It is currently Sun May 11, 2025 11:27 am
PostPosted: Fri Mar 21, 2025 2:20 am
stain or natural wood under the Flight Deck Blue?
PostPosted: Fri Mar 21, 2025 9:33 am
Flight Deck Blue is a stain except on metal then a paint so why have a stain covering a stain?
PostPosted: Fri Mar 21, 2025 7:26 pm
Stained but when not stained it was usually doug fir or spruce and possibly another type of wood. BBs, cruisers and tenders were teak. Nor sure about the submarine deck slats.
PostPosted: Fri Mar 21, 2025 11:39 pm
Carriers used Douglas fir wood for the most part. The only Mahagony wood used was a single plank right next to the tie-downs in the arresting gear area of Essex class. There was Mahagony deck stain that was used before the war, but never on the Casablanca class and likely never on any CVE.
PostPosted: Sat Mar 22, 2025 1:20 am
A one-off, and right on the borderline here... How about the Long Island in July of '41? Photo link for Navsource:
https://www.navsource.org/archives/03/0300101.jpg
Guessing an already badly weathered 5D hull, but might the deck be mahogany with yellow markings? Or is it a blue stain with clean light gray stripes? (Clearly in the time when the F2As are in overall light gray, and they seem to blend in, so possibly?)
- Sean F.
PostPosted: Sat Mar 22, 2025 2:52 am
Thank you for the information, that will be most helpful for my Liscombe Bay build.
PostPosted: Sat Mar 22, 2025 9:20 am
CVE-90 USS Thetis Bay Booklet of General Plans (1945) https://archive.org/details/cve90bogp1945v3
PostPosted: Mon Mar 24, 2025 7:56 pm
Most of the carrier BOGPs had some sort of note for decking, but for some reason none of the Casablanca BOGPs I've seen (including Thetis Bay's) have any mention of wood. Closest I was able to find was Chenango of the Sangamon class:
https://archive.org/details/cve28bogp1945
PostPosted: Mon Mar 24, 2025 9:07 pm
I already have that 1 plus 7 others both complete & incomplete for 5 escort carrier classes saved on my computer. so mostly likely Douglas Fir was used on the escort carriers.
