UPDATE 4AOh Boy! Was it ever a lot of fun taking apart the “ship” that I had put together with one set of pieces to generate another set of pieces so that I can build another “ship”?! If you have been following the Calling All Thresher/Permit Class SSN Fans this will seem familiar to you as I posted essentially the same thing there yesterday before I decided to start this WIP on this site.
I started by segmenting the ship into seven segments, because my buddy said that he could do parts up to about 4” long. With seven segments the largest piece is 4.0” x 2.5” at 1/150 scale. AsI said in the last post, based on advice I was given that 1/144 is a more common scale, I’ve decided to build her in 1/144 as opposed to 1/150, so the largest piece will be 4.2” x 2.6”, which is a little long but 4” was an exact limit. There are 13 parts, with 3 of them being duplicates.
I should perhaps mention that my buddy said that the parts couldn’t be solid, that they had to be hollow. We agreed that 1/8” (0.125”) would be sufficient. Increasing in size to 1/144 increases this value to 0.13” when I scale the model as is, which I will do, because to do otherwise would mean essentially redoing it. Again though, this small increase in width shouldn’t be a problem.
Below are images of the parts, beginning with an exploded view of the model with the individual parts identified, followed by close-ups of the individual part so the detail of each part may be seen. Having put her together, I had to “paint” her, so the last few images show her “painted” in the proper colors. Due to the 10 pic limit on this site, the images will be split onto two posts.
All of the design was done using AutoCAD Civil3D. The “Realistic Visual Display” option (using default settings) was used in all of the images.
After segmenting the ship and hollowing it out I decided to provide a means to align and provide support to the pieces. I did this by adding a ½” wide strip at the ends of each piece, in which I “drilled” 3/8” holes through the center of to accommodate a 3/8” rod down the middle of the hull, which may not be necessary. I also “drilled” small holes on the aft side strips and put slightly smaller extrusions on the forward side strips for aligning the parts readily. I put two on each side, but probably could get away with one, and in act have already changed it although the pictures don’t reflect this change.
Because of size restrictions, the sail had to be a separate part, so I cut it out and extruded some small knobs, which fit into holes drilled in a plate I attached inside the hull. The knobs probably aren’t necessary, but they look cool and I’m going to keep them.
The tail section and to a lesser degree the diving planes took the most time to complete due mostly to me not taking the right approach to doing it. An interesting thing about creating parts in AutoCad is that there is usually more than one way to make a part, and some are better than others. In hindsight, there was a far easier way than the way I did it, but such is life.
I put the “painted” model over a light blue background and I think it looks pretty cool. I’m sure if I knew how, I could change the defaults to make it look better, but the intent here was not to build a virtual model, but to create the parts for a real model.
ENJOY!
The remaining images will follow shortly…
