It is currently Tue Apr 16, 2024 9:58 am
Post new topic Reply to topic  [ 4404 posts ]  Go to page Previous  1 ... 153, 154, 155, 156, 157, 158, 159 ... 221  Next
PostPosted: Wed Dec 04, 2019 11:03 am
1/350 scale at $50 (US?)!! That would be something seeing that the newest and best 1/700 kits go for at least that much!
:wave_1:
PostPosted: Wed Dec 04, 2019 12:58 pm
Miguel wrote:
pascalemod wrote:
- all we need some early US 1/350 ships to the list in plastic...
All in plastic, all fairly reasonable 50 dollar price range + whatever accessories you want and in good casting quality and accuracy. I think this is a very respectable line up for anyone who likes ships that fought when they could see each other.
NO!!!!
we need IRONCLADS!!!!!
I think he was referring to early American ones....
Would be very cool to have a USS Connecticut or USS Tennessee (the armored cruiser). Or some US Dreadnoughts as commissioned.
With the Viribus Unitus coming out, only Italy and the United States of the major naval powers of the time are totally unrepresented in the 1900-1918 era.
I for one would like to see some South American subjects eventually. Incidently, I did note that Flyhawk's new Agincourt comes with decals for the Turkish and Brazilian versions. That opens up some interesting possibilities.
PostPosted: Thu Dec 05, 2019 1:38 am
Full Hull Agincourt im waiting for as Flyhawk said. But if they just BS about it to turn away pesky questioners, then scratchbuilding will be fun one time down the road. It sure looks like a cool ship and may be even some QE lower hull might fit Agincourt with adjustments. :)
PostPosted: Fri Dec 06, 2019 10:05 pm
Ah, boys, make sure your sitting down before you look at the price of this little baby!
https://www.hobbyeasy.com/en/data/g6rtd ... glzes.html
PostPosted: Fri Dec 06, 2019 10:07 pm
But this looks like a real little gem. And a reasonable price.
https://www.hobbyeasy.com/en/data/0zob2 ... zhu84.html
PostPosted: Sat Dec 07, 2019 11:02 am
There appears to be an error in translation: it's actually 1/72, not 1/700, so it's actually a reasonable price!
PostPosted: Sat Dec 07, 2019 11:01 pm
You are correct is 1/72
https://www.specialhobby.eu/en/our-own-production/special-navy/cv-707-vesikko-finnish-wwii-submarine.html
No Whine Policy
1.- Modify it
2.- Ignore it
3.- Don't build it
PostPosted: Sun Dec 08, 2019 11:26 am
The real submarine can be seen in Helsinki:
http://www.modellmarine.de/index.php?option=com_content&view=article&id=5110%3Afinnisches-u-boot-vesikko-in-helsinki&catid=216%3Amuseumsschiffe&Itemid=1
(click on that page "Link zur Bildergalerie" to see all photos)
PostPosted: Tue Dec 10, 2019 7:00 am
Aoshima is coming out with a 1/700 HMS Jervis!
BobPink
PostPosted: Wed Dec 11, 2019 7:03 am
Just out from Flyhawk
http://www.flyhawkmodel.com/html/xwgg/19/12/2010.html
PostPosted: Wed Dec 11, 2019 10:14 am
It looks like the J class is one of the private ships, not the leader like the Kelly kit. So I am guessing that the Javelin kit should be not far behind.
PostPosted: Wed Dec 11, 2019 10:19 am
I do belive that Hms Jervis was the J class flotilla leader.
PostPosted: Wed Dec 11, 2019 10:25 am
So this is just a combo-pack of HMS Kelly (or Lively), a Sunderland flying boat (from their previous dock set), and one of their Type Vll UBoats. Easy enough to put together if you have the above-mentioned kits in the stash. I suspect it is just a sop to pacify the restless natives until their (Flyhawk) next major release. This is one Flyhawk release I'll pass on.
PostPosted: Wed Dec 11, 2019 10:52 am
The J-class is a modified K-class. The aft deckhouse is smaller than the deckhouse on the flotilla leader Kelly. One set of torpedo tubes were exchanged for a 4 inch AA gun on the J-class none leaders. The aft searchlight platform is a bit different to.
The Vii B u boat has an extra AA platform.
But yes this seems to be a way to get some extra money out of already released kits mixed in with a new kit.
PostPosted: Wed Dec 11, 2019 12:16 pm
PetrOs Modellbau
PetrOs Modellbau
Its a "regular" J, yes. But I will probably get it for my collection ;)
Further kits in preparation.
PostPosted: Wed Dec 11, 2019 1:04 pm
If they release it as an 1120S I might consider it. :roll:
:wave_1:
PostPosted: Wed Dec 11, 2019 1:25 pm
No, the destroyer in this combo pack is not the Kelly because this kit is NOT a leader. The previously announced kits were Kelly (leader) and Javelin (private ship - ie not a leader), allowing both types to be built. If you look at the after deckhouse, note that the gundeck circle around the after gun mount overhangs the sides. Compare that to the longer, wider deckhouse on the Kelly kit. Lively is a totally different kit.
PostPosted: Wed Dec 11, 2019 4:33 pm
All Colossus kits have now shipped to dealers and distributors around the world. Customers outside the USA can expect notices from your dealers shortly.
Customers in the USA can order them direct from the IHP website, but quantities are limited. Guess it's time to order another run!
PostPosted: Wed Dec 11, 2019 6:54 pm
A couple of totally different parts.
:wave_1:
PostPosted: Wed Dec 11, 2019 9:57 pm
:wave_1:
The J, K and N classes were virtually identical to each other with detail differences in armament as the wartime requirements evolved. These ships were 1,760 tons standard, 356 1/2 feet long, 35 3/4 feet wide, with 40,000 SHP. The L and M classes were slightly enlarged at 1,920 tons standard, 362 1/2 feet long, 37 feet wide, with 48,000 SHP. The angular pilothouse at the front of the bridge on the J,K,N classes had a roof that sloped toward the bow. The corresponding pilothouse on the L and M classes had a more flat roof because the front ports had to be higher to see over the larger gun mounts originally designed for the ships. The L and M stack was larger to accommodate the greater SHP. That is more than just a "couple of totally different parts". Very few of the parts are interchangeable between the J/K class and the L class kits.
