Hey folks,
got a question regarding some bigger PE pieces like bulwarks. There are some AM companies like Flyhawk, LR or Five Star, that include some complete bulwarks that go straight on the plastic walls after cleaning the later completely from any plastic detail on them. Now, I know the theory of applying PE parts with either CA glue or white glue, or even the combo of those but sometimes using CA glue for example doesn't give you enough time to properly place the PE piece onto plastic when accuracy of less than a mm is needed for a 1/700 piece. Would a thin layer of white glue that could provide extra time for adjustments secure the PE onto plastic permanently? And maybe after that was dry, some extra application of CA glue with a thin needle would finally finish the job? I know I may already answer my question but I was wondering if there is any specific tip or idea I'm missing to add in this procedure.
These PE pieces looks super nice when finally applied correctly, transforming the bare plastic to the real thing, but I find it so difficult to do them without messing with pools of glue or a badly placed bulwark that after messes with my will to even bother to finish the project on hand, killing all the fun.
Any tips would be much appreciated
