It is currently Tue May 13, 2025 4:09 am
Post new topic Reply to topic  [ 178 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
PostPosted: Wed Oct 13, 2021 9:12 pm
ModelMonkey wrote:
bioshock73 wrote:
What exactly is the upper rear facets? Is it the rectangular extensions on top of the turrets? Because I see them on all the secondary turrets.
The rectangular extension you see on the tops of the 5" mounts is the gun captain's blast hood. Below is a photo of a last hood on a museum ship.
Do the 5"/38's that you make have the blast hoods? And is there an option for those who might wish to use metal barrels like you do for the twin 5"/38's.
PostPosted: Thu Oct 14, 2021 8:20 am
Good news, the models have been modified to remove the barrel and include the gun captain's blast hood. I'll post photos of the actual models after the updated design has been printed; all of our printers are presently fully engaged printing customer orders so the new models will get their turn in one of the printers later today or tonight.
In the mean time, below are some renderings of the updated models. The set includes:
- 6 double-knuckle mounts
- 2 double-knuckle mounts with rear facet
- 2 single-knuckle mounts with rear facet
Link to this set in the catalog: https://www.model-monkey.com/product-pa ... cal-mounts
Model Monkey 1-350 Idaho BB-42 5in38 Mounts no barrels a.jpg [ 213.49 KiB | Viewed 3998 times ]
Model Monkey 1-350 Idaho BB-42 5in38 Mounts no barrels b.jpg [ 166.4 KiB | Viewed 3998 times ]
Have fun, Monkey around.™
PostPosted: Fri Oct 15, 2021 1:55 am
Even though I haven't ordered to Idaho kit, I just ordered the set of 5"/38's and 14"/50 turrets and barrels.
PostPosted: Fri Oct 15, 2021 1:13 pm
Thanks so much!
Here are your new 5"/38 mounts:
PostPosted: Fri Oct 15, 2021 4:03 pm
Just noticed I was logged out somehow when o wrote that.
PostPosted: Fri Oct 15, 2021 4:08 pm
ModelMonkey wrote:
Thanks so much!
Those look great! Now I have to see who currently has the 5" barrels in stock.
PostPosted: Fri Oct 15, 2021 9:17 pm
Thanks, Dave! I did find some at spruebrothers, though.
PostPosted: Sun Oct 17, 2021 5:07 pm
Anyone know which version of the quad 40mm mk2 the Idaho had? Mod 1 or 2?
Some aftermarket parts have a mod 1 or 2. Both unshielded.
PostPosted: Sun Oct 17, 2021 7:59 pm
Ok. Thanks. I couldn't seeing any difference between the two aftermarket setups. So it doesn't really matter which one I get.
PostPosted: Tue Dec 28, 2021 10:39 pm
Jeff Sharp wrote:
More New Mexico class fun.
This is probably the last photograph ever taken of USS Idaho wearing MS-12. She arrived in Norfolk on Dec.17, 1941. On Dec.30, 1941 eight tugs moved her from berth 29 to drydock #4. While in drydock her transition into MS-12 mod commenced.
In this photo dated 12/30/41 you can see her MS-12 camo on her hull and 4 of the 8 tugs assisting her to drydock #4. It appears that all four of the visible tugs were from the Wood Towing Corp. Notice also the stern of USS Mississippi can be seen in this shot.
I was able to find another photo from Dec. 30, 1941. This one was taken moments before the shot above. Most of USS Idaho is covered by smoke but you can still see the MS-12 camo on her hull and a little detail on the main deck. The tug facing the camera is YT-213. Behind her is YT-17. The tug on the right is the same tug from Wood Towing Corp as seen in the other photo.
PostPosted: Wed Dec 29, 2021 9:31 am
Found this image and caption posted on the Battleship Cove Facebook page.
December 1949: This image at the Norfolk Navy Yard shows mothballed USS Massachusetts with gunnery training ship (and former battleship BB-41) USS Mississippi.
Image: Fair use from the Francis C. Pogue collection via the Virginia Beach Public Library.
PostPosted: Wed Dec 29, 2021 3:12 pm
DavidP wrote:
Martin, do you have a larger copy of that image I can have?
I downloaded it direct from facebook, so that's all I've got. Maybe the Virginia Beach Public Library has a better copy?
PostPosted: Sun Jan 16, 2022 9:22 pm
The Idaho had 21-inch twin bollards along with 18 open and 2 (maybe 40 closed chocks. Were the chocks 21-inch as well? I am leaning yes. That would put each chock at 3mm (length) x 2mm (height) x 1mm (width) in 1/350 scale. I had to use metric instead of inches because of how small the dimensions are. My search continues for chocks to put on my Idaho kit. I haven't found the size I need as of yet.
PostPosted: Mon Jan 17, 2022 12:14 am
DavidP wrote:
what is the matter with the kit's chocks if supplied?
It doesn't have any.
PostPosted: Sat Jan 22, 2022 2:54 am
Anyone have a good picture of the whale boats used late war?
PostPosted: Thu Sep 15, 2022 1:45 am
Hello everone
Because i woukd like to design paper model of uss Idaho i would like to ask where can i find hull body lines.
Thansk for help
Chris
PostPosted: Tue Dec 27, 2022 10:27 pm
deleted
http://www.lewiscrowauthor.com
Last edited by ArmchairAdmiral on Sat Jan 18, 2025 9:48 pm, edited 1 time in total.
PostPosted: Sun Jan 05, 2025 10:20 pm
Mike C wrote:
With the announcement of the Samek kits and the Model Monkey upgrades, the Midship kits can be considered to be history now. I'm sure the Samek kits will be worth the wait.
It's been a few years. Has there been any movement on either of these projects?
Users browsing this forum: No registered users and 43 guests
