I thought I'd share my idea with the group to see what people thought and if there was any evidence out there to support or counter it.. I'd be grateful for any feedback
My idea is that the block used to raise the forward boat boom (part C39 on zvezda's model) is attached to a kind of "mast" rather than to something just attached to the deck.
I thought of this when I was trying to find the width of the captain's cabin and found that using the rear edge as a reference it seemed to be wider than the navigation bridge and almost the same width as the chart room.
http://www.mediafire.com/imageview.php?quickkey=6i2klgwmno0&thumb=4
But on other views the underside of the deck was clearly visible where the walls of the cabin should be to the extent that it was actually narrower than the navigation bridge.
Then I noticed that there apears to be something to the left of the captain's cabin, painted black, just behind the man's head, which looks as if it could be a continuation of the rectangular piece of metal that the block is attached to. It is in roughly the correctposition and is roughly the correct dimensions.
http://www.mediafire.com/imageview.php?quickkey=bdmdptnac2j&thumb=4
I am suggesting
1 There were "masts" that ran from the block on the searchlight platform b29 to the conning tower deck b26
2 the captain's cabin was built between the "masts" and
3 the chart room walls are built around the "masts" and are thus covering them.
There is something suggested on the builder's plans for Borodino, but it is not clear.
http://www.mediafire.com/imageview.php?quickkey=0vxobxtm1lm&thumb=4
I have coloured the captain's cabin=green, chart room=red and what I think could be the "mast"=blue to try to make it a little clearer.
http://www.mediafire.com/imageview.php?quickkey=6n20jlgy1sb&thumb=4
http://www.mediafire.com/imageview.php?quickkey=82e3zyb2mg2&thumb=4
or
http://www.mediafire.com/imageview.php?quickkey=6akygnucxlv&thumb=4
and
http://www.mediafire.com/imageview.php?quickkey=4mtlam22gg2&thumb=4
I feel this could be a possibility because there is a huge force being exerted on this block because of
1 the weight of the huge boom (part c24)
2 the weight of a boat, which is muliplied 2-3x by the leverage of the huge boom.
There doen't seem to be any visible means of support for part c39.
In Suvorov, AlexIII and Slava, this block is integrated into a deck support which runs from the searchlight platform (part b29) to the conning deck (part b26) and is supported by massive braces. Borodino has none of these braces.
The model of Borodino in St Petersburg shows what I am trying to esplain fairly well and is the only supporting evidence so far.
What do people think and is there any evidence out there please????
http://www.mediafire.com/imageview.php?quickkey=7tm9g03brmn&thumb=4
