It is currently Mon Sep 23, 2019 11:13 am
Post new topic Reply to topic  [ 283 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15  Next
PostPosted: Mon Jul 25, 2016 11:12 am
Wow, this seems to answer all my questions, thanks a lot!
PostPosted: Tue Jul 26, 2016 3:03 pm
Now after readings all the materials provided and researching available photos, it seems to me that Cavalla can be build OOB from 1943 Gato and Tunny from 1942 kit.
Another sub that interests me is USS Silversides. Based on available NavSource photos, it seems that during the overhaul at Mare Island the ship's AA armament was one 40mm Bofors gun and one 20mm Oerlikon cannon on the fairwater, plus a single Oerlikon 20mm gun on the main deck, behind the fairwater. On the other hand, Silversides as preserved nowadays does not have the Oerlikon on deck. Is it possible that in a certain period during war Silversides was armed just like it is now as a museum ship?
PostPosted: Tue Jul 26, 2016 9:16 pm
A few points:
Silversides was a Mare Island built submarine. Boats built at Mare Island, Portsmouth and Cramp shipyard employed "government plans". The limber holes along the side were very different (rows of horizontal slots) from submarines using the Electric Boat plan set (EB and Manitowoc yards).
Government limber holes: http://www.navsource.org/archives/08/0823204.jpg
The limber holes on EB plans were horizontal "D" shaped with the straight end at the bottom.
http://navsource.org/archives/08/218/0821721.jpg
In some cases, additional limber holes were later added to EB boats, most notable USS Gato herself:
original Gato limber holes: http://navsource.org/archives/08/218/0821248.jpg
and late war USS Gato: http://www.navsource.org/archives/08/0821201.jpg
During the war, the conning tower fairwater configurations, armament (guns, large & small, and gun locations) and radar, radio antenna outifttings changed constantly. Original Gatos had large enclosed conning tower fairwaters which were gradually cut down to reduce the silhouettes, especially at night. Subs began the war all black (Ms 9) and then had gray, black & white camo (Ms 32) schemes. Different subs had different configurations at different time points. The later Balao and Tench classes had very different and much smaller and open fairwater configurations.
Here's an early Gato conning tower: http://www.navsource.org/archives/08/0821501.jpg and also seen here: http://www.navsource.org/archives/08/0821601.jpg
Here's a late war cut down Gato conning tower: http://www.navsource.org/archives/08/0822415.jpg
Here's a Balao class conning tower: http://www.navsource.org/archives/08/0828742.jpg and also here: http://www.navsource.org/archives/08/0830507.jpg
The best advice is 1.) pick a submarine 2.) pick a time frame for said submarine, 3.) find a photo of the particular sub at a particular point in time. Pay attention to the conning tower and the armament configurations. There is no generic Gato submarine. Your mileage may vary....
Tom Dougherty
Researcher for: "Azorian: The Raising of the K-129" DVD
http://www.projectjennifer.at/
http://www.usni.org/store/catalog-fall-2012/project-azorian
PostPosted: Mon Aug 15, 2016 3:34 pm
I'm looking for some clearer photos/drawings/dimensions of the antenna masts mounted forward and aft of the sail, such as on Blackfish in 1942:
http://www.navsource.org/archives/08/0822104.jpg
Just like most other exterior details on fleet subs, I've seen enough to know that they varied from boat to boat, so I'm specifically looking for data on Blackfish's arrangement.
Thanks!
Jonah
PostPosted: Mon Aug 15, 2016 5:22 pm
Mr. M....
Did you really have to dredge up the past. I was just getting over my Pettycoat days............G
Anything worth doing is worth overdoing
http://geneberger-models.com/
PostPosted: Mon Aug 15, 2016 8:54 pm
"... well, that takes care of Jorgensen's theory!"
PostPosted: Sat Oct 29, 2016 12:10 pm
I can use some help from the fleet boat experts. I understand that the limber hole patterns identify EB plan and Government plan boats, and that some of the earliest Gatos had anchors on both sides which was quickly reduced to one. I thought that then all Navy yard boats had an anchor on the port side.
When I got the AFV 1/350 1942 Gato class kit, I assumed that the Government pattern limber holes with a starboard side anchor was an obvious error. However, when I started to do research I found a number of pictures, including the one of Silversides on the cover of The War Below that seemed to show the anchor on the starboard side:
Silversides http://www.navsource.org/archives/08/0823628.jpg
Trigger http://www.navsource.org/archives/08/0823702.jpg
http://www.navsource.org/archives/08/0823703.jpg
Wahoo http://www.navsource.org/archives/08/0823832.jpg
http://navsource.org/archives/08/233/0823806.jpg
Whale http://www.navsource.org/archives/08/0823901.jpg
http://www.navsource.org/archives/08/0823917.jpg
Sunfish http://navsource.org/archives/08/282/0828111.jpg
http://www.navsource.org/archives/08/0828109.jpg
Tunny http://www.navsource.org/archives/08/0828230.jpg
While it is possible, I can't imagine that many photos would be mislabeled or reversed. So, did a number of Government plan boats have starboard anchors? Was it only Mare Island boats? Was it only late war after the fairwater was cut down?
Any help / clarification would be appreciated.
PostPosted: Sat Oct 29, 2016 12:40 pm
Answers to most of your questions are here:
http://navsource.org/archives/08/pdf/0829294.pdf
There is a section at the end addressing anchor placements.
Tom
Tom Dougherty
PostPosted: Thu Nov 03, 2016 11:57 am
Wow, Johnston's article is amazing. Thank you. I am still digesting it all, but it appears that hull of the AFV Gato with the anchor on the "wrong" side can be used to build Trigger, Silversides or Wahoo.
PostPosted: Thu Nov 03, 2016 8:47 pm
If you ever get around to building the later war Balao class, here is more information that Johnston compiled on those submarines:
http://navsource.org/archives/08/pdf/0829295.pdf
Tom
Tom Dougherty
PostPosted: Sun Nov 20, 2016 10:18 am
ModelMonkey has produced a Balao fairwater and someone else has a 1/350 5”/25 Mark 40, so that information might be useful in the very near future.
Now, does anyone sell (3-D printed or resin) a 1/350 20 mm with Mark 10 (not cast) mount?
PostPosted: Thu Dec 01, 2016 12:01 pm
I'm about to start work on a 1/200 model of the Barb. I'm debating as to which time period: late 1944 or spring 1945, after her last big overhaul. I have plenty of references for the '45 version, wherein she carried a 5"/25 aft, a single 40mm & twin 20mm on the fairwater, and sported a separate SD mast on the cigarette deck.
I'm not sure what her config was in Dec. '44 when this photo was taken:
If I had to guess, I would assume she still had a 4" gun forward, a twin 20mm on the cig deck, and no separate SD mast. No idea if it was another 20mm or the single 40mm in the forward fairwater location. I would appreciate assistance in confirming her Dec. '44 layout, thanks.
PostPosted: Thu Dec 01, 2016 8:53 pm
USS Barb on January 29th, 1944:
http://www.navsource.org/archives/08/0822011.jpg
http://www.navsource.org/archives/08/0822013.jpg
http://www.navsource.org/archives/08/0822012.jpg
4″/50 Gun is mounted forward, and SJ radar is mounted in front of the periscope shears; omnidirectional SD antenna behind the shears.
USS Barb on May, !945, gun is 5"/25 mounted on aft mount, and SJ radar mast is now astern of the periscope shears
http://www.navsource.org/archives/08/0822031.jpg
http://navsource.org/archives/08/500/0822028.jpg
http://www.navsource.org/archives/08/0822018.jpg
with Bofors mounted on forward fairwater deck:
http://www.navsource.org/archives/08/0822017.jpg
Tom Dougherty
PostPosted: Thu Dec 01, 2016 10:05 pm
Jan. '44 is pretty early. Were any changes made before Dec.?
PostPosted: Fri Dec 02, 2016 9:24 am
No, at least not any major changes. The last major changes during the war were made after her 11th patrol from 19 December 1944 – 15 February 1945. The 5/25 gun and other alterations were made in an overhaul beginning in February 1945. It was also at this point that the rocket launcher was installed. Her 12th and final war patrol with the latest alterations began in June, 1945.
Tom Dougherty
PostPosted: Sat Jul 29, 2017 4:09 am
Does anyone know if "bells" were used to signal time on US submarines the same way as on surface ships?
Cap'n Price
Fitting out:
1/350 USS Saratoga 1936
On the ways:
1/72 Gato
PostPosted: Sun Aug 20, 2017 8:06 am
Riich Model's Gato may be impressive, but it sure is lacking weapon options. Do you know any after-market source of suitable single mount of 40mm and 5"/25 guns?
Filip
PostPosted: Sun Aug 20, 2017 8:17 am
Especially when navigating at depth! :heh: :heh:
"There are more planes in the ocean, than submarines in the sky" - old carrier sailor
PostPosted: Sun Aug 20, 2017 1:55 pm
Shapeways has 1/200 scale in both 5" and 40mm.
PostPosted: Tue Oct 17, 2017 11:40 am
Question for you guys: does anyone have accurate color charts for the submarine camouflage colors used in the Measure 32 patterns? Most of the mass-production literature (like Squadron books) define the colors along the same lines as those developed for the surface ships ("Haze Grey 5-H", "Ocean Grey 5-O"), but the official camouflage sheets from Tracy White's website and the Floating Drydock photobooks describe an entirely new set of colors I've never seen reference of before anywhere else. The greys are described in numbers ("#16 Medium Grey", "#11 Dark Grey", #7 Very Dark Grey", etc).
Any ideas?
Search for:
