It is currently Fri Jan 18, 2019 8:19 am
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Thu Aug 25, 2011 3:45 pm
Good afternoon:
I am looking for some good pictures of USS Scott or USS Chandler..
My brother and brother in-law served on these fine platforms.. I recently came across the article written in Fine Scale about a conversion of Spruance to a Kidd.. they show the 1991 config (all grey and RHIB) which is the time they both served.. recently I managed to get one DML Kit and one Spruance VLS..
while reviewing the article and looking at the parts/instructions they show different arrangements of the aft mast with the Main 3D air search radar... specifically the kit has the mast as part of the deck house that holds the supporting electronics..etc while the article shows it resting on the roof.. which is the case? or did they modify the mast when the class recieved the NTU upgrade... Thanks
 Post subject: Re: Kidd Class DDG
PostPosted: Thu Aug 25, 2011 4:28 pm
The NTU upgrade included a new long-range radar (SPS-49) on the foremast in place of the SPG-60 which was moved to a new platform on the mainmast, the 3-D radar (SPS-48) on the mainmast was upgraded and moved to a higher aft-facing platform, and the mainmast was enlarged.
There are photos of all four of the class on Navsource - http://www.navsource.org/archives/05idx.htm
PostPosted: Thu Sep 01, 2011 7:15 am
hello and welcome,
Here are a few photos I found.. I hope they help....
Break on a side note...
It was discussed the Kidds would have gotten the same VLS package as they Tycho.. What happen and why.. ?
PostPosted: Fri Sep 09, 2011 10:02 am
Thanks, for the information,
one quick ? it appears that they moved the SPS-48 arrangement from facing forward to facing aft when did the NTU upgrade is that correct, because I got a date correction of when he was onboard, he left prior to upgrade.. thanks..
PostPosted: Sat Sep 22, 2012 11:45 am
Is there a difference between the shaft arrangement and the v-brackets of the Kidd class ddgs and the Spruance class ships? Do the Ticos differ in any way?
What are the differences of a mid 90's ship of the class in relation to an ealry 80's ship?
Can a VLS be fitted both fore and aft replacing the launchers?
NIKOS (NICK)
ΜΕΓΑ ΤΟ ΤΗΣ ΘΑΛΑΣΣΗΣ ΚΡΑΤΟΣ
PostPosted: Sat Sep 22, 2012 3:13 pm
I am also looking for the SRBOC positions on these ships. The Dragon instructions point out a single position atop the bridge...
NIKOS (NICK)
PostPosted: Sat Sep 22, 2012 5:53 pm
Nick, root through the photos on Defense Imagery. You should be able to find some nice close-ups there.
http://www.defenseimagery.mil/index.html
I have a nice close-up shot taken from a helo that shows the upper decks nicely from the starboard bow. Its in the 14th ed. of Polmar's "Ships and Aircraft of the US Fleet". Let me know if you want a scan. I can see one set of them between the SLQ-32 and the Phalanx ammo elevator.
PostPosted: Sat Sep 22, 2012 11:24 pm
There is a difference between the Ticonderoga class and Spruance/Kidd classes in reguard to the V braces for the shafts. I don't know exactly what it is but a redesign was made and starting with Vincennes (block 1) it was made. Ticonderoga and Yorktown had a different modification. If the first five Tico had been refit with VLS it would not have really been worth it. Ticonderoga, Yorktown, Vincennes, and one of the other two could not be fit with strike length VLS cells on the stern. Forward only one was able to have a full 64 cell Mk41 mod 0 fit. The others would have had space for a 32 cell VLS forward. Without a large number of strike length cells it ment the ships would be severely limited in the number of Tomahawk, SM-3, and VL ASROC that could be taken to sea, also the number of SM-2MR would not be increased. The Kidd class was never intended to be fit with VLS. From the beginning it was 2 127mm/54 Mk45 guns, a Mk26 mod3 launcher aft (44 missiles), and a Mk26 mod4 forward (24 missiles). 20 missiles in the aft launcher were ASROC RUR-5, so the maximum number of RIM-66B was 48. The aft launcher was modified with NTU IIRC. Currently in ROCN they deploy with 62 SM-2MR Block IIIA.
Seasick
PostPosted: Sun Sep 23, 2012 3:05 am
Thank you both for the help. I will post what ever information I find regarding the Dragon kit and the work involved in building an accurate model.
One more thing I have been looking for is whether these ships acquired RHIBs instead of the whale boats later in their carreers.
NIKOS (NICK)
PostPosted: Sun Sep 23, 2012 5:04 am
Here are my first conclusions:
Someone can build a late fit ship with the parts provided in the kit. No early fit whatsoever. In this case you have to use a RHIB (not provided in the kit) and single arm davits (provided in the kit as part F4, but not mentioned in the instructions).
There are two SRBOC positions, one mentioned in the instructions and one not. The second one is between the SLQ-32 and the Phalanx ammo elevator on the aft right side of the forward superstructure. You will also have to build two ammo ready lockers for these SRBOC.
DO NOT use part K21, the superstructure extension below the harpoon deck on the right side. It was never there in the first place, only on the left side.
The bow sonar dome is not of correct shape.
I will be looking for photographs of the props, but something tells me I need to find new ones. :heh: :heh:
Regarding the Chinese service of this class, they Chinese have changed the position of the ECM and placed them above the boat positions at the aft superstructure and the Harpoon missiles with their own version.
More to follow....
NIKOS (NICK)
PostPosted: Fri Sep 28, 2012 4:19 pm
Does anyone know what are the things in the circles? I understand that the midle ones are some kind of antennas but what are the other ones? They were sometime removed from the ships.
NIKOS (NICK)
PostPosted: Mon Oct 01, 2012 2:57 pm
You're correct about the middle ones; def radio antennae (I want to say VHF). Haven't a clue as to the other objects but they look like their covered up so I'd guess they're sensitive in one way or another. Do you have the dates of the photos?
The object above the SPS-48 looks an awful lot like the Electro-Optical (E/O) sight that the CGN-38 class carried.
Those are my guesses for what they're worth.
PostPosted: Wed Oct 03, 2012 6:24 pm
I served on Kidd from 1983-1986. The antennas amidships are UHF. The camera is the Remote Optical Sight (ROS) for the gun system. I don't know what the objects are and don't recollect them. I will do some research. Is this Kidd or Scott?
Charles
Charles Landrum
USNA 1983
Norfolk, Virginia
PostPosted: Wed Oct 03, 2012 8:08 pm
After some review, those gray items are stacks with herculite covers on them. I don't recall what they vent.
Charles Landrum
USNA 1983
Norfolk, Virginia
PostPosted: Thu Oct 04, 2012 9:21 am
Both photos show Kidd. These vents were later removed... This is just confusing. I also found that the thing on the mast was called ROS (remote optical sight) and it was part of the fire control system. I have not found any kind of info regarding this system though...
NIKOS (NICK)
PostPosted: Thu Oct 04, 2012 6:43 pm
In the Mk-86 gun fire control system, the ROS was an independent camera with zoom that could be used to designate the 5 inch guns. Since the 5in 54 mk 45 guns . It worked reasonable well and was good for small boats and fixed target. The ship also had target detection and tracking (TDT) devices which were like the old designator system from WWII, except it sent a raw synchro signal to the gunmount and caused it to jerk around. We only trained to it on occasion.
Here is a link to more info: http://www.fas.org/man/dod-101/navy/doc ... INFO2.html
Charles Landrum
USNA 1983
Norfolk, Virginia
PostPosted: Sat Dec 09, 2017 4:08 am
With the silly background music aside, here is an absolutely beautiful fly-by video of the Kidd-class in Taiwanese hands.
https://www.youtube.com/watch?v=lykl2A5 ... ture=share
What a beautiful ship!
PostPosted: Sat Dec 09, 2017 9:30 pm
my good mate (also called Scott) has a 1/72 Kidd class DDG of USS Scott DDG995 (currently getting refit) here are some pix....
File comment: Wagga 2011
File comment: on display with USS Fife DD991 alongside.
File comment: Wagga 2011, USS Scott passes USS Fife DD991
building:
1/72 RC USS LONG BEACH CGN9
1/72 RC USS CALIFORNIA CGN36
1/72 RC USS SAIPAN LHA2
1/72 RC USS SHARK SSN591
1/72 RC USS ALBANY CG10
PostPosted: Sun Dec 10, 2017 5:03 am
That is so awesome! I can only aspire to build a model like that in 1/350! :thumbs_up_1:
Search for:
