It is currently Thu Aug 28, 2025 8:38 pm
Post new topic Reply to topic  [ 107 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: Sun Jul 13, 2014 11:36 am
With North Carolina finally finished, onto the next project. With a workshop littered with more hulls than Puget Sound in her heyday, the hardest part was to actually pick the next project. Since our local IPMS club is having a Tin Can group build this year (that was my idea), I figured that would be the best kit to tackle next.
I've previously reviewed the Z-17, and had done some work on it, but just none in the last two months.
After I first got her, I started by water lining the hull, then painting the hull black, as to make sure those big ass portholes were covered with paint.
File comment: The hull painted black
After masking the boot and painting the hull, I painted and then added the aft main deck. Which gave me a little bit of trouble, but it finally snapped into place. I also assembled, puttied and sanded the funnels, then painted the funnel tops aluminum.
File comment: Funnels are just sitting on the hull
And that is how she stayed until last night. I started assembling some of the superstructure components, getting them ready to paint, then dry fitted what I had done together. I also removed the Aztec stairs as I went along.
File comment: Can't find a good bow on photo to see if the bridge wings really curve like that.
The fit is pretty good - so far it doesn't seem like I will need too much filler, if at all.
I may have mentioned in the review that this kit cries out for a photo-etch set. I have the Eduard set for the Trumpeter Z-25, but that appears to be custom fit for that kit, so I'm hesitant to use it for this kit. I may just get some generic Kriegsmarine doors, ladders and railings and go from there.
More to come...
PostPosted: Mon Jul 14, 2014 7:02 am
I've been looking forward to what can be done with this kit since it's on my ever growing list of ships I want to build. Fantastic work so far! There's so few pictures available of the German destroyers compared with the capital ships. I find myself scouring Youtube for useful stuff.
stash:
1/350 Grosser Kurfurst by ICM
1/350 Seydlitz
PostPosted: Sat Jul 19, 2014 5:44 pm
So I went ahead and ordered some German railings, doors and hatches and inclined ladders from Free Time Hobbies. According to the tracking info, it will probably get here Monday. In the meantime, I started doing some more work on the funnels. The Trumpeter PE funnel grates are narrower and a little longer than the Z-17 funnels, so I wasn't going to use them. Instead, I started making my own out of plastic card. Then, after I got the plastic card onto the funnels and roughed out the openings, I realized I could now use the Trump PE, if I didn't make the openings too wide. So, that is what I did.
File comment: Opening in the forward funnel roughed out
File comment: The Trumpeter PE funnel caps. The ends are snipped for it to fit on the Zvezda funnel.
File comment: Trump PE on the modified Zvezda funnel
File comment: After funnel opening roughed out
File comment: Z-17 in her new case
Other than some painting, that is about all I can do while waiting on the photo-etch to arrive. While I wait, I may do some more work on this other tin can that I started...
PostPosted: Sun Jul 20, 2014 11:54 am
Nice work Martin! :thumbs_up_1: :thumbs_up_1:
Bob Pink. :wave_1:
PostPosted: Mon Jul 21, 2014 9:13 pm
On the gun mount, I took this screenshot from a youtube video I saw today:
I don't think this can be anything but a 12.7cm gun on a German destroyer. It shows for about 2 seconds on the below youtube link at time mark 7:37.
http://www.youtube.com/watch?v=CHOu1YHWZ3Q
I think we both have the same pinnace on our ships. Maybe you'll find this link useful:
http://www.ship-model-today.de/sd126.htm
stash:
1/350 Seydlitz
PostPosted: Mon Jul 21, 2014 9:45 pm
Interesting. It looks like the interior of the shield is dark, while the gun itself it light. Thanks!
Photo etch arrived today!
PostPosted: Thu Jul 24, 2014 11:11 am
So..., question for the day, will two destroyers be more, or less, time consuming than one battleship?
:big_grin:
Your usual exceptionally clean work thus far. I find destroyers more appealing than battleships anyway so look forward to watching these. Different shipbuilding from approximately the same period is always interesting as well.
Great stuff.
Mac
PostPosted: Thu Jul 24, 2014 11:22 am
How does the fit, surface detail, and accuracy compare with Trumpeter or Dragon 'Z' destroyer kits? At least there are ships of similar class from 3 manufacturers to compare. Would components from a Dragon Z (gun turrets, AA armaments, torpedo tubes, etc.) result in a better model? :wave_1:
PostPosted: Thu Jul 24, 2014 1:19 pm
Fit is better than I thought, so far it's not too bad. Surface detail is okay...a little bland. Detail is definitely better on the Dragon kits.
I can't really speak to the accuracy - but it certainly looks like a Z class kit.
I haven't tried to mix and match parts, so I can't comment on that either.
PostPosted: Thu Jul 24, 2014 1:34 pm
Amazing how more free time makes life more enjoyable. Nice.
PostPosted: Thu Jul 24, 2014 4:49 pm
The torpedo tubes on the Z-17 have a shielded open position for the operators. On my Z-39 dragon kit, they are fully enclosed and covered by a three windowed cover. Also the Dragon offerings have a wooden deck holding life rafts molded on at the fore end. Looking at published pictures, there'd really be no detail gain.
The AA guns from the dragon kit are very detailed. Published pictures from the Zvezda far less so. That being said, the only AA-pieces in common will be the early model twin 37mm and the single 20mm.
The Type 36 (Z 17-Z 22) was the last German destroyer equipped with the 12.7cm main gun until the type 36B(mob). One of which is offered by Trumpeter (z-43).
The types 36A and 36A(mob) all have 15cm main guns in a different shielded mounting. Unfortunately Dragon doesn't offer a type 34 or 34A which would share the same main armaments as the type 36.
stash:
1/350 Seydlitz
PostPosted: Thu Jul 24, 2014 6:41 pm
When I purchased my Z-17, I did a comparation among Dragon's Z-39, Trumpeter's Z-30 and Zvezda's Z-17. Comparing the 3 kits with some plans from russian books and considering the three ships are from different class (Z-17 1936, Z-30 1936A and Z-39 1936A (Mob)), my conclusions are
- Dragon's Z-39 is the better detailed kit but to me it's stern is too much strait and it has a issue at lower stern area where propeller shafts are instaled.
- Trumpeters Z-30 is less well detailed than Dragon's Zerstörers, it's entire hull looks a little bit too large at it's width, but general proportions are better than Dragon's Z-39. There is a issue at stern at rudder area too, but less noticeable than at Dragon's kit.
- Seems to me Zvezdas Z-17 has the better hull proportions, near matching plans. It's stern is correct too for a 1936 class, but it's the poorly detailed among the three kits. I observed portholes at hull are too large and it's pattern is very different from we can see at real Z-17 pictures. There are some other minor issues at superstructure too I dont remember now. Kit is not the betther but still correctable and buildable.
In a comparation among Trumpeter stern (left) and Dragon (right) we can see how much Dragon's stern is strait.
Comparing this view from Trumpeter stern (top) and Dragon (lower) with plans, we can see it's issues:
Best Regards,
Ricardo
PostPosted: Thu Jul 24, 2014 8:52 pm
:big_grin:
Great stuff.
Mac
LOL. Less, I hope!! And thanks for the kind words - much appreciated.
PostPosted: Sun Jul 27, 2014 1:21 pm
Looks great Martin! Keep on the good work! :thumbs_up_1:
Regards!
Dirk
UNSERE KRIEGSMARINE!
PostPosted: Tue Jul 29, 2014 8:13 pm
Thanks Dirk!
More progress was made over the weekend. I started adding the photo-etch doors from Lion Roar set:
File comment: Before photo-etch doors
File comment: The aforementioned doors...
File comment: After...
And then the other side (which I did first, but neglected to take photos of until I was done).
With the doors (mostly) on (realized I forgot two afterwards), I added the piping to the funnel, but first drilled out the tops...
While that dried, I started assembling the main armament:
File comment: Not much detail on the gun mounts
When these were dry, I glued the shields to the bases and the gun barrels to the shields. Just haven't taken any photos yet.
Overall, it's a pretty decent model. Goes together without much fuss.
PostPosted: Tue Jul 29, 2014 8:23 pm
I neglected to mention that I also assembled the torpedo launchers.
Here are few more photos I just snapped of where she is at as of tonight:
File comment: Main battery armament
File comment: Torpedo launcher
I'm going to keep working on her until I leave for the IPMS/USA National convention next week, my goal is to finish her for our local IPMS September meeting, which is when our "Tin Can Sailor" group builds are supposed to be done.
PostPosted: Tue Jul 29, 2014 8:36 pm
Looking good, Martin. I like that the blast bags are molded on. Did you drill the little portholes in the PE hatches?
stash:
1/350 Seydlitz
PostPosted: Wed Jul 30, 2014 10:01 am
Thanks. Oh, gosh no. Those were there!
PostPosted: Sun Aug 03, 2014 9:07 pm
After airbrushing some parts Hellgrau 50, I decided to do something to those huge portholes. Photos show them to be dark, so I decided to paint them with a small brush.
That may be the last installment before the Nationals. I should probably pay some attention to the other people who live in my house the next two nights before I go!
PostPosted: Sun Aug 31, 2014 3:43 pm
Look well done cant wait to see it in person! Mine is done too except for the paint and I had a question about that. If I was doing a wartime version, would it still be Dunkelgrau 50 and Hellgrau 51 or is it a different color? I know the eagle crest has to come off the bridge for wartime appearance.
Jon
Users browsing this forum: Majestic-12 [Bot] and 8 guests
