It is currently Wed Jan 16, 2019 9:11 am
Post new topic Reply to topic  [ 658 posts ]  Go to page Previous  1 ... 28, 29, 30, 31, 32, 33  Next
PostPosted: Sat Oct 07, 2017 7:31 am
Hi Steve,
Does that mean that a 1/700 scale Intrepid SCB-125 Island is within a few days of completion? :woo_hoo:
PostPosted: Sat Oct 07, 2017 8:29 am
Hi Mark,
[edit: Yes, a 1/700 scale Intrepid CVS-11 island, 1968-1973, is now for sale. Cheers!]
Have fun, Monkey around.
-Steve Larsen
Catalogs of over 2000 products for scale modelers:
3D-printed gray resin (best material!) - https://www.model-monkey.com/
3D-printed Shapeways' white acrylic - https://modelmonkey.wixsite.com/modelmonkey
PostPosted: Sat Oct 07, 2017 11:35 am
Hi Steve,
The Yorktown Island works for me. The 1950s Islands will work so I would advise you to not pursue the others in 1/700 scale. Way to much work for not much bang. Another approach would be to make a 1/700 scale pri-fly to convert the 50's Islands that you already offer. That appears from the outside looking in to be a much simpler operation.
They look great though. I am getting back into finishing my 1/350 Kearsarge SCB-27A ship and your Island looks great perched on top of her.
MM
PostPosted: Tue Oct 24, 2017 12:44 pm
Heaven has been smiling on us. Miracle received!
Mark, Christoph, Jodie and others who have been waiting very patiently for a very long time: good news. After considerable effort, the design for a 1/700 scale Essex SCB-125 island has finally passed Shapeways automated tests. The design, for USS Oriskany CVA-34 is getting final tweaks and detailing and may be released later today or tomorrow.[edit: DONE! and for sale]
Its features are specific to Oriskany as she appeared in 1968.
Model Monkey 1-700 Oriskany CVA-34 Island 1968.b.jpg [ 135.84 KiB | Viewed 1724 times ]
Model Monkey 1-700 Oriskany CVA-34 Island 1968.a.jpg [ 143.9 KiB | Viewed 1724 times ]
-Steve Larsen
PostPosted: Tue Oct 24, 2017 2:33 pm
:thumbs_up_1: fantastic Steve thanks for your work !
Best regards
Chris
PostPosted: Tue Oct 24, 2017 5:23 pm
Awesome!! :woo_hoo:
Do you have plans to attempt more in 700th scale? Maybe the three or four of us attempting conversions should start a thread to generate more interest???
As an after thought I was wondering what is your level of effort after you get the first island set up? Do you have to start from scratch for each configuration, Intrepid, Yorktown, Shangri La, etc. or can you leverage the first one to make the subtle changes between the other ships?
I was showing off the 1/350 Kearsarge Island the other day. Quite a piece of art!
PostPosted: Tue Oct 24, 2017 7:10 pm
Steve, you are doing blessed work. My billfold hates what you are doing but, my goodness, are you making so many other things in my life very happy, and making a lot of long-held wishes come true. Thank you for doing all this.
Jodie Peeler
PostPosted: Tue Oct 24, 2017 7:14 pm
Thanks, Jodie and Chris! I really appreciate your encouragement and patronage. Your continued support helps make all this possible so thank you, too, Jodie's wallet.
Well, I didn't get the island done today but tomorrow it will go live.
Mark McKinnis wrote:
Awesome!! :woo_hoo:
Hi Mark, thank you, too!
...Do you have plans to attempt more in 700th scale? Maybe the three or four of us attempting conversions should start a thread to generate more interest???...
Let's see how this one sells before I commit to more Essex islands. There has been very little interest in the Essex islands designed so far, or surprisingly other products for Cold War subjects generally, probably due to the lack of injection plastic Cold War-era ships to put the products on.
