahead bell on the screws, which meant the ship would be kicking up a prop wash, as shown in this US Navy photo (courtesy of NavSource.org) of LSM-43 unloading at Iwo Jima during the invasion.
I wanted to simulate this, so I took care to build up the prop wash with gel. I also simulated the pooling around the diesel cooling water discharges that were amidships on the port and starboard sides.
Here’s a photo showing the area around the stern.
File comment: The stern anchor line going into the prop wash. The acrylic gel medium has just been applied and hasn't dried at this point.
After the gel had set, I carefully removed the ship from the base and peeled off the protective masking tape along the waterline.
The water around Pacific islands is typically described as very blue, so to achieve this, I used a couple of different shades of blue: Phthalocyanine Blue and Ultramarine Blue. I used Titanium White to lighten the blues of the water and to highlight the prop wash.
Here’s a photo of the model on the base after the initial painting. I still have more experimenting with shades of blue and white to do, but after I am satisfied with the water and the beach, I’ll coat the water on the base with Future floor wax. I’ll post photos when I get to that point.
Here's an in-progress shot of the painting:
File comment: A photo showing the first attempts at painting the 'water'
In my recent post about painting the camouflage, I got a little ahead of myself talking about spraying the hull with Future and weathering. Before I can do that, I have to apply the large hull numbers. I’ll show you that in my next post.
'til next time -
John
