It is currently Tue Jan 22, 2019 1:58 pm
Post new topic Reply to topic  [ 1021 posts ]  Go to page Previous  1 ... 44, 45, 46, 47, 48, 49, 50 ... 52  Next
PostPosted: Wed Sep 30, 2015 11:21 am
Dear friends I need a photo of Japanese merchant ships IWAKI-MARU and HIBURI-MARU
On June 1st 1944, Herring (SS-233) continues to attack and sinks transport Iwaki Maru, the lone surviving ship of convoy NE attacked the previous day. 30 crewmen and 20 soldiers are KIA. Herring also sinks the merchant cargo ship Hiburi Maru (33 crew and 97 soldiers KIA), off Matsuwa Island
岩木丸 IWAKI MARU (1942)
49472/JGKP 貨物船 3,125G/T 起工 1941.3.15(昭16) 進水 1942.4.28(昭17) 竣工 1942.6.29(昭17)
Lpp 97.00 B 14.00 D 7.50 m 主機 R 3連成 2,159IHP 11/13.393kt
株式会社播磨造船所(相生)建造 Sno.303 北日本汽船株式会社(東京)
岩木丸 Iwaki Maru
1943.11.16(昭18)合併に伴い大阪商船(大阪)に移籍
1944.6.1(昭19)松輪島沖(48.00N,153.00E)で米潜HERRING(SS-233)の雷撃により沈没
HIBURI MARU ex HEIJIN MARU
平仁丸 HEIJIN MARU 24961/RLMG→JIVD 4,363G/T 2,939IHP 10/12kt
進水 1919.4.__(大8) 竣工 1919.5.__(大8) 太洋汽船株式会社(新居浜)
平仁丸 Heijin Maru
1925(大14)日本共同汽船(新居浜)に売却
1934.8.28(昭9)満州海陸運送株式会社(神戸)に売却
1934.12.17(昭9)西光丸 SEIKO MARU と改名
1936.8.10(昭11)合併に伴い山下汽船(神戸)に移籍
1940.2.20(昭15)日振丸 HIBURI MARU と改名
1944.6.1(昭19)千島の松輪島近海(48.00N,153.00E)で米潜HERRING(SS-233)の雷撃により沈没
Please, help.RGDS
PostPosted: Thu Oct 01, 2015 2:37 pm
Hello, Zavety
Maybe not exactly, but HIBURI MARU is listed under the subgroup BATAVIA MARU (Japan 1918-1920) OA 357'. They are listed in ONI-208-J page 248 (avail online) w/ plan and photo.
Will look for other in hardcopy when I get home.
Cheers :wave_1:
PostPosted: Tue Jan 05, 2016 9:34 am
Has anyone seen any pictures of the Hie (Hiye) Maru after her conversion to a Sub Depot ship? Was she fairly identical to the Heian Maru? I know the bridge window layout was a little different.
PostPosted: Wed Jan 06, 2016 6:06 pm
Go to page 1 of this thread and check out Motoyuki Iwashige's web site. There are both models of Hie, and Heian Marus. They will be a great visual ID for you to make your changes/adjustments.
Bob Pink. :wave_1:
PostPosted: Wed Jan 06, 2016 10:35 pm
It's interesting he mounted the two side 150mm front.
Hie (Hiye) Maru
9 March 1942:
Arrives at Yokosuka Navy Yard. Begins conversion. Four 5.9-inch (150-mm) single mount guns, one 3.5 m range finder, two two Type 93 dual 13.2-mm machine guns, one 1100-mm diameter and one 900-mm diameter search light are fitted.
Heian Maru
15 October 1941:
Registered as a prospective submarine tender in the Yokosuka Naval District. Begins conversion at Mitsubishi Heavy Industries’ shipyard at Kobe. Four 6-inch (152-mm) 41st Year Type single mount guns, one 3.5 m range finder, two Type 93 dual 13-mm machine guns and one 1100-mm diameter and one 900-mm diameter search lights are fitted. A degaussing cable (anti-magnetic mine device) is also fitted.
23 October to 7 November 1943:
Yokosuka Navy Yard. Refitted. The four 152-mm guns are removed and replaced by two 120-mm AA gun (10th Year Type), two Type 96 25-mm twin mounts and two Type 93 13.2-mm twin mounts In addition, a Type 2 sonar is installed. The crew complement is increased to 242 men. HEIAN MARU's dazzle camoflague pattern is possibly applied at this time.
Looks like Hie Maru kept her original armament while the Heian had hers changed again if the TRM's are correct. Maybe painted Yokosuka Grey?
PostPosted: Fri Jan 08, 2016 9:19 pm
I've looked hard for Hie Maru photos as a tender, but have come up empty. :cry:
PostPosted: Tue Jul 19, 2016 12:40 pm
Hi all.
I would like to build Niko's Asaka Maru as a civilian (NYK) ship.
Do you know of any drawings which could help with this conversion?
Thanks in advance and cheers,
Peter
PostPosted: Wed Jul 20, 2016 7:34 am
The only drawing I know of is of sister Awata Maru in what appears to be Red Cross markings, from Motoyuki Iwashige's first Japanese merchant ship volume.
PostPosted: Thu Jul 21, 2016 4:37 am
Thanks a lot, Dan.
I will choose an other project, I'm not good enough cutting resin (rear deck).
Cheers, Peter
PostPosted: Tue Aug 09, 2016 8:04 am
Hi all
Does anybody have a book on (prewar) Japanese cargo and/or passenger ships/liners he would like to part with?
For example:
- Journey Back in Time/Japanese Passenger Ships (OOP)
- The Golden Age of Japanese Passenger Liners (Kojinsha, Ships of the World, 2004)
Also any hints on where I could find one of these, or similar, books, would be much appreciated!
Thanks and cheers,
Peter
PostPosted: Tue Aug 09, 2016 9:27 am
This volume is not listed as out of stock on the SOTW website. It must be in stock someplace, or I believe you can order direct from SOTW
http://www.ships-net.co.jp/detl/200405b/goldenj.htm
PostPosted: Tue Aug 09, 2016 10:41 am
Thank you, Dan. Good to know that it should be available somewhere.
I will have a look if I find it on a Website in English language, since I don't speak (or read or write) Japanese.
It's not available any more with HLJ where I usually buy Japanese books.
Cheers, Peter
PostPosted: Tue Aug 09, 2016 11:45 am
Hello Peter
Here is a link to the Japanese Merchant Ship Recognition Manual (1944). Just copy and paste the link to your browser and remove the extra space after the http. The Far-Eastern Small Craft Manual is also interesting.
http ://archive.hnsa.org/doc/id/index.htm
Ron Wolford
PostPosted: Tue Aug 09, 2016 2:09 pm
Wow, thank you, Ron, I didn't know this site! VERY interesting!
Cheers, Peter
PostPosted: Tue Aug 09, 2016 3:29 pm
Yes, thx for posting, Ron. That is a fantastic link.
Peter, SOTW has an English language website version, though the volume in question is not listed. I can look that up at home. You can order using the information there. See: http://www.ships-net.co.jp/homee.htm
Got to What's New, then almost all the way dwon towards the bottom of that page. See also the Order and Subscription page.
PostPosted: Wed Aug 10, 2016 8:21 am
Dan, thank you, I found the item where you said, on the What's New page. On the other hand, it's not on the Order Form.
And I did not find it elsewhere... any help would be appreciated.
Peter
PostPosted: Wed Aug 10, 2016 8:29 am
I forgot to look for a volume # last night. Have written a reminder to myself.
PostPosted: Wed Aug 10, 2016 9:17 am
Thank you Ron for the link! :thumbs_up_1: I'll have to check it out.
Bob Pink. :wave_1:
PostPosted: Wed Aug 10, 2016 8:54 pm
Amazingly, there is neither a vol. #, or an ISBN # that I can find on the volume. A bit bizarre. You may have to write them directly for information.
PostPosted: Thu Aug 11, 2016 11:01 am
Hello Everybody
I have this for the ISBN of the “The Golden Age of Japanese Passenger Liners” T1105604053809 and for a very similar book “Japanese Passenger Ships in History Vol. 1 1868-1945” ISBN4-905551-38-2 C0056 P6000E. I got “Japanese Passenger Ships in History” back in 1994, through a Japanese book store in San Diego, so it may be out of print. Both are wonderful references but the photo quality is much better in “The Golden Age of Japanese Passenger Liners”.
Ron Wolford
Users browsing this forum: Littorio and 1 guest
Search for:
