It is currently Wed Sep 17, 2025 11:36 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Mar 01, 2011 1:29 pm
All,
Well, I've been a lurker here for more than a little while, and have been debating if I should post to this forum, but since I'm getting close to finishing the ship, I figured, why not? So, bearing in mind that this is my first scratch-build, my first ship and well, I'm a former member of a armoured regiment so my knowledge of all things Navy is limited--and perhaps a bit biased :) --here is my current project.
Some background: I hail from Prince Edward Island, Canada's smallest province, but one with a proud military tradition. I'm defiantly a 1/72 modeler, choosing this scale over almost all others, and when 2010 rolled around I knew I wanted to build a 1/72 model of a Canadian warship, as my celebration of the Canadian Navy's centennial. Never having tackled anything that big before, I figured I'd cover my bases by getting several sets of plans for modern Canadian ships--and eventually I settled on the smaller Kingston-class MCDV; partly because it was do-able, and partly because one of the MCDVs is named after PEI's second largest city, Summerside. I've since fallen in love with ship modeling, and have plans on building all the ships that have served in the Canadian navy that were named after places on PEI (there are seven, and in 1/72 I may need a larger house...)
I have a debt of gratitude especially to Darren Scannell of the Resin Shipyard, as without his assistance and patience with my stupid questions about ships this project wouldn't have been started, let alone nearing completion. As well, I thank several other board members who have helped answer questions or offer advice--and not to mention the amazing reference materials that exist here as the completed builds of a variety of ship models large and small. This board is home to some master craftsmen, and I aspire to that level of quality myself one day.
One further note: This was a Navy Centennial build, and should have been completed last year, but a kink in the form of a broken ankle in December conspired to delay it. Nonetheless, when I started, I'd not considered posting the build, so some of the early photos are taken with my Blackberry, and are of dubious quality.
So here we go...way back in January of 2010...
Here's where everything started, the keel laying (as it were):
After cutting the bulkheads and gluing them to the keel, I set out to run stringers (none of them apparently straight) between. Some scrap balsa was fiddled with to produce a rough 1/700 Summerside mock-up--just for fun
The bow, and stern were carved from balsa, and once I was reasonably happy with the stringers (which is to say, they were all glued in place) I started planking using 1/16 balsa strip--pinning it using straight pins to hold it while the carpenter's glue dried:
It was at this point that I was unsure of the shape of the bow--the whole ship seems short and squatter than is should be....unfortunately, I'd started building before I had a top view scaled to 1/72...this would cause problems later...
It looked nice by the stern though :)
A fuzzy shot of the planked hull...
Compare that to the real Summerside:
Yeah, shape issues. Once I got a decent main deck plan view scaled to 1/72 I realized what happened--when re-scaling the plans I had, I'd assumed they were all the same scale--but the starboard elevation (visible in the first photo under the keel) was slightly smaller. Without a gut check with the main deck plan, I'd ended up using the wrong measurements, and that screwed up the shape of the bow. At this point, I had to cut the bow off, add a 1" plug of balsa to bring it to the right length, and re-profile everything....
More on that my next post. :)
Thanks for listening to my rambling.
Sean
Now Complete: 1/72 HMCS SUMMERSIDE (MM 711)
Now Complete: 1/72 HMCS ST. CROIX(I-81)
Current Project(s): 1/72 HMS WALNEY(Y 04)
PostPosted: Tue Mar 01, 2011 2:27 pm
Wonderful to see an HMCS build here! Glad to see this coming to fruition :)
PostPosted: Tue Mar 01, 2011 3:23 pm
Same here, rather rare subjects, but interesting ones for sure!
I expected somewhere an error in the plans as there is a fairly strange bulge in those first pics. Not a disaster though, if you never try, you'll never make a mistake (but you'll never have a model either!). I'm sure such mistakes have been made by many over here. I too had a frame sticking out somewhere by bad alignment. You learn from the experience and as far as I can read in the beginning of your topic, you're nearing completion = you fixed the problem along the way!
Good luck in finishing your project, I'm eagerly waiting for the next set of pictures :woo_hoo: :thumbs_up_1:
The merchant shipyard
PostPosted: Tue Mar 01, 2011 3:54 pm
Hi Sean welcomes to scratch build. Identifying any error is one thing correcting the error is another but to show and mention this on your first build on a web board devoted to scratch building takes some doing and for that alone you deserve a commendation .Any way your first build is a good deal better than my first built . Good to have you aboard.
:thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Wed Mar 02, 2011 5:47 am
Hi Sean :wave_1:
Welcome aboard :welcome: Looking forward to your build.When you scratch build you encounter proublems that have to be solved .How you solve them is what makes you a Model BUILDER. :woo_hoo: .
PostPosted: Wed Mar 02, 2011 10:19 am
Thanks guys! I appreciate the warm welcome, and I too am happy that there is an ever-growing fraternity of Canadian naval subjects here; makes it feel like home ;)
Just to riff on what's already been said regarding errors, it really does test, and push your modeling skills to the edge taking on a project like this. Throughout the process I've been sharing the build with friends and members of one of the local hobby clubs, and sometimes it was hard to take the criticism--I had a vision of what I wanted, and I could see that even when all anyone else could see was a collection of badly-glued wood pieces. The constructive criticism though was of great value, and so long as you take some of it with a grain of salt, have faith in your vision and your skills, and then make the needed modifications I believe the build will be a success. Having worked my way through this project, I'm very proud to be able to call myself a modeller, rather than just a kit-builder ;)
Neptune's right, I'd forgotten there was another shape issue with one of the bulkheads--I have no idea how or why, but one of the bulkheads ended up too wide at the top, causing a weird undulation amidships. I re-profiled it, cut new stringers, added a new bulkhead in-between to smooth out the profile and prayed to the gods of wood putty and sand-paper that I could make it smooth later :)
The following two photos show Summerside after the work on the bow and amidships:
At this point, once I'd reshaped the amidships bulge, added a 1" plug just forward of where the Bofors would mount and re-shaped the bow block with generous helping of wood putty, I sanded the living hell out of it and sealed the wood with several coats of acrylic varnish.
I initially planned on coating the wood with a thin layer of Bondo, but my good friend Dennis Kaye (an amazing ship-modeler in his own right, and someone who has been like a mentor to me on this project) suggested I use lithoplate. In an attempt to replicate the actual hull plating, I marked up the hull with panel lines and numbers indication what plate goes where--hence the weird look of the hull.
As can be seen in this photo as well:
I've planked the deck the same was as the hull, and overlaid thin styrene sheet, using Bondo to fill the seams. The superstructure, mast, fun mount and stacks are under construction, but the bridge is only mocked up with cardboard--I'd hoped to get the shape right using cardboard for a master before cutting clear acrylic sheets for the bridge deck bulkheads, but that didn't go quite as expected...
Here is a similar shot after the litho was glued, a skim coat of Bondo applied and the whole hull sanded down and primed:
The stacks have been sheeted with styrene, and I've replicated the dished, stressed-metal effect common to Kingston-Class stacks, by drawing a curved scalpel across the sheet in parallel and perpendicular lines. The effect came out a little overdone, so as construction continued I mellowed it out using some Mr Surfacer and my good friend sand-paper :)
Another shot, from the bow this time. Still some sanding left to do:
The hawse-pipes were drilled out and brass tube fitted. I'm using a Billing's Boat winch, but it's being modified as it's not exactly the same as what Summerside has. I still have the cardboard bridge as I was still having trouble getting the angled-outwards part of the bridge right. These photos were taken by my Dad who was out in Calgary visiting. He was heading back to PEI the end of May 2010 (around when these photos were taken) and wanted to approach the Charlottetown Naval reserve, HMCS Queen Charlotte, about the possibility of me donating the completed model to them--lord knows I don't have room in my house to display it properly. Being an architect, my father wanted some good scale photos to take to the Queen Charlotte.
So this was the state of proceedings last May when I took her to the Western Canadian Regional Model Contest in Nanton Alberta. There was still a lot of work to do, but I was happy with how it was coming--especially in light of being able to--in my mind successfully--deal with the shape issues I'd run in to. It was becoming to look like the ship in my vision--even if only I could see that :)
Thanks again for the interest Guys. More to come.
Sean
PostPosted: Wed Mar 09, 2011 7:07 am
Hello, Sean,
It's great to see another Cdn build on here and a nice ship too. I will be watching you posts with great interest as I am sure I will be building one of these vessels in the future.
James W.
Dry docked:
1/72 HMCS Assiniboine DDE 234-1960
1/72 HMCS Ottawa DDE 229-1960
1/72 HMCS St. Catharines-River Class Frigate-1944
On the slipway:
1/72 HMCS Camrose-Flower Class Corvette-1943
1/72 HMCS Trillium-Flower Class Corvette-1942
PostPosted: Wed Mar 09, 2011 6:26 pm
Thanks James. Truth be told it was your 1/72 Assiniboine build that first brought me here, before I'd even picked my subject, and having read through your build (up to that point anyway) that made me realize there was no hope of me doing justice to a large scale subject like Charlottetown--measuring what I perceived I could do for my first ship against what you were doing made me realize I needed to pick a smaller subject to start :)
In fact I'm keen to see the Boffin mounts you're working on, since the one on Summerside (and hence what I've modeled) apparently comes from one of the DDE/DDHs. I'm keen to compare :)
But first, I need to get some detail shots of my current work without relying on the POS camera in my BlackBerry :Mad_5:
Sean
PostPosted: Fri Mar 11, 2011 7:26 pm
Thanks for the interest in my build. I have lots of photos of the Boffin mount on the Hiada as she in only 30min down the road from me. If you like, I can e-mail them to you. As I don't have many close ups of the actual 40mm mounts on Assiniboine, I will just use the Hiada version and say close enough.
I am planning to use the Airfix 40mm Bofors for the barrel but I have not actually scaled that yet to see if it is 1/72 or 1/76 as Airfix kits vary alot between what the box says and what is inside (for armour anyways). I have build the power moduals and have worked on the bases for the guns but haven't posted any photos yet. Hopefully this weekend I will get something done.
James W.
Dry docked:
On the slipway:
PostPosted: Wed Mar 16, 2011 10:10 am
James,
Thanks for the offer of photos, but we actually have an old boffin mount here in Calgary at the Naval Museum. I've had the opportunity to minutely examine it, along with the 12 pdr 12 cwt as well (but that is for another project). Truth be told, the older boffin mounts are quite a bit different from what's mounted on the Kingstons; but thank you anyway. I've built mine up using the White Ensign Mk 3 kit--granted it's a USN rather than RN/RCN version, but I'm not using much of the mount, and I figured the barrel and breech would be close enough for jazz :) Sadly this means I don't have much advice regarding the Airfix Bofors to pass along.... :) AFAIK however, the Airfix kit is actually 1/76 so it may be a mite small and spindly in 1/72, but I can't say for sure.
So, where were we?
Right. At this point it was late May 2010, and I took the Summerside as you see it here to the model show in Nanton, AB to display (as opposed to competing) along with other completed and not so completed projects (including a friend's 1/350 starship Enterprise WIP--very cool). She generated no small amount of interest from people who I spoke with, and I brought home a bronze for my 1/700 Alfa waterline (which also appears in this year's Great Scale Models), and add to that my daughter winning Best Junior Auto and we had a pretty good time.
Throughout the summer progress slowed as I worked mainly on final major bits of construction (like the bridge bulkheads, which gave me fits trying to get the geometry of the angled outwards parts correct). I also began to scratch some masters for fittings like bollards, bull-rings and water-tight hatches.
By fall I'd reached this point (all photos taken by Scott McTavish):
As you can see, there's a fair amount of filling and sanding of the hull still to do, but the bits and bobs were coming together to look like a ship.
The Kingston class MCDV's are modular in that they can ship several different equipment fits by carrying a 20' ISO container on the read deck. In the photo above you can see the resin MIG shipping container--it still needs paint and doors and actual shipping information (to be taken from HO decals...)
Another view from the stern. The RHIB is a resin copy of one that came from the old Revell 1/72 Cousteau Catalina. I made a mold of the assembled boat and took the first usable resin copy, and added a 1 cm plug to enlarge it using styrene for the floor and Apoxie Sculpt for the sides. As I'm planning on building the HMCS Charlottetown in the future, I'm thinking of casting a copy of this RHIB as a starting point for that project.
The props are left and right handed, and were bought at my LHS. The Kingstons have z-drive, so I had to build the azipods, but didn't need to build a rudder, so I guess it all evens out. :)
As you can see I've started the gun mount and mast here. The model was originally designed to be lit, but as time moved along I decided I'd leave experimenting with lighting to another project. Nonetheless, the mast is still built on a brass tube to allow for lighting later. The yardarms are plastic rod with blobs of CA at the ends to form half-spheres.
And here's the bridge. As you can see, I've finally gotten the geometry of the outward angled parts correct (what a nightmare that was--I had to rebuild this part four times until I was happy with it). I've also built the bulkheads out of clear acrylic on the advise of a member of the local model club--he suggested that it would be easiest to simply mask off the windows and paint the rest so I needn't worry about fiddly window-making. You can also see that I've cast some of the hatches and mounted them using Crystal Clear glue. The bridge wings are roughed in, and the final finish of those will go on when I'm ready to do the railings.
Well, that's it for now. Next update, painting :)
Sean
PostPosted: Wed Mar 16, 2011 11:03 am
hello sean,the summerside is looking bang on good.the casting of the rib is also good.what type of moulding and casting material do you use.i live in campbell river and run a small passenger and frieght boat up and down the coast and quite often run into this class of ship.
PostPosted: Wed Mar 16, 2011 12:11 pm
Russ,
Thanks for the kind words--I've been keenly watching your Adm Scheer build; I can never get enough of seeing all you talented scratch-builders work :) As for Summerside, I was pretty nervous at the early going that I'd never be able to finish the model successfully--but I seem to have taken to ship modeling, well, like a fish to water :)
Despite friends prodding me to use better quality materials, I do all my molding and casting with Alumilite high-strength silicon and Alumilite resin. I've used Smooth-on products before, and prefer them but they cost much more than the Alumilite at my LHS
I hope one day to be able to walk the deck of an MCDV--they came into service since I moved to Calgary, and we don't have much need for them here :) I've only been out to Vancouver Island once, and couldn't make it to Esquimalt. I'm back home in PEI for a week this summer, and plan on going to the Maritime Museum of the Atlantic in Halifax--so who knows, maybe I'll see one puttering along in the harbor :)
Sean
PostPosted: Wed Mar 16, 2011 12:41 pm
Hi Sean your build is progressing well . An interesting ship and it would be just as manageable at the larger scale of 1:48 ?
PostPosted: Wed Mar 16, 2011 1:03 pm
Dave,
Yeah, I think it wouldn't be any more difficult in 1/48 than in 1/72. In actual fact I've had a couple of discussions with another modeler friend of mine who is thinking he might build one in 1/48 as a working model. My scale would be too small for RC I think (not that RC is my thing anyway--I prefer not to to risk all my work ending up at the bottom of a lake :heh: ) but 1/48 should be all right if you can find a way of building the azipods (though I think you might need to make them bigger than scale to get them to work properly, but I don't think that would be noticeable) but I leave that to those more knowledgeable in the ways of working ship models than I :big_grin:
Sean
PostPosted: Wed Mar 16, 2011 2:26 pm
wow the model looks superb! :smallsmile: :thumbs_up_1:
PostPosted: Sat Mar 19, 2011 6:30 pm
Sean,
Thanks for the info on the Airfix Bofors. I will have to scratch build one. I looked at the flickr photos, how did you do the dimpling on the funnel casings?
The ship is looking very good.
James W.
Dry docked:
On the slipway:
PostPosted: Fri Apr 01, 2011 1:48 pm
Thanks James. I created the "dished" effect on the funnel casings by marking a grid in pencil that matched the visible frames I saw in close up photos and then drew a curved #10 blade "backwards" in-between the pencil marks--that is, the sharp end was at the trailing, rather than leading edge of the draw. It's worked all right I guess, but I'm not 100% happy with it. I think it could have been done better with some pre-shading during the painting phase, which is how I'm planning on replicating a similar effect on the hull.
Just to jump ahead in the time-line (I'll come back to the ship herself in my next post) I figured I'd take a moment to talk about how I've tackled or in this case re-tackled) the two Rigid Hull Inflatable Boats (RHIBs, or Zodiacs) the MCDVs carry. When I started out I had no confidence that could make one, so I started looking for a 1/72 Zodiac I could use. A friend of a friend recommended tracking down the Revell Jaques Cousteau PBY-5 kit as it contained a plastic Zodiac. I picked one up on Ebay for a reasonable price, removed the zodiac parts from the kit and "donated" the rest of it to a friend :)
After studying the photos I had however I noticed that the Zodiac didn't quite look the same, and in fact there were two, a longer one and a shorter one. So with some trepidation I elected to make a mold that would allow me to make modifications without ruining the only injection molded copy I had.
You can see the zodiac parts in the top right of the image above. (both photos courtesy of Lars Jørgensen's excellent review at modelingmadness.com)
Here you can see the original as assembled, the mold and the resin copy
I built a stretched version by cutting one of the copies in half, and inserting a pair of aluminum rods into the "pontoons" and rebuildin the floor and keel of the inserted "plug" with sheet styrene and Apoxie sSculpt. I added an operator's station and a "roll-bar" and threw a quick coat of paint on it.
After some time I came back to finish it off, but I wasn't happy with how it looked--it wasn't as beefy as the photos I had showed the original to be. After poking around the Zodiac website, I downloaded some of their sales materials, and scaled the plans to 1/72.
As you can see, in comparison the model zodiac is too pointy at he bow , and lacks the deep, rigid keel of the prototype.
By comparison, the non-stretched zodiac looks not too bad, save for the point of the nose. This I'll fix by carving away the attached bow tarp and the "point" and re-shaping it with Apoxie Sculpt.
For the "stretched" version, I again cut a resin copy in half down the middle, and lengthened it using aluminum tubing. This time however, I also built up a keel cut from plastic sheet. As photos show this bottom sections with a pair of chines, I added them using additional curved sections of plastic sheet. It's all pretty rough right now, but I'll be using Apoxie Sculpt to fair things in and sand it smooth after.
Aaaaannnnnddd....this is what you get when you don't have a means for air to escape from your molds. The bubbles are an easy fix, I just fill them with either Apoxie Sculpt or Superglue, but the tips of the pontoons need to be rebuilt. I drilled a small hole in each and inserted a length of brass rod, cemented in with superglue. I'll rebuild the tips with Apoxie Sculpt, but as I plan on casting copies of the finished Zodiac, I'll leave the rod untrimmed, allowing for an pocket air can escape into to when pouring resin so the tips aren't obliterated by bubbles.
Still some work to do--I have to remove the tarp and point of the bow and build an operator's console, but I'm already a lot happier with the new Zodiacs, since they're going to look more the part when the ship's on display :)
I'll follow up with more photos as I complete these two RHIBs--hopefully it's of help to others out there who may be wondering what to do about this little guys on modern warship models. Or it just soothes the ego talking about it :heh:
Plus it's an opportunity to try out my new digital camera--it already is 1000% better at closeup's of the work bench than the Blackberry :cool_2:
Sean
PostPosted: Fri Apr 01, 2011 3:03 pm
hi sean,i like the rib,s very much,when you are making your moulds do you have a vacum pot or somthing to degass the silicon before you pore, or does the stuff you use need it.i do not have a means of degassing,and no mater how easy i mix lots of tiny,tiny bubbles get in.
PostPosted: Fri Apr 01, 2011 3:32 pm
Do you have a pressure pot?
Darren (Admiral Hawk)
PostPosted: Fri Apr 01, 2011 4:00 pm
Russ,
Nothing fancy with my set-up--I don't have a pressure pot or vacuum chamber to degas the silicone or the resin. The up side is it forces me to think really hard about how to best design the mold to alleviate the issue of bubbles. As can be seen my first attempt with the zodiac wasn't so good, but thanks to that experience I've got some ideas about how to cast the next set.
The downside is I spend hours sitting and watching silicone and resin cure, using a toothpick and a tiny brass wire to prod and poke bubbles out of the molds and castings :cool_2: When I say I hand-crafted a cast resin part, I really mean it!
In all seriousness though, I know there are better ways to do it than I do, but one lesson I learned in the army is to do it the hard way to learn it, and then the easy way to perfect it--I'm only just learning ATM, but soon, my precious, soon, I'll be investing in a pressure pot...not that I'll ever be able to compete with Darren and his Resin Shipyard :eyebrows: :thumbs_up_1:
Sean
Users browsing this forum: No registered users and 42 guests
