It is currently Tue Oct 19, 2021 7:32 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Mon Apr 21, 2008 5:33 pm
David Griffith wrote:
I've been trying to persuade people to use "Caenis", made by Uni-Thread for about a year now.
David Griffith
Well, David I'm convinced!!!...I purchased a few rolls Uni-Caenis from J. Stockard Fly fishing and I like it!...I made two test "masts & yardarms" out of .050" styrene rod and found it attaches well with the gel-type CA I use...I can also get the thread taught with not much tension at all.
I've been useing "hair" from a Halloween mask for my rigging...but it looks like the mask goes back in the attic!
mike mccabe wrote:
I tried the caenis stuff, I found it hard to attach and harder to cut once attached, even with a brand new scalpel when attached to yards it took more force to cut the thread than the yard would take, I ended up cutting with nail scissors. I still much prefer sprue for ease of attachment and removal of excess.
Mike
Mike,
Try useing nail clippers!...I found if they are new, they will cut the Caenis with no problem!...I keep a "new" pair of clippers just for trimming rigging thread.
Dave :wave_1:
PostPosted: Tue Apr 22, 2008 5:42 am
Got my camera back so I thought I'd post some pics of my test rig of the Caenis thread.
Dave :wave_1:
PostPosted: Mon May 26, 2008 11:35 pm
thanks much for the tips in this thread. i've been trying to use fine wire that i harvested from a power cord that crapped out... and doing so with no success (which is why i've become discouraged with my nimitz model and put it aside). maybe i'll give it a shot again with the fly fishin' thread.
PostPosted: Thu Jun 12, 2008 5:49 pm
At David Griffith's suggestion I ordered some Caenis thread, and although I haven't tried it yet, I think it's going to be perfect for 1/700 scale ships. It's the finest thread of any kind I have ever seen!
I ordered mine from J. S. Stockard (http://www.jsflyfishing.com) on a Tuesday and it arrived in the following Thursday's mail! Excellent service. I highly recommend them.
Thanks to David for this excellent idea.
PostPosted: Sun Mar 15, 2009 6:59 am
Just received my order for this Caenis line. Very cheap from the US supplier recommended on this forum - $6.35 for one reel clear and one real black, including mailing to UK! Haven't tried it yet but looks good. Compared it with what I've used before which is CARPTEK 0.1mm, 2ib 5oz/1.07kg breaking strain, and 100m of it. Got it from a local tackle shop. Wasn't cheap - think it might have been about £7. Can't visually detect a lot of difference between it and Caenis. I will let you know how I get on with Caenis.
Regards, Chris
"When there is nothing but ambiguity and hard evidence is lacking, trust your judgement, instincts and hunches."
Diana McLain Smith
PostPosted: Thu Jan 21, 2010 1:07 pm
mike mccabe wrote:
I can't see the advantage to using the fishing line at all, it's just much harder to attach and cut, sprue can be stretched just as thinly, and personally I find it easier to attach and remove waste. Sorry but I'll be sticking to the sprue method, works for me personally.
Mike
Sprue is great, but it has two major disadvantages. First - it's hard to make multiple pieces all the exact same size. (In 1/700 a millimeter is a chasm) Secondly, it is extremely fragile. The caenis thread I've recently started using requires a different method of installation, but once you figure it out, is much easier to use. All the pieces are the same size and the thread will not break (or at least won't break until long after the model does).
David
PostPosted: Mon Sep 13, 2010 6:52 am
David you seem to be developing quite a few converts. Including myself :)
"The vast majority of Iraqis want to live in a peaceful, free world. And we will find these people and we will bring them to justice."
Washington DC, 27 October, 2003. President George W Bush
PostPosted: Mon Sep 09, 2013 9:27 am
I just ordered a spool of the Caenis Thread myself. I think it'll work out well enough for my purposes.
-Shane
Dallas, Tx
Working on: Revell 1/426 USS Arizona BB-39
In the Stash: USS Arizona 1/700 Dragon Premium, DKM Bismarck 1/700 Dragon Premium, Admiral Graf Spee 1/700 Trumpeter, & Prinz Eugen 1/700 Trumpeter
PostPosted: Fri Sep 20, 2013 5:43 pm
For anybody considering using monofilament fishing line, a WARNING. A few weeks ago, I was about to finish a 1:64 model of a Gato sub. It was a commission, which is the reason for the strange scale. Anyway, I had rigged all of the lifelines using actual wire, and the last thing that I needed to do was install the radio antennas. There are two of these on the port side and one on the starboard side, and they extend from a pair of outriggers on either side of the bridge to a mast near the back of the deck. On a model this size, that makes them something like 18" long. I did not want to use wire -- too hard to "tie" to the insulators. So I used 6 pound test fishing line. It worked beautifully, and I was very proud of the model, and delivered took it to be cased and crated for shipping.
A couple of days later, I learned that the person casing it had come into his shop and found the port antenna lying on the deck, with the outrigger snapped off. At first, he thought someone had bumped it, but when he went to glue the outrigger back on, the antenna lead would not reach. It seems that the difference in temperature between my shop (air conditioned) and his shop (not air conditioned) had caused the monofilament to shrink. The 18" antenna lead had shrunken almost an inch, and had put enough force on the outrigger to snap it clean off.
That's a 5% shinkage.
The solution was to replace the antenna leads with silk suture cord, which he had in his shop. He cut away the mono filament, glued the out rigger back on and installed the new silk line. The model was fine after that, and has been delivered to the client, who was very happy with it.
The moral of the story is that mono filament MAY be be to use as rigging for very short runs, particularly if it will have some slack in it. But if you are using to rig anything longer than an inch or so, you might want to try something different. I am sure that different types of monofilament have different shrinkage rates, but from now on I plan to avoid it altogether and go with either wire or silk.
Vince McCullough
PostPosted: Sat Sep 21, 2013 8:57 am
I love the Uni-Caenis thread. I first heard about it in David's book and I'm hooked on it. I used fly fishing tippet previously but the black is much better in appearance.
The main product of Mucilage glue, Elmers, stopped producing this glue a few years ago and the supply has vanished. It is wonderful stuff as it dries clear and flat and shrinks down. It was also great for attaching figures. I've been using Gator's Grip glue now and it works very well. Used sparingly it also shrinks down and holds very well.
Once I get all my lines attached I use smoke from an incense stick to tighten the lines. You literally just let the smoke flow up through the rigging and it draws tight.
I would love to find something like this in a brown color. Does anyone have any recommendations?
Dave
PostPosted: Thu Oct 25, 2018 1:12 pm
Sorry for dig up a old thread. I currently have a little bit of trouble to tie the copper wire on the mast , also to the the glue it down too. Reading Mr.Griffith book, i plan to get a caenis thread , 70 denier for my 1/350 ship, but i still on the fence between it and a Infini rigging line product. Does anyone use both of them yet ?
PostPosted: Thu Oct 25, 2018 1:58 pm
I have both materials and they behave differently.
The Caenis is still a great choice. It’s also available in white which is nice for signal flag halyards. Once the line is in place you stretch it tight by applying heat.
The Infini line is very nice to work with. It tends to be a little flat instead of round but you won’t really notice it. The best tip I ever received on working with this line is to put a small touch of CA glue where you want the line to go. Soak the end of the Infini line in CA Accelerator. Then attach it to the where you put the CA glue. Hold it for a couple of seconds and you are done! This can work with other lines but the Infini (or Lycra thread) lines really work well with this technique. The Infini or Lycra thread seems to hold up really well over time as well.
If I were picking one over the other, I would pick the Infini line.
Good luck!
Dave
PostPosted: Fri Oct 26, 2018 1:33 am
Good luck!
Dave
Thank Dave, i decide to get a Infini 40 denier for my 1/350 first, i will try to get a Ceanis 20 denier on later date
PostPosted: Fri Nov 02, 2018 7:17 am
Also i want to ask abit about the glue that attach the line , i just not able to find mulicage here, but there is plenty of water glue, clear glue that for stationary use . Can i use them instead or dilute PVA glue to glue down the line ?
Users browsing this forum: No registered users and 13 guests
