bengtsson wrote:
If you assume being at the head of the fleet during the fleet gunnery action is Beatty's role, then he did the right thing. That is the first I have heard about being needed at the head to prevent the German BCs crossing the T. I need to think that over a bit. The British understimated German ship handling skills for sure. The High Seas Fleet was in a trap , but visibility was awful, that fact should have changed Beatty's mind about his role. Putting the High Seas Fleet between the NE Grand Fleet and a NW BC force would insure as far as possible continued contact with the Germans. As it was, Beatty steaming across the front firing and not keeping Jellioce informed about the High Seas fleet's position, battle order and course during this run didn't relect well on Beatty. If it was a fairly clear day, rare in the North Sea, then I can see Beatty getting his depleted force into position at the head of the Grannd Fleet. I have always seen the role of BCs in a fleet action as heavily armed scouts, not Battle Line participants once the BBs are engaged with each other.
I still believe that Beatty should have recognized how bad visibility was and that the day was drawing to a close, getting into a scouting position with a clear field of view would serve the Grand Fleet better I think. The British enjoyed a large superiority ,all that was needed was to keep contact to destroy the Germans. If forces had been more equal, then Beatty would need to operate as a part of the Battle Line.
Bob B.
The visibility was not so awful that Jellicoe's fleet could not see the German battleships should the German battleships perform the normal range of maneuvers thought possible by the British. If the Germans were to continue to run into the grand fleet, or make a sequential turn to escape the grand fleet, then much of the German fleet would remain in view of at least parts of the Grand fleet. Fundamentally, the British did not believe a fleet having its T crossed in the ideal 90 degree manner really could extricate itself from the predicament in a short amount of time. So the notion that Beatty should have anticipated the visibility problem probably does not stand based on what British thought the Germans could do.
Even as the Germans did the historic simultaneous turn to extricate from fleet engagement, the German fleet was still intermittently visible to at least some parts of the Grand fleet. The problem Jellicoe confronted was British tactical plotting is worthless, consequently Jellicoe's staff could not use tactical plotting to integrate the various sighting information reported by various parts of Grand fleet to arrive at an comprehensive and up-to-date picture of the battle. This bottle neck would afflict any report from Beatty, so its highly doubtful that a Beatty in a scouting role could bypass this log jam to add much situational awareness to the Grand fleet. The only thing Beatty might do was to attempt to disrupt German maneuver himself. Again, this call for an interpretation of where Beaty should be that conflicts with other scenarios.
The three problems that defeated Jellicoe were:
1. No effective way to integrate sighting reports from different parts of the fleet to construct a clear picture of the battle when the enemy is out of sight from the flagship. This is less of a problem for Beatty when the enemy is 50 miles away, and an approximate knowledge of enemy location, course and speed is all the tactical information that could be acted upon. This becomes a major problem when both fleets are in close engagement, and you need to know exactly how the enemy fleet is deployed and exactly what each part of it is trying to do.
2. No effective way to establish firing solution based on computed, rather than observed, enemy course and speed. So British gunnery can not engage enemies that are temporarily out of sight. Hence intermittent visibility essentially defeated the British ability to engage the High Sea fleet.
3. Doctrine that overemphasize the threat of long range torpedo attack. If Jellicoe had turned towards the High Sea fleet in a general chase rather than away from the High Sea fleet in an attempt to out run a mere 29 torpedoes that the Germans had fired, Scheer's battle turn maneuver would have failed.
