Hello everyone,
I finally have a nice step forward to show on my Russian ships project.
It was a great pain to mount all these details. But in general these models are not so simple to assemble. In comparison, a WWII battleship is a joke next to the
Kirov or Slava assembly.
Before you present the advanced some news. As you know, I moved to a new region 9 months ago. Besides that the climate which is a real renaissance compared to the frost of Savoy. The seaside is a real pleasure, whatever the weather.
But on the model side, it's a little more complicated. Especially with cyano glue, which I use a lot for gluing PE. In summer, it is too hot and to keep an essential fluidity, I must clean and change my source of glue every 10 minutes. And in Winters (as now), there is not enough humidity in the air (due to the ducted heating). Result, it takes more than 2 minutes to have an almost solid bonding. So I recently invested in an air humidifier. Ultimately, I hope to have more conclusive results than today.
On the painting of the ship, I studied the photos for months and on each there is no continuity. On one the elements are painted in a certain color and on others the same element is painted in a different shade. The problem is that it is impossible to date the photos and sometimes to identify the vessel in its class.
So I made my idea by referring to two photos.
For the colors, I used the color from WEM for the bridge and for the rest I used for the first time paints of the brand Mr. COLOR (as indicated on the assembly instructions). For the latter, it is the first and especially the last time. Much too harmful as a paint. More unpleasant to use than enamel paints. Infection in the room (even with the window open and the use of a vacuum paint booth).
I have an air purifier in my office. After using M. COLOR paint, the air indicators were all purple red, more than 850 nanoparticles. While with other paints they only go up to values ??between 300 to 350 and as normal a value around 10 to 20.
Coming back to the ships, I spent more than 4 weeks fitting the covers for the
KIROV. This time spent is explained by the fact that I put almost everything on the model before starting the painting. But to enhance the thing. On Russian ships, there is a red and white border at the bottom of each vertical wall in contact with a red surface. So I painted all of these surfaces, then put in place a cover 0.7 inches high. A real pleasure.
I made the choice to make the markings in white on the flight deck in paint. Because the decals did not give me confidence.
I show the pictures of the rough formwork paint. I�ve finished removing the last mask this morning. I did not paint the portholes and other details. And above all I have not started the filter phase and other phases of aging of the ship.
I take this opportunity to wish you all a happy New Year.
Sincerely.
Alain.