After Oriskany, I need to get back to the Forrestals for a little while. Along with you, Mardis Hall is anxiously waiting for one too but in his case it's an Independence island in 1/350. Once Forrestals are done, I'll likely begin designing a Pennsylvania BB-38 1944 superstructure. Many have been patiently waiting for that product.
...As an after thought I was wondering what is your level of effort after you get the first island set up? Do you have to start from scratch for each configuration, Intrepid, Yorktown, Shangri La, etc. or can you leverage the first one to make the subtle changes between the other ships?...
All of the islands share one or the other of two versions of the same basic shape (the two island forms are "extended bridge" and "short bridge" - see rendering of the "short-bridge" version below). Note that the top portion, when viewed from the front, is correctly, slightly tapered. Many kits and aftermarket products miss the taper.
Model Monkey base Essex island form.short bridge.jpg [ 63.04 KiB | Viewed 1655 times ]
When researching the islands, I was amazed to find so many significant differences between ships of the class (differently shaped decks and bridges, different flag lockers, radar platforms, splinter shielding, deckhouses, door and porthole/rigol number and positions, exterior piping, etc., etc., all different, and noticeably so).
So, from that basic shape, the 3D designs are all made differently, some in just a few ways, others more so, in order to capture the conspicuous features unique to each island and therefore each design becomes essentially a new design. Depending on the complexity of the geometry and the availability of references, each island takes between 1-4 weeks working full time to research and design making them very time-intensive subjects and thus very costly to design (time = money).
Model Monkey Yorktown and Intrepid comparison.d.jpg [ 151.94 KiB | Viewed 1648 times ]
Once the design is complete, each design then has to be adjusted to meet printing requirements for the intended scale, meaning a unique design for each scale is produced. This means that there are actually more than one design of any one island. Printing requirements are much tougher to meet for subjects in smaller scales while trying to keep the design looking realistic. So there is an iterative process (adding even more time) in adjusting features until it will pass Shapeways design analysis software checks before being offered for sale. Until last week, the 1/700 Vietnam War-era island did not pass the checks. Once it passed, I was able to start adding all the details, and there are many.
Thanks so much! I'm excited to see your build finished. I think the SCB-27 island on a straight-deck Essex looks so cool.
-Steve Larsen
PostPosted: Wed Oct 25, 2017 1:00 pm
Chris, Mark and Jodie, today's the day. Thank you for your considerable patience!
viewtopic.php?f=16&t=163596&p=727589#p727589
http://shpws.me/P9CU
-Steve Larsen
PostPosted: Sat Nov 11, 2017 5:16 pm
Two related projects in the works that are likely to be complete by December are World War Two-era Essex class islands of two types, a "short bridge" (1943-1944) and an "extended (long) bridge" (1944-1945). They will have open doors, open director tower battle lookouts and accurately shaped open uptakes. These models will be made available in several popular scales.
Here are the designs at about 50% complete.
Model Monkey Essex Islands World War Two at 50% complete.a.jpg [ 194.4 KiB | Viewed 1477 times ]
Model Monkey Essex Islands World War Two at 50% complete.b.jpg [ 197.39 KiB | Viewed 1477 times ]
Model Monkey Essex Islands World War Two at 50% complete.c.jpg [ 188.51 KiB | Viewed 1477 times ]
-Steve Larsen
PostPosted: Sat Dec 09, 2017 7:40 pm
Here's the "short bridge", early war Essex class island design at about 90% complete. More details will be added and some adjustments to what you see here will be made and then the design will be released. The "long bridge", late-war design will be released soon afterwards.
Intended scales are 1/700, 1/525 and 1/400.
