It is currently Tue Jul 29, 2025 3:53 pm
Post new topic Reply to topic  [ 18 posts ]
 Post subject: Calling all C-1A Fans!
PostPosted: Sun Oct 11, 2009 7:28 pm
I have the above kit and want to finish it for a friend as Cape Race. A B&W profile can be found here:
http://drawings.usmaritimecommission.de/drawings_c1.htm Does anyone know what colors are on the Stack or what line is being represented? It doesn't seem to be Ocean Steamship. Thanks for any help. Fred Schwieg
Title edited
PostPosted: Sun Oct 11, 2009 8:49 pm
Sounds like an interesting model.
Do have this photo of her: http://usmaritimecommission.de/pictures.php?code=A0894b ?
-- Scott
PostPosted: Mon Oct 12, 2009 12:00 pm
No, thanks much!
PostPosted: Mon Oct 12, 2009 2:05 pm
Which kit are you using for this? I hadn't realized there was a C1-A, unless it's something larger than 1/700.
-- Scott
PostPosted: Mon Oct 12, 2009 3:04 pm
Reigels
Loose Cannon make a C1A - sold as Cape Charles - see their website
Jim S
PostPosted: Mon Mar 29, 2010 7:38 pm
Anyone here know the changes these ships underwent to become the PT Tenders???
Current builds:
Planned builds:
3 more 1/700 AH submarines
PostPosted: Mon Feb 04, 2019 4:44 pm
I am working on a C1-A plug in 1/96 scale . Three were used by the US Navy during WWII .They were AE-10 Sangay ( Cape Sable ) , AGP-12 Acontius ( Cape Carthage ) and AGP-13 Cyrene ( Cape Farewell ). The AGP's were torpedo boat tenders . I have photo's of the plug in progress and photo's of the lift they used to pick them up and were they put them on deck .The problem is I can't figure out how to post them . :heh:
It says file to large .How do I change it ?
PostPosted: Mon Feb 04, 2019 5:06 pm
Hi David
I don't know ?
PostPosted: Tue Feb 05, 2019 7:31 am
I was using a computer at the library . I will try again later.
PostPosted: Tue Feb 05, 2019 11:37 pm
Dear Richard,
You may be able to reduce the image file size when you upload. Imageshack has that option. You have to select the reduction before uploading.
Sincerely,
Nelson
PostPosted: Wed Feb 06, 2019 12:23 pm
Thanks :thumbs_up_1:
PostPosted: Wed Feb 13, 2019 8:21 pm
USS Acontius (AGP-12) should answer the question regarding C1-A ships used as motor torpedo boat tenders. My father sailed on SS Cape Charles, both PT boats and C1-As are of interest to me :-)
PostPosted: Thu Apr 18, 2019 4:54 pm
C-1A plug started . AE-10 Sangay or torpedo boat tender .
Plans are from Smithsonian .
Last edited by Richard OMalley on Fri Jun 14, 2019 11:29 am, edited 1 time in total.
PostPosted: Thu Apr 18, 2019 5:06 pm
The C-1A hull was also used to make Attack Transport USS Fomalhant
AGP-13 Cyrene
PostPosted: Wed May 01, 2019 2:27 pm
Filed in the middle with styrafoam then used spray foam the cover the outside .The resin will not eat the spray poly foam .
After it dries I use a rasp and sandpaper to even it out to the bulkheadl . :wave_1:
PostPosted: Tue May 07, 2019 1:55 pm
Richard,
Excellent progress, keep us posted. I am very interested to see how this build proceeds.
PostPosted: Mon Jun 03, 2019 2:05 pm
Thanks William
I will post progress under picture post work in progress . :wave_1:
