ModelFunShipyard wrote:
However I would like to ask you lot, were we to provide printed railings with a bottom plate, would that be better/worse, or an alternative solution to putting grooves for PE railings?
MFSYD - I appreciate your reply, etc. My answer would be that it would be great if the kit(s) would include the waterway in the deck design of the model, as I think this would be appropriate for most, if not all major 20th century combatants. You could also incorporate the chocks (if so desired) into this design, as well since they normally are located above the waterway. Designing the printed stanchions/lifelines may take some time, but in the end, I think possibly an alternative to the PE option. At 1/350 scale, I made those bottom plates 0.1581mm thick, but those will be "evened" once I get back into that design after I have the kit in hand, etc. I may try to make this as "thin" as possible, which may take a few tries...nothing ventured, nothing gained, right?
Since this era of ships had "pointed" ends, I had a similar situation with the BB-55 model at the bow. I made a separate "V" shaped part which worked out well -
In this instance (LEX Class CC's), a similar part could be designed for both ends of the model.
Hope this helps!