Model Monkey Essex class island (short-bridge) at 90 percent complete.a.jpg [ 194.49 KiB | Viewed 1327 times ]
Model Monkey Essex class island (short-bridge) at 90 percent complete.b.jpg [ 194.86 KiB | Viewed 1327 times ]
Model Monkey Essex class island (short-bridge) at 90 percent complete.c.jpg [ 195.13 KiB | Viewed 1327 times ]
Model Monkey Essex class island (short-bridge) at 90 percent complete.d.jpg [ 175.15 KiB | Viewed 1327 times ]
Model Monkey Essex class island (short-bridge) at 90 percent complete.e.jpg [ 197.45 KiB | Viewed 1327 times ]
Model Monkey Essex class island (short-bridge) at 90 percent complete.f.jpg [ 195.35 KiB | Viewed 1327 times ]
Model Monkey Essex class island (short-bridge) at 90 percent complete.g.jpg [ 141.53 KiB | Viewed 1327 times ]
Model Monkey Essex class island (short-bridge) at 90 percent complete.h.jpg [ 187.19 KiB | Viewed 1327 times ]
-Steve Larsen
PostPosted: Tue Feb 20, 2018 1:33 pm
The World War Two-era Essex islands are proving to be popular products. Thank you all!
For those who also enjoy modernized Essex islands, here's the next release, the island of USS Hornet CVS-12 (1969) at about 95% complete.
Further piping detail, whistles and whistle platforms, some tweaks to shapes, and the addition of venturis (wind deflectors) are yet to be added. The island was in this configuration when Hornet recovered the three astronauts of Apollo 11 after their famous mission to put man on the Moon for the first time.
Model Monkey USS Hornet CVS-12 Island 1969 at 95% complete.a.jpg [ 157.64 KiB | Viewed 1037 times ]
Model Monkey USS Hornet CVS-12 Island 1969 at 95% complete.b.jpg [ 203.03 KiB | Viewed 1037 times ]
-Steve Larsen
PostPosted: Tue Feb 20, 2018 8:06 pm
Yes!!!!
PostPosted: Tue Feb 20, 2018 9:37 pm
Thanks for your saint-like patience!
-Steve Larsen
PostPosted: Tue Feb 20, 2018 11:10 pm
Coming down the road. Thanks Steve!
PostPosted: Fri Feb 23, 2018 3:08 pm
Is there a possibility to get the new modern life raft canisters in 1/350, too?
Would need them for a modern Aegis class cruiser.
PostPosted: Sat Feb 24, 2018 8:31 am
Thanks Mardis! I hope the new 1/350 Indy island is a big help to you. Your Beehive Big E is looking sweet.
I would very much like to offer them but so far I regret that sufficient authoritative, dimensioned 2D references from which to make the 3D design have not been found in the public domain. Perhaps someone with good references will see this post and share. I think the canisters would be a big help to many modelers.
Thanks for the interest!
-Steve Larsen
PostPosted: Tue Feb 27, 2018 7:40 pm
A few more details, some final tweaks, and opening the funnel cap and then the USS Hornet CVS-12 island will be done. I hope to release it in 1/350 scale tomorrow or Thursday. Other scales will come shortly after. [edit: Done! Link: viewtopic.php?f=16&t=163596&p=735025#p735025]
-Steve Larsen
PostPosted: Fri Mar 09, 2018 7:10 pm
Here's another model that will be released very soon: a 1944 superstructure for USS Pennsylvania BB-38. The design as of this writing is about 50% complete. The aft fire control tower will be included. An 01 level can be made available for those interested in it and a set of eight 5"/38 Mk.32 mounts is available now, as well as 14"/45 triple-gun turrets.
Thanks to Chad Queen for excellent 2D drawings and Martin Quinn for hi-res photographic references obtained at NARA.
Model Monkey Pennsylvania 1944 Superstructure at 50%.a.jpg [ 150.72 KiB | Viewed 432 times ]
Model Monkey Pennsylvania 1944 Superstructure at 50%.b.jpg [ 145.61 KiB | Viewed 432 times ]
-Steve Larsen
PostPosted: Fri Mar 09, 2018 8:59 pm
1/350 Midway island? What do you know Steve? :whistle: :scratch: :thinking: :twitch:
Users browsing this forum: Lorineheanganismoge and 4 guests
Search for:
