It is currently Sat Jan 19, 2019 11:18 am
Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon May 08, 2017 12:25 pm
Online
Kit listing and Gallery updated 5/16/2018
With the recent announcement from Hasegawa of new Yugumo class releases in 1/700, now seems a good time to set up a thread. The original Hasegawa kits, now 45 years old, were typical of their time in that the detail and armament are very simplistic. The hull is okay, though there’s no rear slope to the stern. The follow-up Pit-Road versions, circa mid 1990s, were a little better in that there is more detail and refinement in the kit parts, but the stern is still wrong, the bridge base is a little short fore and aft, and the bow profile is terrible.
While some modelers see these ships as merely improved Kageros (which they are in many regards), the Japanese consider them a separate class. Several improvements contributed to better sea keeping, stability and maneuverability: The forward main mount was moved 1.5m aft, the bridge was set forward at the same frame number as with the Kagero class, but streamlined to a greater degree, and extended further aft to provide more space. There, it was supported by an open trestle. Also, the stern sloped downward to a more pronounced waterline knuckle, the forward torpedo reload gantries were placed perpendicular to the axis of the ship at #1 funnel, and the main turrets were internally modified to allow barrel elevation up to 75* to improve their AA capability.
From their Wikipedia entry:
“The Yūgumo-class destroyers (夕雲型駆逐艦 Yūgumo-gata kuchikukan?) were a group of 19 destroyers built for the Imperial Japanese Navy during World War II. The IJN called them Destroyer Type-A (甲型駆逐艦, Kō-gata Kuchikukan?) from their plan name. No ships of the class survived the war. (Dan’s note: Many sources, particularly older ones, refer to Akigumo as a member of this class. She was not; she belonged to the proceeding Kagero class.)
Design and description
The Yūgumo class was a repeat of the preceding Kagerō class with minor improvements that increased their anti-aircraft capabilities. Their crew numbered 228 officers and enlisted men. The ships measured 119.17 meters (391 ft 0 in) overall, with a beam of 10.8 meters (35 ft 5 in) and a draft of 3.76 meters (12 ft 4 in).[1] They displaced 2,110 metric tons (2,080 long tons) at standard load and 2,560 metric tons (2,520 long tons) at deep load.[2] The ships had two Kampon geared steam turbines, each driving one propeller shaft, using steam provided by three Kampon water-tube boilers. The turbines were rated at a total of 52,000 shaft horsepower (39,000 kW) for a designed speed of 35 knots (65 km/h; 40 mph).[3]
The main armament of the Yūgumo class consisted of six Type 3 127-millimeter (5.0 in) guns in three twin-gun turrets, one superfiring pair aft and one turret forward of the superstructure.[2] The guns were able to elevate up to 75° to increase their ability against aircraft, but their slow rate of fire, slow traversing speed, and the lack of any sort of high-angle fire-control system meant that they were virtually useless as anti-aircraft guns.[4] They were built with four Type 96 25-millimeter (1.0 in) anti-aircraft guns in two twin-gun mounts, but more of these guns were added over the course of the war. The ships were also armed with eight 610-millimeter (24.0 in) torpedo tubes in a two quadruple traversing mounts; one reload was carried for each tube. Their anti-submarine weapons comprised two depth charge throwers for which 36 depth charges were carried.[2]”
Lastly, under the Modified 1942 programm, 16 repeat Yûgumo class destroyers were planned in two batches, to be named Umigiri, Yamagiri, Tanigiri, Kawagiri, Taekaze, Kiyokaze, Satokaze, Murakaze (program numbers 348-355) and Yamasame, Akisame, Natsusame, Hayasame, Takashio, Akishio, Harushio, Wakashio (program #s 5041-48, to be known as the Yamasame class.) They were postponed/cancelled in favor of Matsu class destroyers in 1943 and thus never laid down.
Available kits:
1/700
1972 (Waterline Consortium 1st generation) – Hasegawa Issued
Yugumo, 1943 - Item # 49410, kit # WL410, originally issued 1972, re-issued, 1994
Hayanami, 1944 – Item # 49415, kit # WL415, issued 1972
Asashimo, 1945 – Item # 49450, kit # WL450, issued April, 2006
Second Generation – (Circa mid 1990s) Pit-Road (Skywave) issued
Yugumo, 1942 – PITW-26, released 1996
PITW-108 Full Hull version, released November, 2007
Asashimo, 1945 – PITW-27, released 1996
PITW-27Y (movie version from 2006 film “Otokotachi no Yamato”), released December, 2005
Kazagumo,1942 – PITW-108, Full Hull, released 2007
SPW13, Full Hull, with new equipment set NE-05, photo etch parts, released February, 2012
Hayashimo, 1944 – SPW34, Full Hull, with new equipment set NE-05, released January, 2015
Takanami, 1942 – SPW37, Full Hull, with new equipment set NE-05, released July, 2015
2017 (Waterline Consortium, 3rd generation) – Hasegawa Issued
Yugumo, 1942 – Item # 49461, kit # WL 461, released June, 2017
Hayanami, 1943 – Item # 49462, kit # WL462, released July, 2017
Asashimo, 1944 - Item # 49465, kit # WL469, released May, 2018
2018 (NEXT snap together kits, 2 ships per box, full hull option, with colored parts) - Fujimi issued
Yugumo 1942/Kazagumo 1944 - Item # 460246, 1/700 NEXT #10, released January 22, 2018
1/350
Yugumo, 1942 – PITWB-09, released 2009, discontinued (was a reworked Kagero class kit with Yugumo parts)
Examples in the gallery (and I’m sure I’ve missed some worthy ones):
1/700
A very nice buildup of the original Hasegawa kit as Yugumo, 1942 by Anthony Kochevar: http://www.modelshipgallery.com/gallery ... index.html
Another build of Yugumo, 1943 from the Hasegawa kit by Eric Navas: http://www.modelshipgallery.com/gallery ... index.html
A nicely worked version of Akishimo, 1944, from one of the Hasegawa kits, by Fan Bai: http://www.modelshipgallery.com/gallery ... index.html
A workup of the Asashimo, 1945 kit from Hasegawa by Zhang Hongmin: http://www.modelshipgallery.com/gallery ... index.html
With a lack of Pit-Road kit builds in the gallery (that I can find), I’ve included some from other sites:
Not from this website, but included anyway as a fine example of the Pit-Road kit, is Asashimo, 1945 by aeronautic (Lars Winther): http://aeronautic.dk/Warship%20Asashimo.htm
An exceptional build of Makigumo 1942 by Nobuyuki Nakazawa on the Suwa website: http://suwaships.jp/gallery_cat/%e9%a7% ... %e9%9b%b2/
Builds of Naganami, 1942 and Kazagumo, 1943 from kit bashing the Aoshima Kagero class and Pit-Road Yugumo class kits, by Dan Kaplan: http://www.modelshipgallery.com/gallery ... ss-700-dk/
Christian Hoeltge's beautiful build of the Pit-Road Asashimo, 1945: http://www.modelshipgallery.com/gallery ... /index.htm
1/350
A nice build of the short lived Pit-Road kit as Makigumo, 1942 by Fred Branyon: http://www.modelshipgallery.com/gallery ... index.html
PostPosted: Mon May 08, 2017 12:27 pm
Online
Some early war ships below. The Kazagumo photo is interesting in that her forward torpedo storage bays have yet to be fitted.
Kazagumo as completed, Uraga Dock, March 28, 1942 sm.jpg [ 175.11 KiB | Viewed 4746 times ]
Makigumo as completed, Fujinagata Shipyard, Osaka, March 14, 1942 sm.jpg [ 175.6 KiB | Viewed 4746 times ]
Naganami as completed, Fujinagata Shipyard, Osaka, June 24, 1942 sm.jpg [ 168.42 KiB | Viewed 4746 times ]
PostPosted: Mon May 08, 2017 12:28 pm
Online
Some mid war ships. In these, the original, streamlined bridge was retained with the addition of a radar compartment under the compass bridge deck extension aft, under a revised mainmast carrying a Type 22 radar. The 25mm mounts to either side of #2 funnel were changed from twins to triples, and an additional twin 25mm AA mount was placed in front of the bridge.
Hayanami on trials in Miyazu Bay, July 24, 1943 sm.jpg [ 146.19 KiB | Viewed 4746 times ]
Hamanami on trials off Maizuru, October 10, 1943 sm.jpg [ 193.29 KiB | Viewed 4746 times ]
PostPosted: Mon May 08, 2017 12:30 pm
Online
Some late war ships. The rear of the bridge was enlarged and squared off, eliminating the need for a separate radar compartment. Two additional 25mm triple AA mounts were emplaced on new, raised platform just aft of funnel #1. While the Asashimo photo is not of high quality, one can see the raked stern form, the squared off corner of the rear of the bridge, and most interestingly, two Type 93 “Long Lance” torpedoes. One is sitting on a torpedo trolley on deck beside #2 torpedo mount, and the other is positioned under the starboard torpedo reload girder next to #1 funnel, about to be lowered into the reload bay.
Asashimo after completion, Fujinagata, October 1943 sm.jpg [ 163.12 KiB | Viewed 4747 times ]
Kiyoshimo departing Uraga Dock, May 15, 1944 sm.jpg [ 177.05 KiB | Viewed 4747 times ]
PostPosted: Mon May 08, 2017 12:35 pm
Online
Some illustration and photos regarding the position and shape of the early vs late war bridge. Also, as the first post shows, the front of the Yugumo bridge was placed at the same frame as the of the prior Kagero class. It also gives one a good feel for the difference in the two bridge shapes and the placement of #1 mount. The cupola atop the main rangefinder also differed in the later ships.
Akigumo (Kagero class top) vs Onami (Yugumo class bottom) plan, Gakken #19.jpg
Akigumo (Kagero class top) vs Onami (Yugumo class bottom) plan, Gakken #19.jpg [ 185.17 KiB | Viewed 4747 times ]
Yugumo classearly vs late war bridge illustration, GPS IJN DD vol.jpg [ 139.63 KiB | Viewed 4747 times ]
Yugumo class early war bridge and forecastle illustration, GPS IJN DD vol.jpg
Yugumo class early war bridge and forecastle illustration, GPS IJN DD vol.jpg [ 107.74 KiB | Viewed 4747 times ]
Yugumo class late war bridge illustration, GPS IJN DD vol.jpg [ 188.86 KiB | Viewed 4747 times ]
Makinami damage at Maizuru, April-May 1943 (early war bridge).jpg [ 187.1 KiB | Viewed 4747 times ]
PostPosted: Thu May 11, 2017 9:23 pm
Some mediocre photos of the new Hasegawa kits: https://twitter.com/warhammer2nd/status ... 92/photo/1
PostPosted: Fri May 12, 2017 11:38 am
Online
Thx for posting, Timmy. Exhibited without turret; I guess it's not quite finished yet. Some slightly larger versions can be seen here: https://twitter.com/HMRF_HOBBY/status/8 ... y-852.html
PostPosted: Mon May 15, 2017 3:17 pm
Online
Some larger pics here; stills from the HLJ TV link.
The turrets aren't finished yet, but most everything else seems to carry a lot of detail. Nicely formed bridge, deck houses (which are separated for easier painting), funnels, the galley exhaust pipe is finely rendered, stern deck is a separate piece (which means a late war version likely). I see some auxiliary deck piping molded on and simplified. It certainly looks better than any version currently out.
PostPosted: Mon May 22, 2017 1:53 pm
A book I have says that the Yūgumo-class was basically an improved Kagerō-class, but with some modifications and improved AA outfit.
I still only see a pair of 25mm Type 96 mounts. Those would have been double-mounts on the Kagerō-class, would they not?
Does this mean they are triple-mounts on the Yūgumo-class?
MB
OMG LOOK! A signature
Working on:
1/700 (All Fall 1942):
HIJMS Nagara
HIJMS Aoba & Kinugasa
USS San Francisco
USS Helena
USS St. Louis
USS Laffey & Farenholt
HIJMS Sub-Chasers No. 4 - 7
HIJMS Sub-Chasers No. 13 - 16
PostPosted: Mon May 22, 2017 4:54 pm
Online
The first four Yugumos were completed early in the war, with the same AA fit as the Kageros. After that, being war built, newer Yugumos were completed with ever larger, more complete AA fits. First, a change to triples, then additional twins in front of the bridge and more triples to either side of funnel #1.
There's a series of line illustrations in Model Art Ship Modeling Special #30 that lays this out well.
PostPosted: Thu Jun 15, 2017 12:11 pm
Online
The Yugumos are in!
https://hlj.com/product/HSG461
http://www.1999.co.jp/eng/10460310
Looks really good to me. All the major issues with the Pit-Road kit appear to have been addressed.
PostPosted: Thu Jun 15, 2017 1:36 pm
I want to build the Asashimo as she was during operation Ten-go. I'm not sure, where the portholes closed, as other ships?
And where were the single 25 mm located? From the aeroview I see three guns on each side of the bridge. Is this right and where there more?
Greetings Christian
At work:
1/700 ICM SMS König 1916
1/700 Flyhawk HMS Penelope 1939
1/700 Fujimi IJN Shokaku 1941
1/700 Fujimi IJN Nagato 1941
1/700 Aoshima IJN Kagero 1941
1/700 Flyhawk HMS Prince of Wales 12/1941
PostPosted: Thu Jun 15, 2017 3:29 pm
Online
I believe that Asashimo was built with a reduced number of portholes, much as in the Kiyoshimo photo. It's possible that even more portholes, particularly on the lower level, were sealed by early 1945.
I'll check some references tonite regarding the single 25mm AA positions.
Asashimo, under attack south of Kyushu, April 7, 1945, from Bennington plane crop.jpg
Asashimo, under attack south of Kyushu, April 7, 1945, from Bennington plane crop.jpg [ 77.49 KiB | Viewed 4214 times ]
PostPosted: Fri Jun 16, 2017 3:23 am
Thanks Dan, and the last pic is the one I was refering to. There I see three at the side of the bridge and perhaps two in front of it.
At the aft there are also possibly one next to the deep charge thrower.
And you also see the spare torpedo, which you see on an earlier pic.
Greetings Christian
At work:
PostPosted: Fri Jun 16, 2017 2:36 pm
Online
I don't believe that is a spare torpedo sitting out on deck. As can be better seen in the previous photo, it appears to be reflected light off the side of the aft deck house that happens to echo the shape to a long object. Besides, it really doesn't make much sense to have a torpedo out on deck during an air attack.
Attached is Asashimo's AA fit diagram as of June 30, 1944. I think it's safe to assume that additional units were added by April, 1945, though the exact number and placement may be debatable.
PostPosted: Tue Jun 20, 2017 10:21 am
Thanks Dan, that diagram will help me a lot.
Do have any drawing for the portholes? I will make my according the Kiyoshima pic, But at the aft the position is not clear on that pic.
Greetings Christian
At work:
PostPosted: Tue Jun 20, 2017 7:31 pm
Online
This survey drawing of Kazegumo in January, 1944 from a Warship International article, shows a porthole arrangement the same as Kiyoshima and, likely, Asashimo. While in Kazegumo's case, it was a matter of sealing off existing portholes, the latter ships' as-built pattern were a match for this pattern. (As a means of comparison, even Yukikaze kept some portholes on the lower row forward, and aft, uncovered through to the end of the war.)
PostPosted: Wed Aug 16, 2017 2:00 pm
I have my Asashimo painted.
Where there any markings on the ship during ten-go?
On the pics I see nothing, but the 3 Kageros got two white rings on the rear funnel and an unknown sign on the front.
Where the Asashimo in the same division and had the same markings?
Greetings Christian
At work:
PostPosted: Wed Aug 16, 2017 3:36 pm
Online
Asashimo was not part of DesDiv 17, but rather the flag of DesDiv 21 (Asashimo, Hatsushimo, Kasumi) for Ten Icho-Go. I'm not sure about the funnel bands; I need to check something tonite. She likely would have worn a white chrysanthenum on the sides of #1 funnel, and possibly one of the symbols denoting #1 ship of the division.
PostPosted: Thu Aug 17, 2017 10:19 am
Online
Mr research was inconclusive. I can't determine what markings she might have worn. My sense is that DesDiv 21 would have worn one funnel band, probably on the rear funnel. FWIW.
Search for:
