Next come the doors/shields on the front of the mounts... this is optional depending on what you're building and/or your concern for accuracy, but I would recommend doing it if you're not sure because doorless quads look a bit TOO detailed to my eyes and that might actually work against you on a finished ship... if the rest of your model isn't up to that level of detail the quads will stick out like a sore thumb.
Anyway, carefully scrape off the detail surface with a chisel xacto blade... look out for all that easy to damage/break off detail around the sides of the mounts and take your time.
Then glue the doors/shields on. Use CA... Tamiya plastic cement doesn't like Veteran resin and won't melt it for a good bond.
Next put the rail on the back of the gun... again be careful as it's delicate and make your folds against some kind of clamping device. The fold points are etched out so it's not too hard but it's easy to mess them up otherwise.
After that comes the semi-circular shell chutes. It just so happens that a xacto knife handle is the perfect size for shaping them (don't be dumb like me and leave the blade in while you do it though!) although any round object of similar circumference will work too.
Hold the PE piece parallel to the rod on one end with you thumb and just roll your finger across the PE...
... and glue em on. Notice there is a little "T" joint on one side of the PE, that goes up!
Now, here's how to get the crew chairs on without going crazy... install them upside down from the instructions:
I think this is a mistake on Veteran's part... the folds are on the wrong side of the PE and the foot pedals consequently break off too easily. Instead, put the circle in the seat down... it matches the corresponding molded resin spot where you glue the seat on and the real guns didn't have big circles in the seats either.
Fold up the backrest only, then glue them on.
You will have to trim the side strut a little on the right seat (in the picture), BTW... dry fit first! It's easily cut to length with a razor blade.
After the glue has cured, you can then bend the footrest up and push the footrest bar down to the proper angle...
Next on the list are the elevation cranks... you would be forgiven if you passed on them because they are the definition of tiny fiddly PE:
But if you do, you might be called a "wimpy little girl" when your ship is on display at IPMS NATS.
they aren't as scary as they look... jut bend them the right way (fold in from the etched folding line, although the crank handle needs to fold the other way)
Don't forget the little center step:
And now the shield:
This one is a bit tricky to fold... you have to clamp it or you will mess up the front of the shield (the thin strips between the edge and the outside sight channels won't bend right.
If you don't have a PE clamp, you can use a safety razor held down into the etched bending line while lifting up on the side piece:
... then make the second bend on the side piece:
do the other side and glue on the central crossbraces:
Finally, glue the shield to the mount at the etched side tabs, 1 side at a time:
Final round, coming up...
