1/300 Scale HMS Penelope Wreck Dio
William J
Post by William J »
Hi guys.
Well I had the 1/300 scale Arethusa-class British cruiser HMS Aurora (Lee) sitting around for a while and it is a very basic model. Not being any good with PE, I was wondering what to do with this very basic kit so as not to make it look like a bath toy. I enjoy modelling wrecks, so I decided to research the Arethusa-class and discovered that out of the various ships that made up the class, HMS Penelope met her end at the hands of a U-Boat off the coast of Naples. I researched the wreck of the Penelope and here is my build up of this vignette.
pre-shading the portholes
Keep The Faith Gentlemen and Watch the Offside
William J
Re: 1/300 Scale HMS Penelope Wreck Dio
Post by William J »
In short, HMS Penelope was sunk as a result of two torpedos hitting her in the rear of the vessel on the starbord side - abaft the engine room and aft of the boiler room. The explosion was huge, she listed to starbord, broke in two and sank. Accordingly, all the damage is in the rear of the vessel. Both funnels were blown off the vessel and her 3 main turrets containing her 6 x 152mm guns fell away from the ship when she capsized.
Bill Keough :wave_1:
William J
Post by William J »
The upper hill was painted in Humbrol Matt 27 and the lower hull was painted with Humbrol Matt 60. The deck was painted with Humbrol Matt 93. All painting was by hand.
Superstructure was painted with Humbrol Matt 64.
William J
Post by William J »
The hull and deck are given an initial wash.
prowannab
Post by prowannab »
Looking good so far. What do u plan on using to the base?
prowannab
Post by prowannab »
For the base. I hate autofill sometimes
William J
Post by William J »
Ultimately I want to display her in a display case but the base will most probably be just a sea bed scultpted with Gel Medium.
William J
Post by William J »
It's now time to give the model the first of many coats of Tamiya Pavement Effect Diorama paint in order to recreate the crusticalled look of a sunken ship. I used some to the texture paint as a base to add rust via the use of the Pro-Modeller Weathering Pigment. It is a very fine powder and get get very messy when applying. If applying dry, it is best applied with a cotton tip (Q tip).
William J
Post by William J »
The pavement effect paint contains crushed ceramic particles and is quite thick out of the pot. It can be thinned down using water depending on the look you want. I want a heavily weathered look, so slop!!! on she went. Note: don't let this stuff dry on your brush coz you'll never get it off. Wash your brushes whilst it it still wet. I washed my brushes under running hot water.
William J
Post by William J »
The hull has been cut at a point that accords with the research I have done as to the damage the Penelope sustained.
I am going to retain the stern as it will be a separate dio that I'll do at a later stage. This pic shows the texture of the pavement paint.
William J
Post by William J »
Some more pics of the hull.
William J
Post by William J »
Have applied the anchor chains and coated the bow with the texture paint. Pics to follow.
Quincy
Post by Quincy »
:thumbs_up_1: :thumbs_up_1:
Bob Pink. :wave_1:
William J
Post by William J »
Thanks Bob.
Will post progress pics soon as I have been very busy with work.
William J
Post by William J »
The anchor chains have been attached and the bow is getting the first coat of texture paint.
William J
Post by William J »
More pics.
William J
Post by William J »
The turrets got treated with the pavement pain, however, I am in two minds as to whether or not to add them to the wreck. I believe that they would have falledn away when Penelope capsized. So, hmmm, not sure.
AndyP
Post by AndyP »
While on larger ships (I.E battleship) the turrets were generally held in only by their own weight, i think with cruisers and smaller they were secured in place, if you look at say the ships of Iron Bottom sound (Guadalcanal) most of the wrecks (cruisers and Destroyers) still have their turrets in place, and even on Bismarck the secondary armaments are all still in place, so for my money they would still be in place
"Wow, how'd you get it to work?"
"I ran a Physical Impulse Mechanical Stress Routine"
"Huh?"
"I kicked it."
"Ahh."
William J
Post by William J »
Oh okay Andy. Thanks for that - food for thought.
Regards
William J
Post by William J »
To make the handrails on the upper structures - and to be able to distort them to create impression of the damage and corrosion - I am not using PE, rather I am using window fly-wire screenings. I had some old fly-wire laying around the house, so I am using it.
