It is currently Wed May 22, 2019 4:10 am
Post new topic Reply to topic  [ 566 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 29  Next
PostPosted: Fri Dec 22, 2017 9:56 pm
also supposedly referred to as north cacalaca if I got the spelling right.
PostPosted: Sat Dec 23, 2017 3:32 pm
Steve, I am glade Martin has provided information on the Nevada 1941 superstructure. Hope you can do a superstructure for it like the Oklahoma 1941 you have planned. When I sent you plans for the Oklahoma I think I recall noting there were a number of differences, but I did not have any plans for Nevada. I do have the Ironshipwright 1/350 Nevada 1941 and it has the different superstructure decks. You can see these differences in photos of Nevada after the PH attack. Looking forward to the 1/700 Oklahoma in the near future and hopefully a 1/700 1941 Nevada superstructure someday. The current, now out of production, 1/700 resin kits for Nevada 1941 are incorrect in depicting the superstructure for December 1941. Have a great Christmas and New Year and I will be ordering some of the Essex islands in a couple of weeks.
PostPosted: Sun Dec 24, 2017 1:04 pm
Thank you so much Frank! I'll do my best.
Your post, David, made me smile.
In other news, a customer asked for a special nameplate be made for a model he named in honor his late father. This nameplate is 3D-printed in acrylic and hand-painted by the customer in colors of his choosing.
3D-printed nameplates are available in acrylic and real metal, too (brass, silver, bronze, gold-plated and rhodium-plated).
Requests for custom names or other text are welcome.
Model Monkey-designed nameplate for USS Bernhard DD 548.jpg [ 393.93 KiB | Viewed 1047 times ]
Have fun, Monkey around.
-Steve Larsen
Catalogs of over 2000 products for scale modelers:
3D-printed gray resin (best material!) - https://www.model-monkey.com/
3D-printed Shapeways' white acrylic - https://modelmonkey.wixsite.com/modelmonkey
PostPosted: Sun Dec 24, 2017 4:52 pm
Hallo Steve
Merry Christmas first of all...and thanks a million for those WWII Essex islands! They look absolutely phantastic! Am I right assuming they are meant for the Dragon kits? TheTrumpeter ones I think are a touch under scale.
Having mentioned Dragon Essex class ships, their details under the overhanging flight deck sections are completely missing! Also, on the long hull version the bow 40mm pits look absolutely toyish! Room for new products...;-)
I am in the market for a Hancock island to start with! :-)
And last but not least, do you know how much a 1/350 island would probaly cost if you did one?
thanks a lot
Uwe
PostPosted: Sun Dec 24, 2017 7:16 pm
Hallo Uwe!
Thanks so much!
I can resize any island to better fit the Trumpeter kits. Please advise how best to get a perfect match. (I have an old Hasegawa kit. Oh that old island, oy!)
I'll rescale some of the islands to 1/350. Once I get one uploaded we'll have a much better idea what it will cost. Is there an existing design you would like to see in 1/350 (Hancock)? I'll start with that one.
Merry Christmas!
-Steve Larsen
PostPosted: Mon Dec 25, 2017 4:23 pm
Hello Steve
Hancock would be great in 1/350...
thanks
Uwe
PostPosted: Tue Dec 26, 2017 4:58 pm
Thanks, Uwe, I'll have the existing Hancock design optimized for 1/350. It should be ready tomorrow pending any "life happens" events.
In other news, a set of 60 US Navy life raft canisters is now available in 1/700 scale and a very slightly smaller set in 1/720 scale. The canisters are very tiny.
1/700: http://shpws.me/PkWc
1/720: http://shpws.me/PkWE
-Steve Larsen
PostPosted: Tue Dec 26, 2017 9:51 pm
Your spoiling the carrier guys Steve! :thumbs_up_1:
PostPosted: Thu Dec 28, 2017 10:09 am
ModelMonkey wrote:
Miguel, I hope this gives you some better options in case the ISW kit is a bit small: Happy to announce a set of Colorado class 16"/45 cal. turrets and barrels designed specifically to fit the 1/350 scale Blue Water Navy and Yankee Modelworks USS West Virginia BB-48 kits. These turrets will also fit the Model Monkey 1/350 scale USS West Virginia 1941 Superstructure.
Turrets: http://shpws.me/PknV
Barrels: http://shpws.me/Pko6
Superstructure: http://shpws.me/P7mI
Happy Holidays!
Again many thanks Steve,but after thinking and planning ,I found for me the best solution is to go with the ISW West Virginia,but wish to ask You a big favor , your BWN Superstructure is simply gorgeous ,how about to make the upper levels only,then will be a perfect replacement for the ISW kit(and cheaper than BWN piece) and is no need to resort in big surgery to the model,then I can use your other pieces like the mast tops, turrets and directors.
No Whine Policy
1.- Modify it
2.- Ignore it
3.- Don't build it
PostPosted: Thu Dec 28, 2017 12:27 pm
Miguel wrote:
Again many thanks Steve,but after thinking and planning ,I found for me the best solution is to go with the ISW West Virginia,but wish to ask You a big favor , your BWN Superstructure is simply gorgeous ,how about to make the upper levels only,then will be a perfect replacement for the ISW kit(and cheaper than BWN piece) and is no need to resort in big surgery to the model,the I can use your other pieces like the mast tops, turrets and directors.
It is very simple for me to provide that for you. But I am concerned that it may not fit the ISW kit well giving you a very expensive unusable part and making for a very unhappy customer.
Let's assume the reason the sample BWN kit provided to me wasn't precisely to scale was because of shrinkage during curing. The BWN master was probably built very accurately, but resin shrinks as it cures, and it does not shrink uniformly. Resin can shrink differently in different directions, how much depends an many factors and conditions.* In other words, the smallness of the BWN kit isn't a simple percentage reduction in size. The sample BWN kit loaned to me was narrow as well as short, but not by the same % fore-aft and side-to-side and vertically, and the shrinkage was not uniform from tip of the bow to extreme stern. Frankly, it was a scale mess most likely due to shrinkage, a common problem for large-scale resin kits. Generally, the larger the resin model, the more it can be affected by shrinkage. Although shrinkage is probably not noticeable to the modeler, it presents considerable problems for vendors trying to design accurately scaled products to fit inaccurately shrunken resin kits.
So the 3D-printed design for every deck and feature had to be adjusted to a different size in all three dimensions, each dimension differently one at a time. The adjustments were extremely complex because of the number of features and the geometry of the sloped vent trunking.
If you lay the 3D-printed design over scale plans, you will see that the upper-most deck and pilot house are essentially 1/350 scale in all dimensions. But as you go down, each deck below gets reduced proportionally until the lowest level is short enough and narrow enough to fit the sample BWN hull loaned to me. The uppermost level had to be to-scale or the BWN photo-etch cage mast wouldn't fit, the cage mast would be too big in diameter because photo-etch doesn't shrink. Which brings up another consideration:
When creating the 3D design, the adjustments not only had to fit the hull, they had to be done in such a way that when the resin BWN model with 3D parts placed on it was complete, the fighting tops would be level on top of the BWN photo-etch cage masts. The 3D superstructure was deliberately designed so that its height would ensure the top of the photo-etch brass cage foremast would match the height of of the BWN photo-etch mainmast (which sits on the hull) so that the fighting tops would be level.
Not knowing anything about the ISW kit, I have no idea if the 3D design intended to fit the BWN kit will provide level fighting tops if used on an ISW kit.
I am happy to offer the 3D superstructure to you without the 01 level if you like. But IMHO, the product might not fit the ISW kit well, noticeably so, and be a waste of your money and time.
Thoughts?
* Even the same two resin model parts pulled from the same mold on different days (different conditions like temperature, etc.) can be differently sized due to the factors affecting shrinkage.
-Steve Larsen
PostPosted: Thu Dec 28, 2017 12:55 pm
Steve ... I really admire your professionalism , Yes , you are totally right ,then lets wait till I have the ISW kit in my hands ,then can have some measurements and figure the best possible path,I still think that my request part has almost non regrettable effects on the kit ,maybe if the ISW has a better proportion vs the BWN ,then You can increase the size a 5% to be more on scale, but after your thoughts ,I better wait for the kit.
Thanks a lot Steve ...Happy New Year and my best wishes
Miguel
No Whine Policy
1.- Modify it
2.- Ignore it
3.- Don't build it
PostPosted: Thu Dec 28, 2017 12:58 pm
Miguel, what is the actual(not scale) length, width & height of the model from the bottom of the hull to the top of the 01 deck?
Steve, that shrink & expansion caused me to redo a drawing I finished doing the previous day back in the early 1980's when I worked as a mechanical draftsman doing full size drawings for the torches to cutout of metal plates for a metal service company. drawing was about 84" wide & over 100" long done on 2 sheets of paper taped together width wise. drawing shrank & expanded by at least an 1/8" all over whereas the tolerance was 1/16". redid that drawing on the lunchroom floor instead of doing it on the drafting table as drawing was too big unless done 1 panel at a time.
