hello everyone,
It has been a couple of weeks since I registered with this site, and I should say, I am really impressed by all the work done by all you modellers here. Not only impressed, I am really insired to build something on my own since I have a couple of weeks of time for myself (summer holidays). After doing a bit of research, I decided to model INS Veer (Tarantul I) in 1/100 scale.
You may ask why I chose that ship and the scale, well I wanted something not too big that I can put in the pool in my apartment, but not too small that I won't be able to add any details as my skills are limited. INS Veer is a guided missile corvett, and the length of the hull is 56 m. At 1/100 scale, the hull will be 56 cm, which is the size I am looking at. 1/96 seems like a popular scale, but diving by 100 makes it easier to conver the actual dimentions to the scale, so I decide on that one. Also, I wanted a ship with less details and components as this is my first scratch built hull. And, why Indian Navy colors? Because I have been on board some of the Indian Naval Ships when I was a teenager, and that is how my facsication for ships grew.
I am a full time student with a meager budget! Hence, this project is going to use most of the stuff that I already have, and scartch built parts as much as possible. The hull will be made out of balsa, with fiber glass coating. The super structure will me made out of styrene of various thickness and some rigid crylic sheet that I already posess.
I could not source a resonably priced plan of the Tarantul. I went ahead and bought a 1/400 plastic kit made by Mirage Hobbies from http://www.squadron.com. My idea is to use this as a template to build a larger model. Found out that I oderdered Tarantul III instead of Tarantul I! I decided to go ahead and use it since the hull is the same.
I also downloaded a boat load of photos of Hiddensee from various photo sharing sites like http://www.webshots.com and http://www.flickr.com. Since Hiddensee is also a Tarantul I class ship, I am going to use these photos as my reference material for building the details.
And now some newbie questions.
1) For a model that is 56 cm (22 inches) long, what type of propulsion system do I need? The ship has two propellers and has a maximum speed of 40 knots. What size motors do you recommend for scale speed?
2) I do not have an airbrush. Do you recommend using a spray can or would it be better to use a brush? And what colors?
3) I already googled for information and photos of this ship. If you know of any other source of material (things like personal photo albums, news groups or threads etc), please let me know. It would be very helpful.
This is my first scrath built hull and my first scratch built radio controlled ship model. Just wanted to make a point as how inexperienced I am at this, so any advice will be greatly appreciated. Also, you will have to excuse my limited writing skills and loose usage of nautical terms! Your anwsers and thoughts are greatly appreciated.
Kalkura
