It is currently Mon Feb 19, 2018 11:06 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 02, 2018 11:11 am
:smallsmile:
Well, I'll give the panel line suggestions a try. I'll take some pictures and post before and after versions.
Thanks again for all your responses and suggestions....
Mercurykid
PostPosted: Fri Feb 02, 2018 9:56 pm
Why don't You use dental acrylic filler instead of baking soda ,pretty sure you will have better results since is finer than the baking soda,here is a great info from Paul Budzik using it
http://paulbudzik.com/tools-techniques/ ... resin.html
No Whine Policy
1.- Modify it
2.- Ignore it
3.- Don't build it
PostPosted: Mon Feb 12, 2018 9:55 am
Hello All...
I tried the several methods of restoring panel lines suggested in this message string. After a number of tries on scrap plastic, I found the best results by using Tamiya tape and Squardon green putty.
Using one layer of tape, I carefully ran a strip above and below the existing panel lines and spanned the areas where the lines had been sanded whilst joining the ship hull halves.
My next step was to apply a film of putty over the space between the two tape strips. Allowing the putty to dry for a couple of hours, I pulled the tape from ship hull and found that I had a very close approximation of the original panel line. Some light sanding on the dried putty surface finished the line. When I sealed the hull with primer, each repaired panel line looked quite good.
I tried to take some photos of the process, but my camera just wouldn't show the detail of work I thought necessary.
Regardless, I thank everyone who shared ideas. I tried them and with some modification found the solution to my problem.
Cheers to you all!
Mercurykid
PostPosted: Mon Feb 12, 2018 10:33 pm
Resin Shipyard
Resin Shipyard
Awesome! Thanks for letting us know!
Darren (Admiral Hawk)
Users browsing this forum: Timmy C and 9 guests
Search for:
