Very thoughtful points Timmy!
Timmy C wrote:
Are you talking about the possibility of those additional missions at the time the missile was in service...
Additional missions while in service from mid 1950s through the seventies.
Timmy C wrote:
It seems the fundamental problem with the land-attack and long-range anti-ship missions would be targeting and guidance.
Yes - this was also an issue for ballistic missiles of the era like the MGR-1 Honest John, and air launched cruise missiles like AGM-28 Hound Dog.
The question also depends on the nature of the target – early 1960s inertial guidance was sufficiently accurate for nuclear, or chemical weapon delivery against air defenses (SAM sites, radars, airfields and so forth). Keep in mind that until submarine launched ballistic missiles like Polaris were fielded in quantity, strategic deterrence largely relied on manned bombers, which had a number of issues.
The anti-radiation RIM-8H was a different animal, and might be the basis for an anti-ship variant.
Timmy C wrote:
Are there any scenarios in which the entire command chain process required to authorize nuclear use would actually take advantage of the Talos' speed and forward location, and which could not be met by already existing means of nuclear delivery systems, keeping in mind the risk of nuclear escalation?
The reality is that the current command system evolved from a very “wild west” mentality about nukes. There is a reason that the USA and Soviet Union each fielded tens of thousands of nuclear weapons simultaneously.
I am not sure exactly how the USA and USSR avoided nuclear war in the 1950s and 1960s giving a fairly cavalier attitude about tactical and strategic weapons by today’s standards.
If that is cold comfort, look at current Chinese doctrine on nuclear weapon employment, and also the Indian and Pakistani doctrine.
Timmy C wrote:
For anti-ship, how would you 1. identify the target and 2. get the Talos to the ship? It seems like the same problem that contributed to the demise of the TASM, where the shooter had no way to discriminate the target at the missile's maximum range…[?]
Using the standards of the day, I do not think that this was the issue it is now; in other words, if it was not a friendly warship, it might well be engaged, particularly if it was emitting enemy radio and radar frequencies.
Targeting by radio detection is adequate in these scenarios. Two, preferably three lines of bearing are sufficient for targeting.
I suspect that the Russian P-800 Oniks has, or creates similar issues.
Timmy C wrote:
If you're really wanting to make it into a dedicated anti-ship weapon, I'd trade range (fuel) for warhead size, keeping it for use in situations where you could actually identify the target and guide the weapon to the target, and maximize the damage that would cause.
Logical!