PostPosted: Thu Dec 28, 2017 1:12 pm
Thank you, Miguel!
David, yes, easy to imagine you having to do that, and not an easy task!
I usually find that scans of BoGP drawings are distorted differentially, surely some of that is due to shrinkage over time of the original drawings and sometimes simply scanning errors. One might be inclined to believe a set of BoGP drawings can be scanned into a 3D program and the software will pop out a 3D object instantly. It just ain't so.
Due to distortion, even the best, most authoritative 2D drawings have to be adjusted for differential distortion and redrawn using the 3D software one line at a time to ensure everything will fit. This is why it takes a month or so working full time to design a single 3D-printed superstructure.
Next superstructure in the queue: USS Pennsylvania 1944.
-Steve Larsen
PostPosted: Thu Dec 28, 2017 2:21 pm
Sorry David ,I don't have the WeeVee ISW kit , was my plan buying one for a future build ,but really want to take advantage of Steve fantastic designs,with the superstructure,top masts ,turrets and directors, also getting the new printed cage mast from Blue Ridge, I am sure that can improve greatly the ISW kit .
Thanks ,getting a better picture,never thought the BWN was a bit under scaled cause of the shrinkage ,to be honest not too picky about a 5% shrinkage , as commented with Steve ,better to have the kit in hands before making any further request
No Whine Policy
1.- Modify it
2.- Ignore it
3.- Don't build it
PostPosted: Thu Dec 28, 2017 2:57 pm
I saw in your above post after I posted that you didn't have the model yet. when you do, post the dimensions to see what can be done.
PostPosted: Thu Dec 28, 2017 4:12 pm
Excellent David ,thanks man :wave_1:
No Whine Policy
1.- Modify it
2.- Ignore it
3.- Don't build it
PostPosted: Thu Dec 28, 2017 5:02 pm
anj4de wrote:
Hello Steve
thanks
Uwe
Uwe, today is your day! Here is the 1/350 scale design for USS Hancock CV-19, late 1944 through circa April, 1945. This configuration represents her Battle of Leyte Gulf appearance.
This 3D design is intended as a direct replacement for the Trumpeter kit's island which has significant deck shape, splinter shielding and detail errors for USS Hancock in 1944.
Link: http://shpws.me/Plep
The attachment Model Monkey 1-350 USS Hancock CV-19 Island 1944-early 1945.jpg is no longer available
Model Monkey 1-350 USS Hancock CV-19 Island 1944-early 1945.jpg [ 37.51 KiB | Viewed 362 times ]
Model Monkey 1-350 Hancock CV-19 Island 1944-1945.b.jpg [ 222.93 KiB | Viewed 359 times ]
Model Monkey 1-350 Hancock CV-19 Island 1944-1945.a.jpg [ 183.38 KiB | Viewed 359 times ]
Model Monkey 1-350 Hancock CV-19 Island 1944-1945.p.jpg [ 202.96 KiB | Viewed 359 times ]
Model Monkey 1-350 Hancock CV-19 Island 1944-1945.e.jpg [ 243.91 KiB | Viewed 359 times ]
-Steve Larsen
PostPosted: Thu Dec 28, 2017 8:13 pm
Steve
Any chance doing a Lexington CV-16 island 44-45 ?
PostPosted: Fri Dec 29, 2017 2:45 pm
MAJOR-B wrote:
Steve
Yes indeed! Working on 1945 designs now. The Lex vet you know will be happy. In the mean time, there is this to whet your appetite for 3D-printed Lady Lex products:
It is 3D-printed in real brass and can be produced in other real metals including silver, polished silver, brass, polished brass, bronze, polished bronze, 14k gold-plated, 14k rose-gold-plated, 18k gold-plated and rhodium-plated.
For those that like to paint their nameplates or otherwise prefer a much less costly material than metal, these same nameplates can be printed in acrylic.
-Steve Larsen
PostPosted: Sat Dec 30, 2017 5:35 pm
Hello Steve
Thanks a lot for the Hancock island. I will get it very soon...I would like it right now but I just had to hit the button on another subject and hence the island has to wait a few weeks! I was super lucky and snatched an MRC Intrepid 1/350 for just 75EUR...couldn't let that one pass...:-)
thanks a lot and happy new year!
Uwe
Users browsing this forum: Boro and 5 guests
Search for:
