It is currently Sat Feb 16, 2019 1:59 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject:
PostPosted: Wed Mar 01, 2006 7:17 pm
I look forward to seeing your progress on the carrier, I am working on my first carrier now and although Im not building the one I had wanted, I am enjoying it very much.
I have been hearing about a type of plastic sheet for about 10 years now called sintra (I think it is called) and it looks like ABS sheet but it is much lighter and in-fact it floats!
I am using 1/8” sintra for the flight deck and it seems to be perfect for the job, I like the way it cuts and sands, it takes ca glue very well and can be painted easily.
I have had the boat out running about ten times now in the warm southern California sun and it has held up just fine!
I plan to plank over it with 1.5mm wood decking and I would not be surprised if with all the added detail along the deck edge and the small island attached, that this might just float incase of some unforeseen event.
This stuff is PVC foam board and Im sure it could be found in the UK!
I just wanted to mention this stuff because of how nice it is and how perfect it has been for my carrier.
I wanted to build the WW2 enterprise or the Zuikaku but settled on the much more compact Bogue class Copahee CVE 12.
David Manley
P.S. any chance of seeing some corsairs on your ship?
David Manley
Scratch builder of model ships in 1/96 scale!
Owner of Small World Models!
Lover of life!
And over all bad influence!
 Post subject:
PostPosted: Wed Mar 01, 2006 7:43 pm
I am not sure yet what I will use for the flight deck, but I will more than likely use 4mm Birch Ply, with under deck bracing beams. I have an 8 foot x 2 foot sheet of this and I like working with wood rather than plastic.
Not sure about the planes as yet, but I prefer the British aircraft, rather than the American. I rather like the Swordfish and Hurricanes, but again I have not got any definate plans at the moment. I could model this ship in any period from built to 1955. After that period, she was lengthened and had her angle deck fitted. The hull I have is the straight deck version.
 Post subject:
PostPosted: Wed Mar 01, 2006 9:22 pm
I understand about the planes, the corsairs might look a bit out of place; I just like them a lot!
Maybe some spitfires!
David Manley :big_grin:
David Manley
Lover of life!
 Post subject:
PostPosted: Thu Mar 02, 2006 6:24 am
Victorious had quite an interesting carreer and flew many types of aircraft during her lifetime.
She started with the trusty old Fairey Swordfish in 1941 and ending her days in 1968 with the Buccaneer Mk2 and Hawker Siddeley Sea Vixen.
She was on loan to the U.S. Navy during 1945 as U.S.S. Robin and returned back to British control after hostilities ceased.
She went into dockyard hands in 1950 for a major modernisation, costing £20,000,000. and recommissiond in Feb 1958 having been lengthened by 40 ft and given an angle deck.
Here is a list of the aircraft she carried throughout her career.
Fairey Swordfish Mk 1
Fairey Albacore Mk 1
Fairey Fulmar Mk 2
Grumman Martlet Mk 1V
Hawker Sea Hurricane Mk 1B
Supermarine Seafire Mk 2C
Grumman Tarpon Mk 1
Fairey Barracuda Mk 2
Chance Vought Corsair Mk 2
Supermarine Walrus Mk 2
Westland Drangonfly HR 5 (Helicopter)
Wesltand Whirlwind HAR 3 (Helicopter)
Westland Whirlwind HAS 7 (Helicopter)
Douglas Skyraider AEW 1
De Havilland Sea Venom FAW21
Supermarine Scimitar
De Havilland Sea Vixen FAW 1
Fairey Gannet AEW 3
Fairey Gannet COD 4
Blackburn Buccaneer S1
Westland Wessex HAS 1 (Helicopter)
Hawker Siddeley Sea Vixen FAW 2
Blackburn Buccaneer S 2
Quite a list to choose from when it comes to modelling.
 Post subject:
PostPosted: Thu Mar 02, 2006 6:37 am
like me and my carriers they will get finished anyway good luck with that :woo_hoo:
 Post subject:
PostPosted: Thu Mar 02, 2006 10:45 am
Your list is a bit shorter if you are not doing the angled flight deck version. Personally I love the Buccaneer, those things used to part your hair when they did mock attacks.
 Post subject:
PostPosted: Thu Mar 02, 2006 6:18 pm
Victorious, check this link as was 43 not 45 when served with us navy in pacific & was not renamed uss robin as was a minesweeper already named uss robin. http://forum.axishistory.com/viewtopic.php?t=72717
 Post subject:
PostPosted: Thu Mar 02, 2006 6:30 pm
That was interesting to read, probably the Call Sign Robin, was the reason it got called the Robin, but obviously she sailed under her own name. Thank's for pointing it out :thumbs_up_1:
 Post subject:
PostPosted: Thu Mar 02, 2006 6:32 pm
Did you notice she sailed with the NORTH CAROLINA, :lol_3: :lol_3: :woo_hoo: :thumbs_up_1:
Simple but effective.
 Post subject:
PostPosted: Thu Mar 02, 2006 6:42 pm
Yes I did Ron. Sometime in the future when Vic is built, we will have to have a reunion with your North Caroliner and my Victorious. :thumbs_up_1:
I had the hull on the bench today and have fitted the keel in position, bonding it to the hull base with epoxy filler paste. It was cut from a length of pine and is 1" deep by 5/8"" wide. I put anchor screws near the keel base, every six inches on each side, with 1/2" protruding, these were then covered with the filler to the hull base, allowing the keel to be firmly stuck down. The next job will be to put in some frames, using 1/4" ply.
See new topic for continuing build reports
Scratchbuilding H.M.S. Victorious in 1/96 scale for R/C
Search for:
