It is currently Thu Sep 04, 2025 12:14 am
Post new topic Reply to topic  [ 10 posts ]
PostPosted: Thu Mar 07, 2013 7:57 am
I'll start off with a question. I have been collecting 1/1250's for a while now. I usually just put them on a cabinet shelf for display. How do you all do it? Do you stick them on a base? I am considering painitng a thin piece of plywood sea blue to use as a base. Your ideas more than welcome.
ELAURENS
PostPosted: Thu Mar 07, 2013 2:24 pm
Online
I don't work in 1250th, but I can easily imagine a smaller version of Jim B's 1/700 display cabinet w/seabase for each model would be quite effective: viewtopic.php?f=12&t=16218
PostPosted: Thu Mar 07, 2013 2:45 pm
Either
1) a wood base in full hull or
2) "afloat" at water level on simulated water.
Here are previous posts on the both topics. Hope they help.
viewtopic.php?f=4&t=150089
viewtopic.php?f=28&t=111727
John
Currently on the bench:
- Revell 1/720 USS Enterprise CVAN-65 ca.1968
http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=146736
PostPosted: Thu Mar 07, 2013 2:49 pm
Oh yeah, here's my 1/1200 Enterprise "on water"
John
PostPosted: Thu Mar 07, 2013 3:29 pm
Thank you for your replies John and Timmy C. I do agree they look better "afloat". I will have a go.
Very grateful
Elaurens
PostPosted: Thu Mar 07, 2013 4:39 pm
Online
Good luck! And if you're looking for watermaking methods, give this thread a try: viewtopic.php?f=4&t=37923
PostPosted: Thu May 16, 2013 4:29 pm
I do it like this:
PostPosted: Thu May 16, 2013 7:52 pm
Back-Aft Models
Back-Aft Models
Plastruct makes a thin clear (and blue) textured plastic sheet (two sizes) called "Agitated Water" that could work very well for open ocean seascape in 1/1250. You can cut it to size and spray / airbrush it and seal it with a gloss coat.
Painting it from beneath doesn't work so well. You get little, tiny black/dark dots that show through. An odd effect.
http://plastruct.com/Pages/OnlineCatalogIndex.lasso
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
PostPosted: Fri Aug 23, 2013 2:36 pm
This Flickr link will show you various harbour situations in 1:1250 scale.
http://www.flickr.com/photos/42270887@N03/sets
PostPosted: Mon Aug 26, 2013 9:21 am
Super Dios!
Jack
