It is currently Thu Apr 25, 2024 9:39 am
PostPosted: Fri Nov 09, 2018 11:59 pm
Classic Airships
Classic Airships
Following on from my earlier post about my upgraded Patriot Missile System (deployed) set, I am pleased to be able to tell you that the 1/700 scale "Convoy" set has received the same treatment. All of the models here are depicted in travelling mode so that they can properly be used for deck cargo or arranged on the quayside awaiting loading. To make the convoy more easily expandable I have split it into two parts:
The PATRIOT COMMAND CONVOY is a six piece set and includes...
1 x ECS (Engagement Control Station) on a M1085 FMTV lwb truck
1 x AMG (Antenna Mast Group) Vehicle, FMTV Truck based.
1 x HEMTT M983 Tractor unit.
1 x Patriot AN/MPQ Radar Set mounted on an M860 semi-trailer.
1 x HEMTT EPP III Electric Power Plant
1 x HEMTT M978 2500 gallon Fuel Tanker
The PATRIOT MISSILE CONVOY is a 12-piece set including...
4 x HEMTT M983 Tractor units.
4 x M901 Patriot Missile Launch Stations.
4 x HEMTT M985 E1 Truck c/w 4-pack missile load.
Once again, as well as the great advantage of not having to cut each model away from a sprue, having each set held within a protective cage means that the printer sees it as one piece and the price is reduced considerably. I think you will be impressed at the value for money each one represents. Have a look HERE at the other models in my military vehicle range.
Happy modelling!
Derek
Patriot Command Convoy six piece set...
Patriot Missile Convoy 12 piece set...
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 31 guests
