It is currently Sat May 24, 2025 6:35 pm
PostPosted: Thu May 29, 2014 11:48 am
Link: http://history.scout.com/story/1394442- ... NjA5OTAxS0
PostPosted: Thu May 29, 2014 5:24 pm
They've finally done it - a Death Ray!! :woo_hoo:
PostPosted: Fri May 30, 2014 5:03 am
I wonder what it was that was burning ? A slow drone like that shouldn't have masses of fuel on board.
PostPosted: Sun Jun 01, 2014 12:48 am
Aluminum, and carbon composite both burn at the right temperature.
Seasick
PostPosted: Sun Jun 01, 2014 9:31 am
They wouldn't spread like that - that was a flammable substance, probably fuel
PostPosted: Sun Jun 01, 2014 3:15 pm
It doesn't take "masses" of fuel to make a large fire. A friend of mine had an engine fire while taking off in an EP-3. The flames shot back the length of the aircaft and lasted through the emergency shutdown procedure, two fire bottles and the then-standard resetting of the oil shutoff circuit breakers. Post-incident analysis showed that an oil seal had ruptured and the engine was pumping the oil directly onto the exhaust manifold. Max oil capacity on the T-56 engine was 8.65 US gallons. Not alot, but enough for quite a show.
