You don’t mention which type of print, which does make a difference. I’ll assume that you’re buying the finest detail material from Shapeways, their “Frosted Ultra Detail” (or the slightly rougher “Frosted Detail”), both of which are UV-cured acrylic plastic, and specifically “Visijet SR 200” from 3DSystems, printed on a multijet machine such as a Projet 3510 HD from 3DSystems.
“Cleaning” has several aspects:
1. These parts are printed with a soft gooey support wax UNDER all overhanging part surfaces… basically the entire vertical shadow is a block of this wax. Most is washed off by Shapeways, but depending on the technician’s willingness to scrub your delicate details, much may be left behind. The stuff can be cleaned with strong solvents, but warm water and water based cleaners will do the job too. Spic’n Span, Simple Green, etc. I use a cheap ultrasonic cleaner, and follow up with pipe cleaners into any holes.
2. Wherever the wax touched your part, the part will have a frosted surface. After cleaning, this will look like a white crust of mostly parent plastic, but it seems to contain some residual wax too. I scrape/scrub/sand this, as best as I can manage.
3. This mechanical cleanup can also address any visible “print lines”, but it’s made harder for you if the designer has included a lot of integral surface details. (I prefer to make loose details for later assembly, rather than one solid and complete model).
4. Finally, paint ONLY with water based acrylics. This plastic seems to be “wet”… I don’t know if it’s uncured resin, or excess plasticizer or what, but SOMETHING in my printed parts prevents oil based enamels from curing. Water based acrylics cure just fine.
If you are trying to save $$ by buying the cheaper "Strong Flexible" material, then you are getting an "SLS" (Selective Laser Sintering) part, which is fine nylon powder fused into a solid mass. Not only do you have coarser print lines to deal with, you also have a porous sandstone-like surface to seal... AND a very tough nylon material which is near impossible to sand. Yes, layer after layer of sealing material is needed... fill with sanding sealer or primer/surfacer, and then good luck avoiding a globbed-on appearance.
I have used SLS on larger structures where I could smooth out large flat surfaces... I then populated the details with finely printed FUD parts.
FUD details on my latest 3D Printed model in 1:24 scale (cabin was made with yet another process, "stereolithography"):
Pat Matthews
Get your boats wet!
Blog: [redacted]
Shapeways Shop: [redacted]
MWS Gallery:
http://www.modelshipgallery.com/gallery/users/Pat-Matthews/user-index.html
