It is currently Sun Jan 20, 2019 8:54 am
Post new topic Reply to topic  [ 631 posts ]  Go to page Previous  1 ... 25, 26, 27, 28, 29, 30, 31, 32  Next
PostPosted: Tue May 16, 2017 6:44 am
Hi Red,
I thought about using a Trumpeter 1/350 JFK or KH to do a Ranger. At least the hull below the hanger bay would be correct. Well, correct enough. $200 for a hull is a bit pricey though. I still have so many projects to complete that Ranger will have to wait.
PostPosted: Wed May 17, 2017 9:14 pm
I also thought of getting another Kitty Hawk to make CV-62. But that would take a lot of work. I don't know if America and Kitty Hawk comes out great. Will see.
PostPosted: Mon May 22, 2017 9:14 pm
Image It can be done. J.F.K hull is being used.
PostPosted: Sat Jun 17, 2017 9:36 pm
The elevators openings the same size as the Forrestal and Kitty Hawk?
PostPosted: Sun Jun 18, 2017 5:13 am
I am not sure. I will drag out my 1/350 scale Ranger plans and take a look to do a comparison.
PostPosted: Sat Jun 24, 2017 7:55 am
Could someone let me know what the color number is for the 'red' antifoul for USS Constellation please. As she was in 2003.
Regard
Pawly.
Hindsight always trumps forethought..............
PostPosted: Sat Jun 24, 2017 9:19 am
Regard
Pawly.
Hi Pawly,
I use Tamiya Spray "Dull Red" TS-33. I was quite pleased by the way it turned out on my JFK.
Good Luck,
Mark
PostPosted: Sat Jun 24, 2017 6:43 pm
Thanks Mark,
I'll need to get a few litres of it as it is for my 1/72 model of Connie.
Regards
Pawly
PostPosted: Sat Jun 24, 2017 7:33 pm
Whoops!
I forgot the scale of your project! Well, in the states you can take a color sample to a Hardware Store and get it matched for a couple of gallons of house paint. Wonder if that would work?
If so, get a can of the Tamiya Dull Red, spray it on a sample of the material you used on the hull, and have them match it. It might work?
Good luck,
Mark
PostPosted: Tue Jun 27, 2017 8:28 pm
Did you find out Mark about the openings?
PostPosted: Wed Jun 28, 2017 8:46 am
Hi Red,
Assuming that everything is scaled correctly, the Ranger opening is 5.5cm and the Kitty Hawk kit is 6cm. When I lay the hull of Kitty Hawk over the plans they line up so I think that is a correct assessment.
So there you have it.
Mark
PostPosted: Wed Jun 28, 2017 7:59 pm
So does that mean your taking on that massive project with hull you have? :thumbs_up_1: :heh:
PostPosted: Thu Jun 29, 2017 5:18 am
gtbred, it is a rather big model. I will be getting her belly wet for leak testing in a few weeks. I hope to have the hull and all openings done and painted by this time. I will post pictures when this has happened.
PostPosted: Sun Aug 06, 2017 2:09 pm
Hi Red,
Mark
Thanks Mark, maybe after Labor Day I will make my mind up to get a kit to make Indy.
PostPosted: Sun Aug 13, 2017 6:13 am
Hello all
I got a 1/720 Indi yesterday second hand for cheap and started to have a look/go on her last night. Looking at pics it seems like Italerie was aiming for an early 80ties look...not exactly sure though. What really strikes me is that the island seems not to be even vagely close to the real thing. The port side especially does not seem to look like on any real Forrestal class carrier. Are there any conversion kits out there to address that? I checked Steve's (modelmonkey) site but he does not cover the later carriers...so no quick and easy 3D island! :-( Any help would be highly appriciated...also links to potential build threats and how others fixed those issues...
thanks
Uwe
PostPosted: Sun Aug 13, 2017 6:49 am
Hi Uwe,
Forrestal islands (Ranger and Saratoga) coming soon.
Have fun, Monkey around.
-Steve Larsen
Catalogs of over 2000 products for scale modelers:
3D-printed gray resin (best material!) - https://www.model-monkey.com/
3D-printed Shapeways' white acrylic - https://modelmonkey.wixsite.com/modelmonkey
PostPosted: Mon Aug 14, 2017 5:04 am
Hello all, here is a link to pictures I have taken along the way so far. It has been a little slower than I had planned but as most people know, life is full of choices, surprises, sickness, etc, etc.
Comments welcome as is advice.
I am still working on how to post pictures, I hope this works.
http://s1044.photobucket.com/user/Pawly05/library/Connie%20build?sort=3&page=1
PostPosted: Mon Aug 14, 2017 6:51 am
I've long interpreted the Italeri kit as kind of a composite Forrestal-class ship in the 1977-1980 range, prior to SLEP modernization. That time period may not necessarily match the aircraft you get in the kit, but it squares with the ship's configuration as best I can find.
These kits have their slip-ups and clumsy areas (a catapult track that runs over onto an elevator?), but overall they look fairly good and if you do homework on the particular ship you want to build the Italeri kit is a good basis. I have one upstairs that I am very, very slowly turning into Forrestal as built, and a long time ago I built one as Independence in the 1970s, and if you make a few corrections and add some photoetch the kit dresses up really nicely.
I know Model Monkey has some parts in the works and when those become available it'll make turning the Italeri kit into a showpiece a lot easier.
Jodie Peeler
PostPosted: Fri Aug 25, 2017 8:08 pm
Gregg from Shapeways e-mail me. The America island in 1/720 came out great. He will be able to upscale the island soon to 1/700 and 1/350. Perfect for my build. :woo_hoo: :thumbs_up_1:
PostPosted: Sat Aug 26, 2017 1:59 pm
Hi
Is there a link to the 1/720 America island?
thanks
Uwe
Search for:
