It is currently Sat Feb 23, 2019 12:44 pm
Post new topic Reply to topic  [ 473 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24
PostPosted: Fri May 04, 2018 2:35 am
Fivi_1241 wrote:
Hello guys,
I've just recently discovered wide offer of Rainbow Model accesories, and I'm very interested in their two versions of 140mm guns:
http://www.rainbowmodel.com/proshow.asp?proid=104
http://www.rainbowmodel.com/proshow.asp?proid=105
Both sets look great on their page, but has anyone used them already?
I have the Rainbow Resin Gun houses for the 140mm IJN guns on their CLs.
They are really nice. Now if I could just finish building the danger bridge for my Nagara.
MB
OMG LOOK! A signature
Working on:
1/700 (All Fall 1942):
HIJMS Nagara
HIJMS Aoba & Kinugasa
USS San Francisco
USS Helena
USS St. Louis
USS Laffey & Farenholt
HIJMS Sub-Chasers No. 4 - 7
HIJMS Sub-Chasers No. 13 - 16
PostPosted: Mon Jun 25, 2018 1:26 pm
After Matthews recommendation I've ordered the resin shields, and those are really fine. A nic addition to my Hasegawa Tenryu, even in deluxe version Hasegawa doesn't provide us with any add-ons for the shields.
I compared resin gun breech with Hasegawa's plastic gun, and it's interesting to see that they have completely different shape, Hasegawa being round and Rainbow being square-shaped. Are there any gun breech photos to confirm the shape?
Another thing is this weird photo-etched...frame around each shield. It is marked as an optional addition, but I haven't seen such thing in any picture of those shields in reality. What is this supposed to be?
PostPosted: Mon Jun 25, 2018 8:59 pm
I only have a side view drawing. I believe the gun is a 50 Cal Type 3 14cm. The breach was a screw breech. You could search for the gun type.
Gabriel
Current Builds:
Fujimi Hiryu 1/350
Trumpeter San Francisco 1/350
Dutch Harbor PBY 1/350
Gallery
PostPosted: Tue Jun 26, 2018 5:27 am
I've found a nice photo of salvaged 140mm on NavWeaps:
Rainbow seems to have done a much better job with this detail.
PostPosted: Tue Jun 26, 2018 7:20 am
Salvaged off Mutsu. Thx for the comparison.
PostPosted: Sun Jul 01, 2018 12:07 am
Greg lester wrote:
My bad, on the side of the ship, adjacent to the stacks are 6 panels that run from just aft of the tower to just under the rear torpedo tubes. They sit just above the armour belt.
I was wondering if they were hatches for coal/oiling. Does that make sense?
Looks like a riveted butt joint to me. I would guess there are more than just those four. http://d2vlcm61l7u1fs.cloudfront.net/me ... QShYba.png
Similar joints can be seen on Naka: https://upload.wikimedia.org/wikipedia/ ... r_Naka.jpg
And Jintsu: https://2.bp.blogspot.com/-MrBc_HPi18Y/ ... 9.jpg1.jpg
PostPosted: Wed Jul 04, 2018 5:32 am
Mike is right in the numbers of stiffeners. They can be 7,8, or 9 depending on ships,sizes and shapes vary from ship type to other types. IJN did this obviousloy for strengthening against hull deflection. Deflecton rate is so different from ship to ship. They say the largest deflection occurred on non-ribetted ships,the cause of nr.4th fleet accidents...
br
mucho,
PostPosted: Tue Jan 29, 2019 1:29 pm
Can someone identify this 5500 t cruiser?
http://www.mtu-net.ru/airships/Japan_1.html
Nagara class? But which ship?
PostPosted: Tue Jan 29, 2019 10:28 pm
Why do you suspect Nagara-class, and not Kuma-class?
The Bridge on this one is too obscured to get much detail on whether it is a Nagara-class or Kuma-class, from what I can tell.
Although the Kumas had a shorter bridge... That could be something.
But both classes had the single main-mast at one time or another.
If we are thinking Nagara, then it cannot be the Abukuma, or the Natori, because the main-deck ran on the Starboard side toward the Stern.
OOPS! Stern!
I can make out a 'Na' or "I" Hirigana (な or い) on the stern, and I see two other characters, meaning three syllables. With Three syllables, that narrows us down to the Nagara, or Isuzu, because we have ruled out the Natori due to the deck configuration..
I want to say the last character is a 'Ra' (ら) and not a 'Zu' (ず). But given the 'Na' and 'I' characters are slightly similar, we need to look at the other two characters. The last could be either 'Ra' or 'Zu'. Which means that we can have either 'Ga' (が) or 'Su' (す)for the second character. It does not look like the Second and Third Characters are identical (nearly so, with the exclusion of the ten-ten on the 'Zu').
I am going to say this is the Nagara based upon the barely visible Hirigana on the tail (specious, at best, but that is tenuously better than nothing).
MB
Working on:
HIJMS Nagara
USS San Francisco
USS Helena
USS St. Louis
PostPosted: Wed Jan 30, 2019 12:16 am
Thank you!
Did the Nagara class cruisers always had the extension of the upper deck? I thought that this was related to the aircraft handling, i.e. only added after the catapult was added.
I.e. Natori would be still possible?
PostPosted: Wed Jan 30, 2019 12:23 pm
I've not been able to find that photo in my collection. All the 5500 tonners had upper works aft of some sort. They changed over time.
PostPosted: Wed Jan 30, 2019 1:00 pm
I was refering to the extension of the forecastle deck (and used the wrong term), which all 5500 t cruisers got, which also got a catapult - some to port, some to starboard. The my knowledge the cruiser on the photo should not have it, because there is no catapult.
Do you have any guess which ship it could be? Nagara and Natori would be for sure candidates.
PostPosted: Wed Jan 30, 2019 4:41 pm
The larger bridge is indicative of one of the Nagara group, but aside from that, I couldn't say.
I defer to Mathew on making out the name at the stern.
Search for:
