IJN Light Cruisers Kashima and Katori - Aoshima 1:700
D-Boy
Post by D-Boy »
The new Aoshima 1:700 IJN Kashima, a Katori-class light cruiser, arrived here at the office today, the model finally following an earlier shipment of the wood deck and PE set from HLJ. I wanted to offer some first impressions - as expected and long desired, this is a significant upgrade over the former Aoshima releases of this class (those kits are some of the oldest and most disappointing molds in the WL series, and included a notorious curved transition from foredeck on the bow to main deck aft of the bridge structure).
Aoshima's releases of the Katori and Kashima are somewhat unique from one another - the Kashima has parts for a late-war build, and the Katori kit is intended as an early-war build - and the Katori kit omits parts that allow you to build a late-war version OOB.
(DanK first reported that the sister-ship Kashi, in yet a third, distinctive version that includes a false second funnel, will also be released; there are corroborating photos of that kit in Model Art Special #41, page 51. This kit is now scheduled for a November 2011 release and will mark Aoshima's complete re-release of this class: http://www.hlj.com/product/AOS04543). Edit: The kit of the Kashi is listed as available at Hobby Link Japan as of 11/2/2011.)
The chief difference between the early and late war kits appears to be additional gun platforms and shields of various types which are included in the Kashima kit. The Kashima has a heavier forward mast design and Type 13 radar, and subsitutes AA weapons for the twin torpedo tubes of the Katori. Additionally, the stern of the Kashima includes detailed depth charge equipment not included with the Katori, and has locating holes in the deck for these weapons.
I only have the Kashima kit on hand, but have been comparing with photos of parts and instructions on the Hobby Search website - I've included links below for you to take your own look there at photos and instructions.
The Kashima kit includes the hull (labeled "A") 3 main sprues ("B," "C" and "G"), a transparent sprue with the bridge windows ("I"), a one-piece "D" sprue that is the superstructure under the funnel, and the standard detailing sprue "W" with a variety of AA/ships boats, etc. Katori appears to come with the "A," "B," and "C" sprues, a smaller alternate sprue to "G," and an added sprue with additional mast parts, as well as sprue "W.".
The differences between these two builds can be noted in a comparison of the instructions for each of these ships. Assembly steps 8, 11, 16, 17, 20 and 21 of the Kashima instructions are focal points for the differences between these kits.
Some specific notes on the Kashima:
1) One-piece hull with WL plate. Portholes are well-scaled and detailed with molded-on gutters. Degaussing cable also molded in place, and is more finely cast than the cable in my PE stash. Portholes at the level closest to waterline are molded with covers in place - subtle, but noticeable. Stern anchors are cast in place. Very impressive upgrade over the former kit.
2) Main deck is cast in three pieces. Hard to tell from parts on the sprue if the joint seam toward the stern will be noticeable - it is likely hidden by the aft superstructure. There is a mix of cast-on and add-on details on/for the deck pieces; what is cast in place is well-detailed and will be worth the effort to mask around for deck painting. Baseplates for guns, splinter shields, winches, etc, appear worth leaving in place and working around. And, yes, an accurate step-down from the fore-deck to the main deck level. The deck pieces are different between the Kashima and Katori - the Kashima includes cast-in-place splinter guards mid-ships and mounting locations for depth charges and racks on the stern. The bow deck appears common to both kits.
3) Twin 14 cm main turrets are well molded with details, and the gun barrels include molded-on blast bags. My gut reaction, which is likely completely inaccurate, was that these main turrets, in toto, look undersized. When I post photos, I'd welcome your opinion. Given all that appears improved and correct about this kit, it would be odd for Aoshima to mess up the main armament. So I expect that they will stand the test of other impressions/documentation. I do think the main turrets look appropriately sized in the manufacturer's photos.
4) Funnel is cast in three main pieces, capturing distinctive internal piping.
5) Bridge assembles from multiple pieces and is well detailed, far different than the former version of this kit. The bridge has been the focal point of strong criticisms of the earlier version of the kit (see here: http://smmlonline.com/articles/katori/katori.html). I'll need to lay out pieces off the sprue to assess any progress with this mold to a more accurate, documented shape, but the bridge now builds from 9 major parts and presumably Aoshima made accurate improvements here. Incidentally, I've seen several builds in Japanese modeling publications that have one or more bridge decks painted in linoleum brown.
6) A lot of single, double and triple AA armament on the sprues, and the instructions show you where to place the full lot of it, so, per instructions, OOB, this builds to a late-war version. Triple, Double and Single AA is not is fine as FineMolds or PE options, but an improvement over the "W" sprue moldings.
Here are photos and instructions from Hobby Search that will give some context to my comments above:
http://www.1999.co.jp/eng/image/10144547a/20/1
At HLJ's website, you can see the major sprue that is different between the Kashima and Katori: http://www.hlj.com/product/AOS04542
And here are photos and instructions for the lead ship, Katori:http://www.1999.co.jp/eng/image/10144544a/20/1
And here is a photo of the Kotari's distinctive "early war" sprue at HLJ: http://www.hlj.com/product/AOS04541
To summarize, the Katori kit is packaged as an early-war build, the Kashima as a late-war build. It would be easier to back-date the Kashima kit - it is missing the simplified early-war mast and does not include torpedo tubes - whereas the Katori is missing detailed gun platforms and the more complex mast.
Check out the "Calling All Ships Fans" IJN Light Cruisers threads for more commentary discussion and photos of these Katori Class kits.
Added note: the PE/wood deck accessories for this kit include a common deck for the bows of the Kashima and Katori, and seperate stern deck pieces for either the Kashima OR Katori. So the wood deck kit will serve for either the early or late war builds: http://www.hlj.com/product/AOS05027. This accessory pack also includes PE for the kit, including railings and other detailing.
Return to “Ships and Subs”
